Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
Maytag refrigerator model # MTB1956GEQ
Water is pooling daily on the top shelf of the fridge section yet the walls are dry and nothing appears to be leaking from the freezer. The thermostats of both fridge and freezer sections are working and both sections are cold enough. We can not see where the water is coming from.
  • 1073 Answers
SOURCE: sears refrigerator
stopped up drain in the freezer remove back freezer panel and
unthaw the drain pan and the tube, the tube connects to the bottom of the metal pan, you will see a hole about the size of a dime direct the heat from the hair dryer at this hole it may take 20 min, to thaw
pour some water down the hole if it is clear of the ice the water will run to the drain pan at the bottom of the ref
if it does not keep thawing until it does
Posted on Apr 17, 2008
  • 66 Answers
SOURCE: the refrigerator section is freezing. the temp adjust is at 1
This could be the actuator is not closing the door that controls how much cold air from the freezer is ciculated into the fresh food section. It could be something broken or there could be ice biuldup on the door itself, not allowing the door to open or close.
Posted on Nov 12, 2008
rpbuice
  • 161 Answers
SOURCE: Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Posted on Jan 12, 2009
SOURCE: Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
Posted on Mar 23, 2009
bobicehouse
  • 1524 Answers
SOURCE: top of the freezer not freezing
SealedSystem problem. You need a "Certified Technician".
Posted on Apr 26, 2009
Water pooling on top shelf in refrigerator with top freezer
Your drain is obstructed within the freezer compartment causing the water to floe into to lower section via vent ducts. To correct this, you will need to access the rear wall of the freezer and at the bottom you will find the drain hole. Remove the obstruction with warm water and remove all the ice also.
Good Luck
Mar 06, 2016 | Refrigerators
How do I reset fridge model #106.51132210 it drips water from top and freezes on top shelf of fridge side
I'm not sure if resetting will help, but the easiest way is to just flip the breaker off and then back on.
Dec 04, 2014 | Refrigerators
Whirlpool, water puddles on top shelf of fridge
If it is not from a plugged or misaligned defrost drain tube, then it is always from air leaking into your refer section. Check you door gasket to see if it is sealing correctly all around your door. Make sure your door is shutting tightly every time. Good Luck, Appliance Specialists.
Jan 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a top freezer Maytag refrigerator. Water condenses on the "ceiling" of the refrigerator section enough to drop onto the top shelf and form small puddles. Otherwise, the refrigerator seems to keep...
first make sure the door of your fridg is closed very good, check in your freezer behind the back wall that the drain is clean and water can flow down.
Dec 29, 2009 | Refrigerators
Everything in my frig is frozen
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .. I don't know what he was doing with the putty unless he was stopping up the vent which won't work because you have to have the air circulation for the fridge section to work. The fridge temp control may be the problem.
Aug 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
We have a Maytag Fridge model: MTB1956GE and the top freezer is not keeping food frozen, however the bottom fridge is working fine. In addition small pools of water have been cleaned up from under the...
Your defrost system consists of the timer, heater and thermostat. Your problem could be any of these. But because your fan doesn't turn off it is more than likely the timer. https://www.searspartsdirect.com/model-number/MTB1956GEW/3048/0166000.html
Oct 31, 2017 | Maytag Refrigerators
Refrigerators Logo
64 people viewed this question
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
