Question about Samsung HLM507W 50" Rear Projection HDTV
HLN507W Samsung 50" DLP
There are green lines that come and go on my TV. Sometimes they are isolated to covering certain colors and other times are all over the screen. Then, sometimes the picture looks perfect. Any suggestions as to what could be causng this?
  • karlaandwil Dec 27, 2008
    Hi, we have a similar problem with our TV. We've found that when we turn it off for about an hour then turn it back on, the green disappears BUT reappears after about 30 minutes of watching. Can I ask was the solution offered helpful with your problem??? Thank you.
    Scholar:
  • 167 Answers
Hello yes it sound's like your fly back transformer is going bad. to me.!!! just have to wait and see. wont take long if it's doing what you say. "hope this help's you "good luck"
Posted on Aug 20, 2008
SOURCE:
Green Lines on Samsung DLP
Either bad capcitors, or (if you're lucky) the color wheel needs lubed up. Probably bad caps.
Jun 12, 2012 | Samsung Televison & Video
I have a 50" Phillips
Check ur owner manual or call Philip support Tech. ask it this tv model have a colors wheel design into it tv.Not sure for a Philip model tv 50" DLP tv,but the Samsung model 50" DLP tv this problems alway causes by a dying colors wheel that design into it tv.Which the colors wheel it is warp worn out and spinning off of it motor mount axis to cause grinding noises and tv colors to mess up and flashes or have flashes Black & White within it picture.
Jun 07, 2011 | Philips 50PL9126D/37B 50" DLP TV
I took my Samsung HLN507W apart to replace the color wheel fan... is there a schematic somewhere in the TV or online so I can now put it back together?
You Tube have video by somebody take out the old colors wheel and steps by steps and a replacement of a new colors wheel put into the DLP tv.
May 08, 2011 | Samsung HLN507 50" Rear Projection...
Samsung DLP TV shows green color where color should be black
This could be your video board going bad where your input cables are connected --OR-- the color wheel going bad. Hard to tell without a photo or reference though. Try swapping the cables first... and listen for any winding or whirring sounds.
Feb 04, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Buzzing noise
COLOR WHEEL OR COOLING FANS
Mar 28, 2009 | Samsung HLN507 50" Rear Projection...
HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Mar 13, 2009 | Samsung DLP HL-P5663W 56" TV
SAMSUNG DLP TV HLR5067W
The main board is more than likely the cause of the trouble. Time for a new TV.
Oct 29, 2017 | Samsung DLP HL-P4663W 46" Rear Projection...
MY Samsung DLP TV Has Green/Purple Lines
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Jan 08, 2008 | Samsung DLP HL-P5663W 56" TV
Open Questions:
Samsung HLM507W will not turn on Alright so here's the deal....I got this TV for free from a guy on craigslist. He said he couldnt get it to turn on. He replaced the lamp, it still didn't work, so he gave up and now I have it. First thing I did was try and turn it on... The TV powered up for about 5 seconds, and then the screen started to flicker all kinds of crazy colors, and it shutdown shortly after with all 3 lights blinking. I figured this probably has to do with the color wheel, so I bought a new one and popped it in. Once installed, the TV started right up, and worked for the entire duration of it being on (approx 7 hours). Now it will not turn on. Here's the startup sequence: -Push power -A couple of audible clicks, and both cooling fans energize. -Lamp does not turn on, and after about 45 seconds of having just the fans running, the TV cycles off and tries to power itself back on. -Rinse and repeat about 3 times total. -After the 3rd attempt, the TV shuts down completely and all 3 lights start blinking in front. -Pushing power does not do anything with the 3 lights blinking. TV must be unplugged and pplugged back in before sequence can be attempted again. Looking for a possible solution/troubleshoot technique. Checked the fuses and they are fine, triple checked all of the connections. Seeing as the lamp doesnt even attempt to energize, Im thinking it could be the ballast, but I'm trying not to dump money into something that might not fix the problem. Thanks for your help!
Jan 21, 2013 | Samsung HLM507W 50" Rear Projection HDTV
Samsung HLM507W 50" Rear Projection HDTV Logo
257 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
