Question about Saitek ST290 Joystick
Saitek st290 Lube
Hi, i have a question concerning the use of oils/lube to grease up the joystick to smoothen it out. Is this possible, if so, does the oil matter?
    Problem Solver:
  • 18 Answers
I'm going to assume that you're refering to the central spring slider on the stick. The spring follower at the base has to slide up and down the shaft to provide spring pressure as the stick moves away from center. This plastic follower has a tendancy to gall the plasic it slides over on the stick shaft resulting in jerky stick movement. You can solve this problem with any wax based lubricant. I used a chapstick, but there are sprayable wax lubes that would be easier to apply, you can find them at hardware stores. Be careful with oils. Plastics are made from oil and the wrong ones will disolve it. WD-40 is a safe oil but use it sparingly and only on the shaft. Avoid using penetrating or cutting oils, they will disolve the plastic. You should test any oil on a foam coffee cup.
The stick's internal gimbals are already well greased and don't need relubed and the throttle is supposed to be a little stiff. I've had good results with both WD-40 and waxes. The waxes are a little harder to apply but last much longer
Posted on Dec 19, 2008
  • 44 Answers
I believe that the writer is referring to the actual rotating ball and cover sleeve assembly. I am having the same issues with a grinding sound and the smooth action is going away in certain directions. Will try the chap stick solution first...... sounds reasonable...... was considering petroleum jelly but the plastic/oil issue was in mind. Got some silicone gas stopcock valve grease but there is a disagreement in silicone and black rubber which is partially oil based so maybe the chap stick can provide a solution.
Will lift the spring and "slider" up for access to the ball assembly and try daubing on with a q-tip to the ball assembly itself.
IO mention the ball assembly because I have just disassembled the entire unit and found dry areas on the plastic-plastic sections...
Posted on Apr 27, 2010
SOURCE:
Trigger button on Saitek ST290 is stuck in fire position
I've disassembled the ST290 to get at it's internals. It wasn't easy. It's not something I would recommend and finding the exact same lever switch to replace the damaged one would be tricky, not to mention soldering in the new switch and all.
I have seen the ST290 at Radio Shack stores for less than $20. You might be less frustrated just getting a new one.
May 27, 2008 | Saitek ST290 Joystick
XP Pro doesn't recognize the ST290
You do. I had absolutly no problem with it when i jad windows.
Mar 20, 2008 | Saitek ST290 Joystick
Not working help
joypad doesn`t work well ob fifa 09
Jan 19, 2008 | Saitek ST290 Joystick
I need a manual for your Saitek ST290 Joyhstick; can you supply one to print?
you can get a free manual :
you have to log on to www.saitek.com and have to become free member by providing your general info. like email id thats all . you will get any manual for free.
Dec 28, 2007 | Saitek ST290 Joystick
SAITEK ST290 JOYSTICK USB disc
you can download from www.drivers.softpedia.com for free.
yes it is compatible with vista.
you may try for: www.opendrivers.com
Nov 25, 2007 | Saitek ST290 Joystick
Games
You should be able to play any game out there, if you are unable you may need to update your drivers. Hope this helps:) Jason
Sep 04, 2007 | Saitek ST290 Joystick
Saitek ST290 Joystick Logo
405 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Peter Dragonetti
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
