Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
Replacing convergnce ic s
Model kp-46wt510 i am trying to remove the d board to change the ic's but cant get the red wires out of what appears to be some sort of coil any help
  • richchapman Dec 08, 2008
    how can you remove it? that web address didn't work.
    Scholar:
  • 167 Answers
Hello .ok that coil thing is the fly back transformer.and the wire's that come out of it . come off buy a clip that hold them on.!!! you can go to this link for all the info. you need . hope this help's you . "GOOD LUCK" GO TO THIS SITE.http://home.earthlink.net/%7Eoleg.filippov/ConvergenceFix.htm ..!!! let me know ok . if it dose rate me as . FIXYA.!!! ok "GOOD LUCK"
Posted on Aug 20, 2008
How do I remove the G board from a KP-46WT510 sony projection tv?
the wires pull out but a better way to do this is with everything else out lift the board up so bottom faces rear of set--be careful when soldering at the chips a quite a number of surface mounted parts near the pins on the STKS.
May 05, 2012 | Sony KP-46WT510 46" Rear Projection HDTV
I have a red shadow in 3d on sony KP-46WT510 TV.
Ur convergence is dead.Problems:Are 3D colors,colors misaligns,and colors out of focus.Know how to solders?Must change 2 convergence ICS,and some or all the resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 17, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
The STK392-560 ICs have gone bad. They need to be replaced by a qualified TV2_bing.gif technician. The repair cost is from $200 and up.
Best of Luck
Nour BMI
Feb 17, 2010 | Sony Televison & Video
My sony tv model # KP-46WT510 is showing a three D Picture with a red outline
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 17, 2009 | Sony Televison & Video
I have a Rear Video Projector model # KP-46WT510 and it started acting up. It is a double picture when we try to watch TV. Can this be easily fixed?
Unfortunately it is a job that will require an experienced TV technician,
You have 2 large 18 pin ICs called convergence amplifiers who's job is to insure beam alignment of the three picture tubes in your TV set (Red, Green & Blue). One of the 2 chips have shorted and more than likely cause damage to the 2nd one as well. This involves removing the board where the ICs are mounted then rmoving the ICs by a process called desoldering & resoldering during the replacement process. They are not a plug in Ics.
Hope this helps.
Jul 07, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Replaced STK's, fuses ok, +/- 22 VDC ok, still can
did you checke the two 5amp IC protectors located on the G board? Those will usually blow when the original ICs fail.
Jun 12, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Convergnce sony kp65wv600
You can get replacement Ics at the following link which provides free instructions. I would recomend replacing the 4.7 ohm 1/2 watt resistors along with the two STK392-560 Ics as the resistors can get weak over time and that can lead to premature IC failure. Heres the link.
http://servicemanuals.vstore.ca/
Jan 18, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
KP-46WT510 Sony, locating boards?
I have the same model tv, with the same problem... convergence ICs were shot.  As you look into the back of the tv, the ICs are located on the backside of the large heat sinks on the tan board.  The pico fuses are directly under the heat sinks.
Removing the board is fairly easy with the exception of removing the red cables at the rear left side of the board.  You have to exert a lot of force to pull them out (they go into the grey tower looking thing) but they do come out.
I recommend taking pictures of the board before removing, and then make sure you label each connector you pull off the board.  There are six screws to remove as well.
Check with Sonny and Barry at this site.  They gave excellent directions and have a convergence repair kit for your model tv. http://servicemanuals.vstore.ca/index.php/cName/convergence-repair-kits
Dec 25, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Color video rear projector...........color red is misaligned
convergence amplifier ICS !!! replace them and associated pico fuses ICS # start with STK
Dec 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sont kp-46wt510 blinks 4 times
Four blinks is a "vertical stop error" I have a pdf file of the service manual and troubleshooting guide. If you want it,let me know where to send it.
Sep 27, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
