Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Refrigerator ice machine
Our brand new whirlpool refrigerator ice machine does not work at all. What can we do the get it to work. It is an $2000.00 refrigerator!
  • takastone Sep 07, 2008
    Our icemaker has just quit..........suddenly. I haven't checked whether
    the feed line is iced but if you other thoughts I would love to hear
    them.
    doug
  • nanci9rfan Sep 19, 2008
    We used up all the ice one evening and now the ice maker won't dispense any more ice. I can feel the cubes, but the ice won't go into the bif plastic container just inside the door.
    Help!
My understanding is Whirlpool has a one year warranty. Mine is not working but it is 3 years old. Maybe your warranty is still good.
Posted on Sep 01, 2008
How long should it take to make ice in a brand new whirlpool refrigerator?
It will depend upon how warm it is, how warm the water to the icemaker is, and how much food is in the freezer. Regardless, I would say within 24 hours you should have ice.
Aug 24, 2014 | Whirlpool Refrigerators
Refrigerator whirlpool wbm 501
Problem is defrost thermostat, defrost heating element or defrost timer and or low gas in the system. Remove the back panel in the freezer and look to see if the evaporator coils are frozen solid with ice. If so the problem is no defrost cycle. If no ice then the unit is low on gas and it has a leak. If the refrigerator is old... recycle it and go buy a new refrigerator from Whirlpool.
Feb 07, 2014 | Refrigerators
Whirlpool ER2CHMXPL ice tastes bad
If I were you id replace the ice filter or get an ice mold and put water in it and stick it in the freezer
Jan 16, 2012 | Whirlpool Refrigerators
I have a GE refrigerator side by side that is 2 years old. We noticed last night that food wasn't very cold, so we checked the temperature setting. The setting is at 9 the coldest, yet it doesn't seem to...
If the refrigerator is not cooling it could be for a couple reasons.
Either there is an excess of ice buildup between the freezer and the refrigerator or the compressor is bad. If its just and ice buildup all you need to do is remove the ice by either defrosting the refrigerator or using hot water poured down into the air vent inside the machine.
If its not the ice, its probably the compressor in which case you would have to get a professional to come and replace it which is rather costly. In most cases you are better off buying a new machine rather than replacing the compressor. Especially since it is not that old and is already having a major problem. If you decide to buy a new machine I recommend Whirlpool brand appliances.
Dec 12, 2009 | GE Refrigerators
Refrigerator/freezer not getting cold. Defrosted all items in freezer. There is air circulation though. All light bulbs are working. We have a 25.3 CF Whirlpool SXS with icemaker purchased brand new in...
it's been 6 year old now right? check your pipings, there might be some leackage on it, better yet call a technician and have check, you might have under charging thats why your cannot can't make any ice
Nov 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No ice, checked water supply
Is the box cold enough (-10/+10 degree Farenhite)? The IM head could be bad. What brand is the machine?
Sep 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Aug 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice Maker not working
Start by cleaning the condenser with a brush and a shop vac. Then get some nickleguard ice machine cleaner and wash the units plate's down going by package directions, then retry before calling a tech. It may start working but if it does not then it may save you some money by having the unit clean before the tech gets there. Ice machines are not a DIY repair. Sowwy
Mar 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ED22PW water not reaching ice maker or front dispenser
It doesn't matter if a whirlpool or any other brand is new or not, if you don't use an inlet water filter the water will taste like **** and sediment will deposit and cause catastrophic ice maker and water dispenser failure.
Feb 10, 2009 | Whirlpool GS6NBEXR Side by Side...
Whirlpool Side by Side Refrigerator Model # ED2FHEXNQOO
POSSIBLE YOU HAVE 2 SEPERATE WATER SOLENOIDS. THE SOLENOID FOR THE ICE MACHINE HAS A STRAINER AND ORFICE JUST INSIDE THE INLET SIDE OF THE WATER CONNECTION. CAREFULLY REMOVE THE ASSEMBLY AND CLEAN-IT. YOU CAN CHECK IF ICE MACHINE SOLENOID HAS POWER BY TAKING A METAL BUTTER KNIFE AND HOLDING IT JUST ABOVE THE COIL ... THE MAGNETIC FORCE SHOULD BE FELT TUGGING THE BLADE DOWN. LOSSEN THE NUT ON THE OUT-LRT SIDE OF THE ICE MACH. SOLENOID AND SEE IF YOU HAVE WATER ...
Apr 26, 2007 | Whirlpool GD2SHGX Refrigerator
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
217 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
