Question about Samsung YP-U3 MP3 Player
USB NOT RECOGNIZED
Hi, the ypu3 is working fine but when i plug it on the usb port samsung tmp3 tells me usb connecting but winxp tells me that the usb device is not recognized. I tried putting it on hold and pressing the 2 buttons on top( the one that has ´´play´´ and the other that has ´´user¨´ both at the same time) but nothing is happening. Does somebody know what am i doing wrong or if this has a solution?
  • 8 more comments
  • Anonymous Aug 24, 2008
    yes,i has same trouble.
  • paepae Aug 30, 2008
    wow it seems that alot of ppl are having the same problem i have to and cant seem to find any help!!! its just not registerin it when i plug it in the usb port >.<
  • Anonymous Oct 09, 2008
    Hi, the ypu3 is working fine but when i plug it on the usb port samsung tmp3 tells me usb connecting then it says disconected. We have everything installed but when the USB mp3 player is plugged into the usb port it does not come up at all.
  • Anonymous Dec 16, 2008
    i have a problem w/ that too
  • Anonymous Dec 28, 2008
    i hav the same pr0blem as y'll to0..at 1st it says disconnected and the day after that when i plug it to the usb p0rt,n0thing's p0p out..can't we just send it to Samsung to repair?by using a warranty?
  • Anonymous Jan 02, 2009
    same problem, connect to the USB but USB NOT RECOGNIZED .... any resolutions.....
  • Anonymous Jan 03, 2009
    Samsung YP-U3 Player is not reconized when pluged into the computer USB port, the Samsung Media Studio is on and opened
  • Anonymous Feb 07, 2009
    uuuuuhhhhhh i have the same prob it is sooo frustrating!
  • Vinsie1973 Feb 08, 2009
    Samsung studio media does not recognize the MP3 player after a few months of using. At the beginning no problems, but now there is no recognition anymore. Atre reinstalling new software still no cure. Can anyone help?
    Kind regards,
    Vincent Wessels
  • Anonymous Mar 01, 2009
    i have the same problem,.. i became frustrated about my U3 but one time i tried to plug it again, my laptop recognized it... i put all my songs at that moment...now, again my laptop doesnt recognized it...  i hope somebody at the samsung company myt help..                       stay COOL think +
    New Friend:
Boxer_10053 you are right !
People make sure when you plug it in THAT you look at you mp3 screen it goes 'usb connecting' hold it there with your figures untill it shows on your computer screen then slowly move away your hands from mp3.
Posted on Oct 28, 2009
Mp 3 ni gx bsa hidup sma skli....
pdhal gx ad ap2 kok lngsung mati sndri!!
trus ni gmn yia!!
n gx connect sma skli!!!
Posted on Dec 31, 2008
Actually i have the same one and it says that but i looked at where i plug it in to the computer and then it was broke when u plug it in u have to make sure its in the middle or else its gunna say not reconized but when u do this u can only upload 1 thing at a time,
Posted on Feb 09, 2009
SOURCE:
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
My adaptor is not recognized in my USB ports I installed the router and it completes all of its connection checks. I am trying to install the adaptor on a remote computer (in the basement) and that...
Here's what you can do since this is a USB wireless adapter, first connect the USB adapter on a different USB port on the computer better if you connect it on the back USB port of the computer tower and check if the computer will recognize it and if its recognize you can already continue with the software installation , but if not you can restart first the computer and check if the adapter will be recognized if still not the next thing to do here just to know if the adapter is good or bad is to connect it on a different computer and just to check if it will be recognized once its connected to a USB port , because a device should be automatically will be recognized by a computer once you connect it so if its still not recognized by a different computer adapter is bad...
Dec 15, 2009 | Computers & Internet
Samsung external hard drive not recognized
its happens when the hard drives cable or usb port is problem
change the ccable then try
other wise plug the pci usb card & first diseble the motherboards usb port
then try
ok bye..........................................
Nov 17, 2009 | Computers & Internet
Canon hv30 is't being recognized on my vista computer
You may have used a different USB port on the computer. Try a different one.
Generally, any USB port would work, except that some devices create a "Virtual USB" connection that is configured with a specific USB port.
Let us know if this helped...
Gort007
Sep 16, 2009 | Canon VIXIA HV30 DV Camcorder
Samsung sgh-j600v
hi im josh in cebu phils.may i help you?
Friend if not recognized by the pc im sure the problem is in the connection because XP O.S. auto detects usb.
To solve the problem:
1.Check the usb port of the computer you are using
2.Check the usb cable from your phone to pc be sure there is no cut.
3.Check the usb port of your phone so as the connection. and the setting be sure the usb is enable.
Good luck friend hope i helped you.
Mar 14, 2009 | Samsung SGH-J600 Cellular Phone
Kid tough digital camera
The camera has to plugged into a usb 1.1 port, it will not work with a usb 2.0 port. Try using the additional usb ports on a monitor or keyboard. Otherwise you will need to use a usb 1.1 Hub.
Jan 02, 2009 | Fisher-Price Kid Tough Digital Camera
USB DEvice not recognized
I had a problem like this -- tried plugging the camera in to the rear USB slots not the front ones and it worked fine.
I think that it doesn't like going via a USB hub, but wants a direct connection. All of the USB ports on my computer are connected direct to the motherboard (i.e. none are on PCI cards or anything), but looking at the hardware info for the computer, it looks like the motherboard has a few "direct" USB connections, and then an on-board hub which the front ports connect to. If your computers are the same, that would explain things. I'd suggest trying each USB port one at a time (turn the camera off before plugging in, and back on when in) and see if one of them works. Wouldn't hurt to power the camera from the mains at the time too.
Jan 01, 2009 | Video Cameras
Windows doesn's recognize camera, device manager says no driver
Hi -
Have you tried another USB port? Sometimes, they can act goofy.
Also be sure your anti-virus isn't blocking any part of the installation.
Here is a link to the Samsung troubleshooting guide for your camera.
You can probably download the most recent driver from that website as well.
Perhaps they have a better or newer version than what came prepackaged
with the camera (just because a camera is a new purchase does not mean
the software it came with is the most updated).
http://tinyurl.com/5zsvwd
I run WinXP home edition, so I am not familiar if there are any differences in the professional version regarding software installation....
Dec 17, 2008 | Samsung L100 Digital Camera
Samsung YP-U3 MP3 Player Logo
888 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
