Question about Watches
Sekonda 3850 battery replacement
Replaced battery watch working but no digital display
  • Anonymous Sep 04, 2008
    Watch comes on but when you press the light button the whole screen goes off.
  • matt2nd
    matt2nd Aug 26, 2012
    thank you richard i had same problem
Hi, its Richard, after battery replacement before replacing watch back, there is a small hole in the movement near the edge if you look down it there is a metal plate at the bottom gently press this with a fine screwdriver, the display will then come on, it is a reset switch, regards Richard.
Posted on Aug 19, 2009
  • matt2nd
    thanks richard i had the same problem now fixed thanks to you
Have you checked a different battery, or verified that the replacement battery is of the same type?
The reaction of the watch is typical for power stress/voltage drop, either due to a bad(weak, old) battery or the wrong battery type.
Posted on Feb 23, 2009
Change battery Sekonda wrist watch
Posted on Feb 15, 2010
  • bandit02680 Apr 20, 2011
    Hi there!
    My watch has done exactly the same thing. Replaced the watch under warranty in the first year (seconds hand came loose) and now the watch is doing this, and the seconds hand has come loose on this one too!
    Shoddy build quality I think, I don't even wear thiswatch to work!
Buttons and analog time stopped working
If the digital time is still showing, it looks like your watch has a defect. If the digital display doesn't display anything, the most probable cause is an empty battery. In both cases you should take it to the shop to have it repaired/the battery replaced.
May 25, 2015 | Casio Dress watch AQ230A7D Watch for Men
On my diesel DZ-4108 I changed all of the batteries and the hour and minuet hands are working, but the digital display is not working the batteries are brand new but on digital display what can I do?
I just figured this out. When you replace the batteries, there's the white plastic cover secured with two screws. Remove them and you'll see an area with two exposed 'pads' that says 'reset'. Simply touch them together with a paperclip, screwdriver or whatever and the watch starts right up. :)
Jun 15, 2012 | Diesel DZ4108 Pocket Watch
The hands have stopped on my Fossil Big Tic watch but the digital display still works, like the seconds.
This watch has 2 batteries so sounds like the main one has gone flat and the display one is still going, you just need to get the battery replaced.
Aug 24, 2010 | Fossil Big Tic JR7896 Watch
Stopped working and all digital figures displayed!
If the display is not dim the battery is probably OK. Try removing the battery, test it anyway, and after a minute or two replace it (I'd use a new one anyway) and see if the problem is cleared. Sometimes just power cycling will "reboot" the watch. If that doesn't do it I'm afraid it will need to visit a Breitling service center.
Apr 15, 2010 | Breitling Aerospace 455 Wrist Watch
Cannot get the analoue display to work on my gucci i-gucci digital watch. can you advise please
Check out if your watch has two separate batteries - one for digital and another for analogue movement.
If it does, replace analogue battery. If it does not - you will need help of a watchmaker.
Rate, please.
Jul 19, 2009 | Bulova Watch
Brand new watch won't work
Check your users manual if your watch have two batteries. If yes, you need to replace digital part battery.
If your watch has only one battery, your digital screen or plate is defective. Bring it back to the retailer and ask to replace for the decently working watch.
But first of all try to fiddle with all pushbattons- sometimes it helps.
Dec 20, 2008 | Fossil Leather Multifunction Black Ip Ana...
Fossil Big Tic Watch - setting the correct time on the digital display
The watch is scrolling through the seconds, and is not something that needs to be set. If there is a bottom it is only there to change the way the seconds are scrolling? There are many different types of these, but most are just standard seconds.
Oct 25, 2007 | Fossil JR8096 Wrist Watch
Fossil JR8096 - Display Not Working
hi i have a watch very simalar. They run on two seperate batteries. sounds like one of them is dead. get the digigtal one replaced
Aug 21, 2007 | Fossil JR8096 Wrist Watch
Watches Logo
4,478 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
