Question about Saeco Magic De Luxe Espresso Machine
Leak Our Saeco is about five years old and has been relatively problem free. A few days ago we experienced a leak that overflowed the small tray that collects excess ground coffee directly below the bean receptacle inside machine. While cleaning the machine thoroughly, we noticed that there was a buildup of soggy coffee in the hole that you see after removing the brew group near where the waste plugs accumulate. After cleaning this up, we reassembled and have no further leaks however the coffee just doesn't quite taste right. Any suggestions?
    Problem Solver:
  • 11 Answers
If you clean your brew unit and coffee lines infrequently you're coffee may taste differently when you do get around to cleaning them.
If you are not happy with the taste, I would receommend the following steps
1. A Good Descale (See our article here for on Descaling your Coffee Machine for details) - This will remove excess mineral build up.
2. Try a Saeco Cleaning Tablet in your brew unit - this will remove excess organic build up (Coffee and Grease)
3. Use only filtered water
4. Rinse your brew unit every time you empty your coffee dreg drawer
That should bring your machine back to optimal coffee making condition. If you are still not happy, try some different coffee blends for a while - a change can be as good as a holiday
Paul from Coffee Shrine
Saeco Coffee Machine
Posted on Aug 21, 2008
Radiator fluid leaking from hose under overflow container on 2001
That should be the hose and pipes that feed or return coolant from the heater core thru the firewall.
Apr 24, 2010 | 2001 Chevrolet Malibu
My Saeco Vienna Superautomatica leaks
Check the little chamber under the white plastic valve behind the brew unit, that might be blocked with coffee.
Apr 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Brewed coffee leaking into spill tray underneath
HI
You have a stripped thumb screw. It needs to be replaced. It holds the filter screen in.
Dec 06, 2009 | Saeco Magic Comfort Plus Espresso Machine
Liquid leak while Vienna runs...but where from?
You may have a cracked coil inside the boiler and cracked nut of the coil going up to the wiring lug. Check it out, it will be a hair thin crack, almost invisible.
Feb 11, 2009 | Saeco Vienna De Luxe Espresso Machine
Small leak from the bottom right side (when looking at the machine) of my Saeco Incanto Sirius Espresso Machine when being operated. After two or three cups of coffe are made, need to move machine to the...
I have the same problem. To day I opened the Saeco and discovered that the unit attached to the knob at the right side of the machine must be replaced. Water came out in two places. I dont know where to buy this part.
Per
Oct 13, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto not grinding
Hi Chris,
The leaking is your steam valve that has to be replaced, you can see this if you open the door and look up in the right corner there you will see water drip.
If not then you have a pipe or boiler leak.
How old is your machine?
How often do you descale the machine?
When you try to make a cup of coffee, starts the grinder for two seconds or is it dead?
Hope this will help you.
Jul 19, 2008 | Coffee Makers & Espresso Machines
Cd tray won't open
their is an tiny hole in the cd tray.. f their is... u insert a pin that cn fit to it you estimate the pin head is... while pushing the eject button
Jun 05, 2008 | Compaq (CDD480172) CD-RW Burner
Hi, we have aa Saecco Cafe Grande an automatic Espresso Coffee machine. We purchased over 1 year ago from Future Shop. The machine only recentlly started to leak from the bottom, I did some...
Possible areas are the steam valve leaking or the boiler valve housing is leaking. I suggest Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Apr 05, 2008 | Saeco Vienna SuperAutomatica Coffee...
Water Leaking and not coming out from the nozzel
Thank you thank you!!! This problem has been irking us for months! The people in our company adore the coffee the Saeco Incanto Sirius makes so we just lived with the leak. The fix was such a simple thing, heh.
I used a cable tie to clean out the hole. The hole is very small - a design mistake, I'd say - and when I unclogged it I could see the cable tie coming out and coffee sludge flowing into the drip tray.
Dec 17, 2007 | Saeco 00034 Incanto Sirius Super Automatic...
Leaking Water shorts out machine
I had the same problem. What may be the problem is the tiny water drip hole that feeds the drip tray is blocked with coffee sludge. Open the machine and remove the dump bucket, drip tray, and the brew group. Behind the brew group is a flat plastic piece which has a small drip hole at the bottom of it. This may be blocked which causes the water that should go into the drip tray to build up and overflow inside the machine running onto the countertop. Clean out the area behind the little drip hole and the hole itself. This should cure it.
Nov 16, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Magic De Luxe Espresso Machine Logo
194 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
