Question about Electrolux Dishwashers
I need to replace my Frigidaire dishwasher detergent/rinse dispenser part number 154574401. How do I remove the old dispenser from the door? Are there screws or does it simply pop out of the door?
  • 5,911 Answers
The dispenser is usually mounted by a series of screws from the INSIDE of the door panel. You need to turn the breaker off to the dishwasher, open the door, and remove the inside door panel to access the dispenser. There also should be a couple of electric connectors going to the dispenser motor. Use care not to pull the wires when removing the panel. HINT: If your dishwasher is like most dishwashers, the door will try to close on you from the tension of the door springs. You can disconnect the door springs, which may require unmounting the dishwasher from its under-counter position, or you can make this process easier, by finding something to prop the door open with. I usually use a thick dowel rod, or cut off broom handle to prop the door open against the cabinet. I hope this helps you. If you need further assistance, please let me know.
PS For future reference, please post your complete model number when submitting questions about your applainces. This makes the process of assisting you much easier as all makes and models are NOT made the same.
Posted on Aug 20, 2008
Top draw is stuck on rinse / can't move push button to go on anything else
make this tests and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Jul 24, 2013 | Fisher and Paykel DD605FD Stainless Steel...
How much salt do I put in ,,, and why won't it
follow this steps and fix it. God bless you
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Jul 08, 2013 | Dishwashers
Dtergent dispencer does not open
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
Dishwasher suds up and leaks during wash
Suds in a dishwasher usually come from using too much soap or the wrong kind. Soap can build up over times causing problems. First start a cycle.Do not add detergent or any dishes.When it starts washing, pour a cup of vegetable oil directly into the tub. This will cut the existing soap suds. You may need to try this a couple time before the dishwasher will drain. After all suds have been removed, load you dishwasher and start a cycle filling the detergent cup up half way. If it goes through the cycle with no problems, you should be all set. Still have the problem? A rinse aid dispenser that dispenses too much rinse aid will also cause the dishwasher to suds up. You can remove the dispenser from the door, flush it out and reinstall. Make sure you turn the circuit breaker off before taking the door apart. After rinsing it out, do not add rinse aid. Try the dishwasher and see if the problem goes away. I've seen people accidentally put liquid dish detergent in dispensers too. A dishwasher that has suds is apt to leak. Fix your suds issue and you most likely will fix you leak
Dec 27, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
There is still soap running down from the dispenser after each cycle.
Hello creativee798 - If you put regular dish soap in the dispenser, then you could encounter oversudsing and leaking through the door. Here are some tips for minimizing and maybe even eliminating the sudsing problem:
If you have a turkey flavor injector, you may be able to use this item to **** the detergent out of the rinse aid dispenser. Open the dishwasher door and fill the dispenser with water and then **** the liquid out with the injector. You may also be able to use a syringe without a needle that is used to dispense liquid medicine for a child or baby. If you alternate filling the dispenser with water and then removing the liquid, you will eventually dilute or eliminate the detergent that was in the rinse aid dispenser. Once you dilute or eliminate the detergent, fill the dispenser with water. Set the dispenser on the highest setting and run a cycle to see if you see excessive suds during the final rinse cycle. If you don't see a suds problem at the end of the washer cycle, then I recommend taking as much of the water out of the rinse aid dispenser as possible and filling it up with rinse aid and then returning the dispenser to the normal setting that is appropriate for your water hardness. If you are seeing excessive sudsing, then you may need to try to flush the dispenser with the fill and drain routine again. You may need to change the setting to the minimum and see if you detect a suds problem. If not, then allow the dispenser to empty at the minimum setting and then fill it with rinse aid after it is empty. I don't recommend using the heated dry until this problem is completely resolved. This could cause residue to dry on the dishes. If you detect residue on the dishes after the cycle is finished, you may need to wipe the dishes off as you remove them. Excessive suds and possibly residue on dishes would be the only consequence of this mistake. The excessive suds could cause leaking out of the front of the dishwasher door if it is severe enough. The dishwasher may not drain properly if excessive suds are present. The above tips should help you minimize or eliminate these consequences, if any proves to be ineffective contact a professional to move forward accurately.
Dec 02, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire d. w. grit and white film on glasses
Good Morning Friend,
I see that you are receiving grit and a white film on your glasses, in your Frigidaire dishwasher, model# FDB1050REC. Here are some common solutions that you can begin with.
-Check your water hardness. Hard water can cause lime deposit buildup on the interior of the dishwasher. Dishes and glasses may also get spots and film for a number of reasons. To remove buildup, spots and film, clean using the following instructions:
1. Load clean dishes and glasses in a normal manner. Do not load any metal utensils or silverware.
2. Do not add detergent.
3. Select the NORMAL WASH cycle. Close and latch door. Press START/CANCEL pad.
4. Allow your dishwasher to run until it starts the second water fill (approximately 10 minutes).
5. Unlatch and open the door, and pour 2 cups of white vinegar into the bottom of dishwasher.
6. Close and latch the door and allow the cycle to finish.
For extremely hard water, it may be necessary to install a water softener.
-Your water temperature may be low. Avoid extremely low or high temperatures.
-Avoid overloading and improper loading.
-Make sure you are using fresh detergent. Old detergent is ineffective.
-Make sure your rinse aid dispenser is filled.
-Check to see that the proper amount of detergent is being used for cycle selected.
-Your home water pressure may be too low-it should be 20 to 120 pounds per square inch (psi).
If none of these suggestions helps, I would suggest contacting either the manufacturer or a local authorized technician. Hope this helps.
-Best Regards-
WP
Feb 16, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Glasses have a film when dishwasher is done.
There are several things that could cause this; 1. The rinse agent dispenser is out of rinse agent(Jet Dry). 2. The dispenser is not working and is easy to replace by removing the four screws that hold the door panel on and the two that removes the dispenser(be sure the breaker is turned-off). 3. The water temperature coming into the unit from the water-heater is not hot enough. 4.Your water may need to be tested for excessive minerals or chemicals. 5. Low grade detergent may not dissolve correctly.
Jul 28, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Detergent dispenser replacement
The front door panel can be removed from the stainless steel inner panel to get to the rear side of the dispenser.open the door & there will be screws along the side.the panel should come away exposing the rear of the dispenser wich then can be undone & replaced.
Jun 04, 2010 | Frigidaire 24 in. GLD3450RD Built-in...
Won't dispense dishwashing detergent
There is a recall on these that has to do with the rinse dispenser and fires. Go to the manufacturer's site with model and serial number to see if yours is recalled. Rinse agent drips on the wiring inside the door and can cause a fire.
Apr 13, 2009 | Maytag 24 in. MDB4000 Built-in Dishwasher
Dishwashers Logo
285 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
