Question about Sony KDS-R60XBR1 60" Projection HDTV
What do i do if my sony sxrd power light starts blinking red
  • 597 Answers
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly
Posted on Jun 17, 2011
5 Suggested Answers
SOURCE:
SOURCE: sony sxrd 60 in, won't power up--blinking red light 5 times
You need to replace your bulb. Order a replacement online---it's easy to swap and the instructions are in your manual. If you purchase one from a local dealer you will pay over $150 more!!!
Posted on Mar 01, 2009
tvtechnician
  • 105 Answers
SOURCE: sony sxrd kds-r69xbr1
4 red blinks indicates a fan error. usually blowing duster inside the fan blades will cure this. there are 4 fans inside this tv. looking from the back of the tv, the large fan on the left side is usually the culprit...good luck to ya
Posted on Oct 25, 2007
  • 6 Answers
SOURCE: Sony SXRD (KDS-R50XBR1) fan question
there are 2 more fans, 1 is in the middle of the base housing, 2 screws, should be clean. the other is on the left behind the circuit board in a black housing. This fan when i removed it was CAKED with dust and there is no way it could have had any effect on air circulation. the fan is inclosed and you have to take out the whole circuit board to get to it.
Posted on Jun 06, 2009
  • 195 Answers
SOURCE: My SXRD 60
Perhaps it needs the bulb, but there is also a good possibility that the lamp fan is getting clogged and shutting down the set. This is NOT the fan you see in the back, instead, it is above the lamp, and is a small blower-type fan, that tends to clog with dust. You CAN check this, when you open the lamp door,you can see the blower wheel, and if it is all dusty, it needs to be cleaned out--but do NOT just blow it out, or you might clog the engine!! It needs to be removed, and cleaned out of the set.
But first...if the blower is not too dirty...try another lamp.
Posted on Oct 10, 2009
I have a sony SXRD television, and it has five blink red lights, what should I do to fix it?
99% of the time a 5 blink is your Lamp Driver (Ballast). If that does not fix, then it is either your lamp or the power board. Part# for the lamp driver is 147401221.
Apr 19, 2012 | Sony KDS-70R2000 70" SXRD TV
On my 50" sony sxrd
The service manual lists 3 blinks as the light cover not being secure. it has a micro switch behind the cover so if you hold down the switch you can see if this is the problem.
Apr 16, 2011 | Sony KDS-R50XBR1 50" HDTV
Sony SXRD KDS-50A2000 Will not power on. Green
I have the same problem with my unit. I've been removing the bulb and just replace it back and unit will work again. I probably need to vacuum or check the fan out too.
Mar 09, 2010 | Sony KDS-50A2000 50" HDTV
60" Sony SXRD that won't turn on
Sounds like the line output transformer (flyback transformer) has gone out.Depending on how old the TV is will depend on if it is worth fixing
Nov 14, 2009 | Sony Televison & Video
No picture or sound
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
Jul 25, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
TV Wont turn on - Red Blinking Light under Lamp
The lamp is shot. Port is on the right side of set - just remove and take a look. Check VISA limit.
Mar 16, 2009 | Sony XL5300 Replacement Lamp for XBR2 SXRD...
Sony sxrd 60 in, won't power up--blinking red light 5 times
Feb 25, 2009 | Sony KDS-R50XBR1 50" HDTV
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Sony KDS-R60XBR1 60" Projection HDTV Logo
662 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
