Question about Saeco Classico Espresso Machine
No steam Provides steam for just a short time. I noticed that both the ready light switch and steam switch light both go out. I tried descaling, but no help. Any ideas??
    Problem Solver:
  • 11 Answers
There is descaling and then there is descaling.
We have written a good article on how to descale saeco coffee machines which you may find useful.
Try a really heavy descale - use the recommended dosage of descale powder or solution in 3/4 the recommended quantity of water.
Run some coffee through the coffee side of your machine, then the water/steam side of your machine and then allow to sit for a good five monutes before repeating.
Do this until the solution no longer comes out with a greenish tinge and then flush both sides with fresh water.
Make you use on filtered water or an in tank filter in your machine.
If this doesnt work it's off to your saeco service center.
Paul from Coffee Shrine for Saeco Coffee Machines
Posted on Aug 21, 2008
Hi Ihave a Bosch B25L steam generator iron and it has stopped steaming completely. Any ideas?
Yousaf/Tony, Either the switch is defective or the heat element has gone bad, probably not cost effective to repair.
May 25, 2014 | Bosch sensixx TDA 8333 Iron
Low steam pressure
descale the heating elements with vinnegar.
Mar 20, 2014 | Rancilio Silvia Espresso Machine
Needs descaling, I don't have the manual, what is the procedure??
Hi Auto descale: To automatically descale your machine, press the scoop or menu button and hold it down until you enter the menu. Use the arrows on the to scroll up until you come to "Descale". Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and close the open the steam knob again. Let it quit on its own. Refill tank again and prime the machine and your ready. Exit "Descale mode and scroll down to "Reset descale", press the enter button and chose "Yes", then exit and your ready for the next time.
Jul 21, 2011 | Saeco Royal Professional Espresso Machine
1. Where is the lever located in the Saeco Incanto De Luxe located? 2. How do you decalcify the same same product? Thank you for your help
Hello Dolls36,
I understand you have two questions the lever question I assume you are taking about the steam lever. The second question is how do you descale the unit.
Lets answer the first question first. The steam lever is not a lever but a knob. The knob is located on the right side of the unit.
1. Put container under steam tube turn knob downward to open until you get steam
2. Once you get steam turn knob upward to close
3. Put item you want to steam under steam tube and open valve back up to steam
Now to answer the question about how to descale the Incanto De Leluxe. When you are ready to descale the machine follow these steps.
1. Hold down the "x" button for 5 seconds, the machine will tell you it is ready to descale
2. Remove the filter
3. Fill the water tank with your descaling solution
4. Insert a container under the steam tube and open the steam valve
5. The machine will display descaling and finished
6. Then it will prompt you to fill tank with clean water for rinsing.
7. Press the "x" button once tank is full
8. Place container under steam tub and turn knob to open steam tube
9. When finished press "x" button one more time to confirm done
10. Replace water filter and fill tank
I hope that I have answer you question as for question 1 I assumed that is what you were asking about. However, if that was not the right question please post back to this tread and I will be more than happy to answer the question that you specify.
Thank you for choosing FixYa.com
Justin
Mar 11, 2011 | Saeco INCANTO DELUXE Espresso Machine
How do you descale my Delonghi Magnifica?
10.3 DESCALING Due to the continuous heating of the water used to make the coffee, over time it is normal for the tubing inside the machine to fill with lime scale. When the light starts flashing (section 12 - point 5), it is time to descale the machine. NOTE: when the light switches on, the coffee maker can still be used to prepare coffee. Proceed as follows: • Empty the tank and pour in the contents of one bottle (125 ml) of DURGOL descaler plus one liter of water. For subsequent descaling operations, descaling solution can be purchased from authorized technical service centers. Note: Make sure splashes of descaler do not fall onto surfaces sensitive to acid such as marble, limestone and granite. • place a container with a minimum capacity of 34 oz. under the cappuccino frother (Fig. 3); • turn the machine on by pressing the button (Fig. 4). • wait for the green and indicator lights to come on steady. • press and hold the button for at least 5 seconds (Fig.14). The decalcification warning light will illuminate (section 11 - point 8) to indicated the start of the descaling program (the and lights remain off to indicate that it is not possible to make coffee). • turn the steam knob half a turn counter-clockwise (Fig.5). The descaling solution will come out of the cappuccino frother and start to fill the container underneath. • the descaling program automatically performs a series of deliveries and pauses, so as to remove the lime scale deposits from inside the coffee maker. Fig.32 The two red buttons have snapped out CORRECTLY The two red buttons have not snapped out CORRECT INCORRECT 17 OPERATING INSTRUCTIONS • after around 30 minutes, when the light comes on (section 12 - point 1), turn the steam knob half a turn clockwise (Fig.6) until it stops. The machine must be rinsed so as to eliminate the residues of descaling solution from inside the machine. Proceed as follows: • remove the water tank, rinse it and fill it with clean water. • reposition the tank. • empty the collection container (located under the milk frother) that is full of liquid, and then replace it under the milk frother. • turn the steam knob half a turn counter-clockwise (Fig. 5). Hot water will come out of the milk frother and fill the container underneath. • when the tank is empty, the l ight goes off and the light comes on (section 12 - point 1). • turn the steam knob all the way clockwise (Fig. 6) and fill the water tank with clean water again. • the program of descaling is now terminated and the machine is ready to make coffee again. NOTE: if the descaling procedure is interrupted before completion, the alarm (section 12 - point 5) is not deactivated and the procedure must be started again form the beginning.
