Question about Canon PIXMA iP2000 InkJet Printer
Canon PIXMA iP2000 service manual
My waste ink absorber got full so i open the printer and clean it up
but was not to fix the mehanic the cleanse the printer mouth, so i need help on it or diagram or serice manual pls
  • Anonymous Sep 29, 2008
    service tool para resetear ip 2000
    President:
  • 2,712 Answers
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
With the printer on, open the lids and wait for the ink tanks to center, as when you put new ink tanks in. Unplug printer. With a flashlight, good tweezers, and small hands (or enlist the help of someone who has them, or get loooong tweezers), reach in over the right where the ink tanks usually rest. Carefully remove the two pads which are held in only by a formed rubber foot. These two pads are porous but stiff plastic. Rinse them in water (in a bowl and carefully so that you don't lose them down the sink!) until the water stays clean. Thoroughly dry them by gently squeezing between paper towels. Swab area that they were sitting in with cotton swabs if you see any pools of loose ink. Replace pads. Reset printer's computer as described above, print a few test pages if neccessary, and everything should be okay!
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 03, 2008
A printer,s ink pad is at the end of its service life
This means the waste ink collection sponge is full. This counter can be reset but it is strongly recommended to replace the ink pad as you will end up with a large amount of ink spilt on your desk if you continue to use the printer after the pads lifespan. It can be quite a large job to change depending on the model. If the printer is not an expensive model it may be more cost effective and less messy to simply replace it with a similar model.
Jan 14, 2017 | The Office Equipment & Supplies
5C00 Error Code as well as yellow and green alternating lights
To fix this error is much easier than it looks. Unplug the printer power. Move the ink cartridge cradle to the left. Over to the right you will see a small pad about 1cm square. This pad and the area around should be covered with ink. Get a cloth and press down on this pad - it's not fixed so should come away with the cloth, otherwise use tweezers gently. Squeeze the pad several times between your thumb and forefinger while inside the microfibre cloth to remove ink build up. Then when not much ink comes out on the cloth, clean the area in the printer around the pad so that looks free from ink too. Then position the pad back in place, move the cradle back into position, plug in and switch on - should work fine now.
Jan 14, 2017 | Office Equipment & Supplies
My Canon PIXMA MX700 is not turning on! I have checked all the cords even moved from one outlet to another and its still not turning on. Should I just purchase an new one this model is an old on
Do you have a CD to install this printer? if you do go into MY COMPUTER where you can erase things and erase the printer and its system then shut computer off and restart then reinstall the printer using your CD to reinstall it. Some times you have to delete things and reinstall them to work.
Jan 09, 2017 | Canon Office Equipment & Supplies
How do i solve an error e000-0000 canon ir 2202 please
Dear
Its related to the fixing temp. do the error clear on service mode. then check the fixing film assy. heater circuit contact points for corrosion. Replace it.
Thanks.
Dec 12, 2014 | Canon Office Equipment & Supplies
My Epson WF-3640 is printing with gaps in the text. How do I fix this issue?
Make sure you should remove shipping tape from the ink cartridge. These taps are used to protect printer during shipping but you have to remove it before starting printing. Beacuse these taps prevent the ink to entering in print head. If you will not found shipping tape in your printer then there is terr off strip, remove it. The tear off strip seals the the vent holes on the top of the cartridge to prevent it from drying out on the shelf or during shipping.
After ensuring that the shipping tape has been removed, run the printer's "Head Cleaning" utility to prime the cartridge, then print a test page.
See full detail at- http://guideusermanual.com/product-name-workforce-wf-3640-manual&po=152836&lang=English
Sep 18, 2014 | Epson WorkForce WF-3640 Wireless Color...
How to clean ink absorber for canon mp237
First of all open the ink cartridge of your printer.
When the ink cartridge would move all the way over, then disconnect the power cord of your printer.
Now pull the frame of rubber from the printer and remove ink pads.
To clean ink pads you may place them in a bowl having warm water and start rubbing and squeezing them to clean it from ink.
After removal of ink, keep the pads separate for dry.
When the pads get dry completely, place them back in rubber frame.
Reinstall the rubber frame in your printer.
For deep guide and support refer to-
Canon Pixma Mp237 Manual
Oct 07, 2013 | Canon PIXMA MP230 Multifunction color...
Prinnter not printing but showing 'put custom in manual tray'
There is still a print job in the queue. Place a sheet so it prints or kill the job.
Open Printers and Faxes. Open printer. Highlight jobs and Right click > Cancel, or Documents > Cancel.
For those stubborn jobs, Right click My Computer > Manage. Choose Services and Applications > Services > Print Spooler. Right click and stop. Then start. This may have to be done from the Print Server if it's network printer. Contact IT to kill.
Nov 09, 2012 | Office Equipment & Supplies
Printer won't recognize cartridge
I had the same problem. I'm not sure but I think I replaced the cartridges when the printer was on because I turned the printer off and removed one of the cartridges. When I turned the printer back on it recognized that cartridge but not the others. I turned the printer off again, rmoved all cartiridges and put them back in when the printer was still off. When I turned the printer on again I had no problems. So...try turning off the printer, rmove all cartridges, then put them back in and restart printer. Hope this works for you .
Nov 28, 2007 | Epson Stylus 2200 InkJet Photo Printer
Canon PIXMA iP2000 InkJet Printer Logo
749 people viewed this question
old marine
old marine
