Question about RCA HD52W59 HDTV Projection Television
Hd52w67 my rca hd52w67 will not turn on. I bought it brand new, and use it for maybe 3 months and after that I put it in storage for a long while. I have it out of staorage and when I plugged it up, and push the power button, it illuminates for about ten seconds and goes off. When I try to push the button again, it wont power until after 30 seconds and then the power light comes on, and repeat, but it never comes on. What seems to be the problem?
  • 1 more comment
  • ccraigmorris Feb 06, 2009
    I have same problem, an RCA hd52w67 that cut off and won't cut back on, though the gn power indicator light will remain on about 5 sec, then click off. Has any one found a solution? What about the "reset button" solution that someone mentioned? Where is the button and does it solve the problem?
    I have same problem, rca hd52w67 cut itself off, and now powers off 5 sec after power on, before picture appears. Anyone know if this is a common problem what the problem is and how to fix it?
  • gabe one Feb 06, 2009
    I have the same problem,(except my monitor number: D52W23) I've had my HD monitor for a few years. I put it storage for a few months, and now it worked for about a week, and when I try to turn it on: the light comes on for a few seconds then shuts off, then back on for a few seconds, then shut off permantly. If I wait a fw days it stays on for a few minutes, then same thing. When it works for a few minutes, it works well.
No! The solution wasnt helpful. It wasnt the problem you said that it was. I took off the back cover, and push the reset button and it came on. Thanks anyway.
Posted on Aug 21, 2008
SOURCE:
I have rca tv model#hd52w67 when i turn it on the power light blinks on & off about three times then cuts off
This is what RCA (Thompson) calls the three strikes and you are out.
If a problem: set will attempt to turn on 3 times and then go into shutdown which indicates a short somewhere.
It will require a shop repair as this set is not usually repairable in the home.
Let me know if you have questions.
Feb 26, 2012 | RCA Televison & Video
Hdtv wont turn on
moisture might be the problem check circuit board
Aug 20, 2008 | RCA HD52W66 Projection Television
RCA hd52w67 analog convergence problem.
with Tv off press and hold ch- and vol- at same time untill tv turns on then release and you should be in factory settings service mode.
May 26, 2010 | Televison & Video
I have an RCA HD52W67 and it just started to have
I'm having the same problem with my RCA HD52W67 rear projection TV and I've notice this problem is listed with my other owners of this product. I have no experience with fixing electronics. Sould I try this myself or take it to an expert? Has anyone fixed this problem? What is an estimated cost involved, if I take my set to an expert? Any advice with the HD52W67 is great appreciated.
Mar 19, 2010 | RCA HD52W59 HDTV Projection Television
Bought a fairly used 2003 HDTV 4 months ago, Didnt come with remote but got a Universal I used that worked, my friend took the batteries out for a while for something else, we put the batteries back in...
Hard to say what the code is without knowing the model number of the remote and the brand of TV.
RCA's website has a remote code finder you can use.
Dec 17, 2008 | RCA Universal Remote 3 Device Remote...
Rca hd52w67
the ignition panel ve been coruptted
replace it
dont forhet to rate me!!
Aug 19, 2008 | RCA HD52W59 HDTV Projection Television
HDTV R52WH74 TV WILL NO TURN ON
I would contact RCA support, and they should be able to provide you with the authorized RCA service centers in your area.This is the RCA customer Service number 580-634-0151
Jul 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My HD52W67 has concaved picture
This is a convergence problem and can be repaired relatively easily. If you can solder, you can fix this yourself. First try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heat sink and should be marked STKxxx.
Keep us posted.
Dan
Jun 25, 2008 | RCA HD52W66 Projection Television
MY TV WONT WORK, I NEED A NUMBER FOR RCA. IT IS ONLY 5 MONTHS OLD, BOUGHT BRAND NEW, NOW IT WON'T TURN ON
Did you buy the walmart special,the ones they had on sale for 780.00, RCA has produce a nightmare these sets have all kind of problems.
Jun 12, 2008 | RCA Televison & Video
RCA HD52W67 Projection TV
open it up and you will see the burn marks pull the board and re solder it the hole in the board
Feb 23, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
406 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