Jul 14, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Cant remember how to de scale
Instructions per De'Longhi:
10.3 DESCALING
Due to the continuous heating of the water used to make the coffee, over time it is normal for the tubing inside the machine to fill with lime scale. When the light starts flashing, it is time to descale the machine.
Proceed as follows:
cappuccino frother;
• turn the machine on by pressing the button.
• press and hold the button for at least 5 seconds. The decalcification warning light will illuminate to indicated the start of the descaling program (the and lights remain off to indicate that it is not possible to make coffee).
• turn the steam knob half a turn counter-clockwise. The
• after around 30 minutes, when the light comes on, turn the steam knob half a turn clockwise until it stops.
• turn the steam knob half a turn counter-clockwise. Hot water will come out of the milk frother and fill the container underneath.
• when the tank is empty, the indicator light goes off and another light (looks like a pitcher pouring water) comes on.
• turn the steam knob all the way clockwise and fill the water
NOTE: if the descaling procedure is interrupted before completion, the alarm is not deactivated and the procedure
IMPORTANT: FAILURE TO DESCALE THE APPLIANCE REGULARLY INVALIDATES THE WARRANTY.
You can download the entire pdf manual from the De'Longhi website: http://www.delonghiusa.com/index.php?texts&pid=10&catid=1
Helpful tips:
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water or use abrasive cleaning products/scouring materials on any part of your espresso machine.
Jun 24, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Machine stuck in ventilate mode after aborted DESCALING. When descaling tripped circut breaker on the power circuit.
Hi
This means you probably have a leak inside. Usually the seals from not descaling enough. The steam boiler is over the power switch and will short the power switch. You can replace the seals in the steam boiler hoses, or tighten the fittings and probably save the machine, but change the water hardness setting in the menu to 4. This setting has saved many machines, but you mest descale your machine when it tells you. This also saves the machine.
Jan 21, 2010 | Saeco Royal Professional Espresso Machine
The red light for descaling won't go off after descaling
The button to push was the steam button and hold for 5 to 10 seconds until the light goes out.
Apr 22, 2009 | Saeco Magic De Luxe Espresso Machine
Solis Palazzo Descaling (?) Problem? Please Help!
Hi
He has the first part correct, but when you rinse the machine with fresh water the machine needs to quit on its own and you will know this when the descale light is off, but you will have a flashing green light and a steady red light over the water drop. Refill the water tank, the close the steam knob and then open it again. This will clear the red light and then the machine will start heating. IMPORTANT on any automatic machine is when the water tank is off the machine don't do anything with the beans. A chip of bean in the water receptacle can be a big problem for the machine.
Jan 28, 2009 | Solis Palazzo Espresso Machine
How do I descale the saeco magic deluxe coffee machine?
Try this:
Standard descaling
Switch off the machine.
Pour a descaling product into the water tank.
Switch the machine on to the programming mode(see below). Place a large container under the steam/hot water dispensing tube and open the steam/hot water knob slowly, turning it counterclockwise.
Turn on the machine by pressing the main switch and let the descaling product flow out of the dispensing tube for approx. 1 min.
Close the knob again.
Turn off the machine with the main switch and let the solution take effect for approx. 5 minutes.
Repeat this procedure two or three times, to allow all of the descaling product in the water tank to flow out of the dispensing tube.
As soon as descaling has been carried out, rinse the tank thoroughly and fill it with fresh water.
Switch on the machine and let fresh water (approx. 2 l) flow out of the steam/hot water dispensing tube in order to rinse away residue.
The machine is now ready for operation.
When the machine is on, the warning light switches off automatically, by pressing the steam selection button for at least 5 seconds.
To enter the programming mode, turn the machine
off with the main switch.
Press steam , espresso coffee and the
main switch at the same time.
Release the buttons.
Hope this will help you.
/Mirran
Aug 16, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Classico Espresso Machine Logo
198 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
Shehu Pro
Shehu Pro
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
