Question about Lexmark Office Equipment & Supplies
CANNOT CHANGE INK CARTRIDGE,CARTRID GE IS ON FAR LEFT SIDE OF PRINTER SO THAT i DO NOT HAVE ACCESS TO IT. iT IS A MODEL 8300.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Lexmark Master
  • 1,362 Answers
Turn off machine, open and get a knife (or something flat) and put on top of the cartridge and push down, then try pulling to the middle.
The problem is that somehow the latch that holds the cartridges is open.
Posted on Aug 20, 2008
After 7 yrs, suddenly the ********* cartridge is not recognized, no red light, why?
HP Officejet Pro 8500 will not recognize changed ink cartrid ...
h30434.www3.hp.com > Printers, Copiers, Scanners and Fax > Inkjet
Laptops & Tablets Laptops & Tablets .... HP Officejet Pro 8500 will not recognizechanged ink cartridge ..... I have a hard time believing that something that worked just fine until it ran out of ink, suddenly has a broken sensor. It's barely 2 yrs old. ... show any ink, replaced them all and after 5 minutes of 'thinking', ..it worked.
Epson cannot recognise a cartridge:16 ways to solve the ...? 6:33https://www.youtube.com/watch?v=bc04OM9ZRXkNov 4, 2013 - Uploaded by viandant5The red ink light remains on after replacing an ink cartridge. - The printer is not recognising one or more ink cartridges. ... Via Beverara 224/7 ... Printer cartridges not detected - How to fix - Duration: 2:41. by Thriftyink 102,951 ...Epson inkjet printer rejecting printer cartridges
Dec 21, 2015 | Office Equipment & Supplies
HP 6700 printer change ink cartridge
http://images10.newegg.com/User-Manual/User_Manual_28-415-214.pdf
Open ink access door.
1. Make sure the printer is turned on. Never turn off the printer when ink cartridges are missing.
2. Open the ink cartridge access door. [This is the panel that is to the left of the touchscreen. To open, put your fingers on the upper left hand side of the panel (by the logo: HP OfficeJet 6700 Premium), You should be able to gently pull the panel so that it opens out.]
NOTE: Wait until the print carriage stops moving before proceeding.
3. Press the front of the ink cartridge to release it, and then remove it from the slot.
4. Remove the new ink cartridge from its packaging.
5. Using the color-coded letters for help, slide the ink cartridge into the empty slot until it is securely installed in the slot.
Replace the
Aug 18, 2012 | HP Officejet 6700 Premium E-All-In-One
HP 944 Photo all in one printer isnt recoginizing new ink cartrid
Very carefully using a clean duster, wipe the cartridge terminals/pickups
Nov 03, 2009 | Dell 962 Photo All-In-One InkJet Printer
How do you change the ink carterage in an hp officejet 5610v all-in-one?
Hello !
To change the ink cartridge(s) in your printer,
Open the print-carriage access door by pulling it forward.
The print carriage moves to the far right side of the HP All-in-One.
Remove the cartridge.
Take the new cartridge from the package.
Remove the strip from the cartridge without touching the metal back.
Insert the cartridge.
Hope this helps.
Oct 04, 2009 | HP Officejet 5610 All-In-One InkJet...
I am getting an error warning on my HP. "Error: left cartrid
Change the cartridge if this still persists with the old and new cartridges then its a hardware malfunction with the printer and so call in to hp
Jun 30, 2009 | HP PSC 2210 All-In-One InkJet Printer
Dell A920 cartridge stall error.
Hi, I HAD the same problem, but not anymore!! I just opened the top to expose the "inside of the printeri" and checked the long clear band at the rear behind the print head. Make sure that the clear ribbon is NOT TWISTED. There is a small metal bar with a small extended part on the far left interior of the printer. Just make sure that the slot on the clear band is fitted on that extended part. This will put the print head back "on track" This worked for me!!
May 30, 2009 | Dell A920 InkJet Printer
How to replace ink cartridge in canon pixma IP1800
make sure that the ink cartridge is in the docking posistion on far left hand side of printer. press down firmly on the cartridge and then slide it out.
Oct 06, 2008 | Universal Office Ink Tank Cartridge for...
I have a Lexmark color printer, I can't find where the ink goes in?
if it's a flatbed scanner model, the whole scanner assembly on the top is larger than the printer portion below. if you lift up on the front corner of the larger scanner assembly, you will see the ink cartridge carriage tucked under the left or right far side when the printer is not printing. power the printer on, lift up the scanner assembly, and wait for the ink cartridge carriage to move itself out from being tucked off to the side. you will see a clip on the front top corner for each cartridge. gently pull forwards (the clip) with your thumb, and the cover will pop open to take out the old cartridge.
ps. remember to take of the piece of tape that covers the jet nozzels on the new cartridge before inserting cartridge into carriage.
Sep 26, 2008 | Lexmark Office Equipment & Supplies
Can't find ink levels on my printer
I just had this same problem on my Deskjet 5550 printer. The orange light (ink indicator) was staying on. I found out that all you need to do is just open the front cover to the printer. If your printer is running out of ink, the print cradle will move to either the far left or far right side. If it moves to the far left side, the BLACK cartridge is low or empty and should be replaced. If the print cradle stays on the far right side, the COLOR cartridge should be replaced. Normally, when you open the front cover, the print cradle should move to the center. Hope this helps!
Aug 11, 2008 | HP DeskJet 5550 InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
