Can't open any pictures on my pc since it automatically did an update recently.
  • 790 Answers
Hello!!!
y dont u a try a system restore!!!
Posted on Aug 20, 2008
I recieved a Bresser Biolux al as a gift, but unfortunatly the usb camera that comes with it doesn't seem to work, there is no picture on my pc when i chose 'open the camera'. I have downloaded...
If your pictures in camera memory, try to move it to your memory card. While your camera does not paired successfully with PC, you use the card reader to your pictures by PC.
Aug 05, 2011 | Cameras
What is an ArcCon ac application error0xc00000006?
What you describe falls under the general category of svchost.exe issues. Svchost.exe is used by your computer to access the registry and check the services to load during system startup.
arccon.ac is an ArcSoft Connect Notifier. There are two possibilities why its happening:
  1. Microsoft releases regular security updates that are installed automatically on your computer by the Automatic Updates feature, which is enabled by default on your computer. The Svchost.exe Application error usually appears due to a problem with a recent update.
Closing the error message might freeze your computer. To fix this error, perform the following tasks.
  1. Open Control Panel, select Performance and Maintenance, and then select Services.
  2. In the System Properties dialog box, open the Automatic Updates tab.
  3. Next, select the Turn Off Automatic Updates option.
  4. Select Apply and then OK to accept your changes and exit the System Properties dialog box.
  5. Restart your PC.
  6. Ensure that you are connected to the Internet and then select the Windows Update command from Start > All Programs to manually update Windows.
  7. After the update is complete, enable the automatic updates again from System Properties > Automatic Updates.
This should rectify your application error. However, if the error keeps reappearing, then you might turn off automatic updates permanently and manually perform Windows updates at regular intervals.
Errors Caused By Virus Infection
Let's hope that this isn't the case. Lengthy procedure but if you are still having trouble, we'll cross that bridge when we get to it.
Dec 09, 2009 | Computers & Internet
Some applications are opening & closing
check your system is fully updated with anti virus program, if not could be a virus problem, update the system and remove the virus, also check if you had recently installed any programs, that might had caused this problem then uninstall it..
Nov 10, 2009 | IBM ThinkCentre M50 PC Desktop
No picture but i have sound, recently done update.
It has nothing to with the update , and everything to do
with the G.P.U. warping the P.C. board just enough to
break open the video feed . So the unit sound great
but no picture.
Microsoft will cover this problem , but it is incumbent on
you to call 1-800 4my XBOX and get the RMA and
ship it in Quickly before your warranty runs out or
it does some new trick that Microsoft won't cover.
The Fix is to have G.P.U re-flowed to P.C board.
Rob
Oct 11, 2009 | Microsoft Xbox 360 Console
Is there anyway to fix a memory card. I am getting 1/0 device error when I put the memory cad into my pc. It will not let me open it to get the pictures.
Dear Chirpy1,
Assuming that you are running Microsoft Windows Vista OS on your PC .. Might be this update would help you.. its a manual update and is not a part of automatic updates that your computer downloads automatically.
http://support.microsoft.com/kb/936825
Please let me know if the card works after installing this update.
If not then please try using the card on some different compter .. that way we would be able to know if its a problem with the card or with that particular computer.
Hope that helps.
Regards,
Srinivas
Jun 21, 2009 | Kodak EasyShare C643 Digital Camera
Can't get the software for my new Panasonic TZ5 Lumix to load into my iMac! iMac doesn't recognize it as a CD. Urgently need to download my photos to update my website! Help! Patti
there is two ways to load pictures from your cam to pc:
step 1
youll need a card reader to put in the memory card to a usb port.
A.then the computer will recognize the device as a FLASH DISK/ REMOVABLE DISK.
B.some pc will automatically open once you inserted the card reader to the usb port "click open containing folder". if the pc does not open automatically open my computer and find the "falsh disk/removable disk" and click.
C.once inside find the DCIM folder this contains your pictures taken from your cam.
D. now you can choose a picture you like to be transfered or copy to your PC
E. save picture in a folder that you ca easily remember
step 2
need a usb wire to connect cam to usb port
A. attach wire from your cam to usb port/pc
B. your cam will show options choose storage data. the other options requires a software
C.same as step 1 from B-E
i hope i was able to help you with your problem! good luck!
Nov 01, 2008 | Cameras
Microsoft Office 2003 Professional - Picture manager
Fixed the problem - Even though the pc checks for updates automatically I should have checked to see if there were any available updates at the microsoft website. There were 3 available and once downloaded and installed the picture manager part of office suite professional 2003 is now working just fine!
Sep 19, 2008 | Microsoft Office 2003 Basic Edition...
Dell pc giving blue screen -issue with recent Windows update?
Dear SherriJ:
Some time you might get this issues with the updates if they doesn't install properly or the computer turns off while instaiing updates.
However you can select last known good configuration of restore you computer to earlier time.
I would recommend you to keep the automatic updates on that will help you keep your computer in a good state.
Regards,
Mohammed
Jul 18, 2008 | Dell Dimension 4600 PC Desktop
USB 2.0 device
All you have to do is Windows update! Sorry, everybody has to update their version of Windows. If you want windows to let you know when there are important updates I can show you how to set this up. Open control panel, open the icon System. Click Automatic Updates tab. You will see you have choices. Pick one. Click Apply & than OK. After your computer is all updated try your iphone again. I'm sure it will be fine. Good day!
Please vote......
Jan 11, 2008 | Intel Motherboard
Picture package problem opening
Have found the solution to the problem. If you cannot access Picture Package because it says Macromedia Flash needs to be downloaded, and you have already downloaded Flash successfully then the problem is with Picture Package, and it needs to be updated. Go to http://www.ppackage.com/e/index.html and download the most recent update for your version of Picture Package. This solved the problem for me and hopefully will do the same for you!
Aug 21, 2006 | Sony Handycam DCR-HC20 Mini DV Digital...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
