Question about Kenmore 62702 Microwave Oven
Can't figure out what wrong
We have a Kenmore microwave model number 721.80609500 that lost power to all the functions recently. I think it may be the touch pad on the microwave but not sure. They recently ordered and installed a new circuit board but that didn't solve the problem. There is no lights, no display at all, and nothing comes on when plugged in. So far it appears to get power to everything I have checked and can get to easily. Any ideas would be greatly appreciated.
  • Kenmore Master
  • 9,086 Answers
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Aug 21, 2008
Microwave has lost power
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101
Mar 19, 2011 | Kenmore Microwave Ovens
Kenmore model number 721.80593400 everything works but will not heat food it also sounds louder. I just replaced the magnetron and that did not help any ideas.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 04, 2011 | Kenmore 80012 Microwave Oven
Kenmore elite microwave/convection oven just lost power and will not come back on. have checked the the outlet and it works.
Microwave Oven Basic Troubleshooting Tips
heatman101
Dec 26, 2010 | Kenmore Microwave Ovens
No power
Basic Microwave Oven Troubleshooting Tips
heatman101
Aug 02, 2010 | Kenmore 63793 Convection / Microwave Oven
Our Kenmore microwave started emitting odors and then quit
To figure out what is wrong with it, it will have to be removed from the wall, Then the top cover will have to be removed, then you can look for any swelled capacitors, burn marks on the circuit board or any shorted wires.
The power supply is most likely faulty . You can test the power with a voltmeter from power supply to main circuit board.
Oct 28, 2009 | Microwave Ovens
No power at all
You probably blew the fuse in the microwave.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
There may also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Nov 22, 2008 | Kenmore 63792 Microwave Oven
Can't figure how to change settings from high to low
If you've lost your owner's manual, you can often find them for free download at the Sears parts site.
Just enter your model number and on the resulting page, look for a manual button on the right side of the screen.
Nov 20, 2008 | Kenmore 62109 Microwave Oven
Kenmore 62702 Microwave Oven Logo
106 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
