IS your thermostat set to automatic on the fan switch? If so then you may have a stuck fan relay in the air handler. If it has an electronic control board the relay is on the board and the whole board would need replaced. If it is not a stuck relay then you could have a crossed wire from the thermostat to the air handle, usually the green wire from the t-stat, it could be crossed with the red wire that supplies 24 volts to the t-stat.
