Question about Uniden Cordless Phone
Phone not Charging
My phone is plugged in directly to a working outlet and the charge/in use light has been blinking. Never solid. The phone will not charge. How do I fix this?
  • Anonymous Aug 25, 2008
    I'm having the same problem, have 3 units and none of them are charging anymore, has been less than a month since purchased a brand new set from costco!! How to fix this uniden phone and make it charge correctly? Help! All my phones are out of charge now!
I'm having the same problem!...All three units not charging?
Posted on Aug 25, 2008
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Why wont my motorola photon q phone charge or power up...no green light comes on at all
Your charge cord may fit, but it may not be configured to your phone. I just bought a new Nexus phone that has the same charge port as my older Galaxy 4s phone. The Nexus charge plug fits into the Galaxy 4s charge port with no problems but does not charge after plugged into outlet. But the older charge cord will work with the new Nexus charging wise but data transfer will not work. So you may have a charge cord that plugs into phone, but may be configured differently due to phone manufacturer. Hope this helps.
Dec 19, 2014 | Motorola Cell Phones
My Samsung s5 is not charging
try this
SAMSUNG GALAXY S5 - NO POWER, BATTERY, CHARGING AND CHARGER ISSUES alltabshighlighted.jpg
No power, battery, charging and charger issues
This guide contains troubleshooting steps and advice to help resolve issues you may experience when attempting to charge the handset.
After performing each step, please test to see if the issue is resolved.
Symptoms:
  • Battery not charging
  • Battery is not lasting long
  • Phone won't charge
  • Charging error
  • Failure to charge
  • Display remains black or blank
  • No power
  • Boot failure
  • Overheating
Troubleshooting Questions
  • Are you using the correct equipment?Make sure you are using an approved Samsung wall charger and USB charging cable. Other brands of charging accessories may have different voltage parameters and could cause charging issues when used with Samsung devices.
  • Have you charged your phone for longer than 30min? Leave your phone plugged in to the charger for about 30min without powering on. In some cases, it may take slightly longer for your phone to charge.
  • Is the battery icon displayed on the screen when charging? After charging your phone for a little while you should get a battery charging icon appear on the screen which will indicate that your battery is charging properly.
    If the charging icon appears, leave your phone for a little longer before you try to switch your phone on.
    If however, the screen is blank and nothing is displayed, follow the below troubleshooting steps.
  • Is the charging cable plugged into a USB port? Some charging cables can disconnect from the wall outlet adapter and plug directly into a USB port. However, when plugged into a USB port, the charging process is much slower due to the limited power output of USB ports. Instead, plug the device directly into a wall outlet to speed up the charging process.
  • Is the outlet faulty? Try a different outlet or check for a switch connected to the outlet. If possible, try powering a different device on the same outlet.
  • Does another USB cable, or wall charger work? Charging issues can occur if either the battery or charging cable is damaged. Verify that the charging contacts are clean. If necessary, clean the contacts using a cotton swab and rubbing on isopropyl alcohol.
    If possible, test the charging cable by plugging it into another device and seeing if the device charges. Alternatively, try charging the device with a different cable. This may mean changing out the cable or the adapter on two-piece chargers.
    If charging through a car charging kit, ensure that the car engine is running, and if possible try to charge other devices using other cables, through the same car kit. If none will charge, then it is likely there is a fault with the car charging kit. It is recommended to continue to cross-test devices, cables, and car kits until the problem device can be identified.
    If the device charges when using a different USB cable or wall charger, the issue most likely lies with the charging accessory. In this case, follow the approved charger repair / replacement process.
    Also, if the charger is connected via an extension or other multi-socket adapter, remove this and plug the charger directly into the wall-mounted socket. This will eliminate the possibility of a fault with the adapter.
    If you are still unable to charge your device, continue to the next step.
  • Has the phone experienced any shock or exposure to water? Accidental physical shock to a handset can sometimes cause problems to arise with battery or charger, as these components contain delicate parts, particularly. Damage can occur either to the component itself, or to the component's connection to the motherboard.
    Water exposure can also lead to damage of these components, however due to the slow way in which this type of damage can manifest itself, the cause may not always be readily obvious.
    With any physical damage of this nature, the only recourse is to contact the device manufacturer, and follow their approved repair or replacement process.
^_^
Jul 04, 2014 | Samsung Galaxy Cell Phones
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Blackberry storm charging problem is plugged into the computer to
I've had this problem just since the last software upgrade. New charger, cable & battery haven't solved it.
Dec 14, 2009 | RIM BlackBerry Storm 9530 Smartphone
8525 Red Light
Take the battery out then plug in the phone. The light should turn red, then reinsert the battery with it still plugged in. It should turn orange and start charging.
Jun 08, 2008 | Cingular Wireless Cingular 8525 Smartphone
Display shows "Not Registered"
1. Remove battery from phone, and unplug from charging cable
2. Unplug Phone base
3. Hold Page button on base and plug it back in. While holding page button wait for in use light to go solid. Once solid unplug base.
4. Hold clear button on the phone pod and plug in charging cable until you see ----- on the screen.
5. Press 0
6. Unplug power from phone pod
7. Hold clear button on the phone pod and plug in charging cable until you see ----- on the screen.
8. Hold the page button on the base and plug it in, Hold page button until the in use light blinks. Let go of page button.
9. Press 9 on your phone. If it says Reg o it is finished. If it says Reg fail try again if it fails twice please call Tech support.
10. Replace Battery
11. Make a test call
Oct 05, 2007 | ClearOne Communications Max Wireless...
Uniden Cordless Phone Logo
297 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
