Question about Samsung HCJ652W 65" Rear Projection Television
Display blacks out
Our HCJ652W 65in. Samsung rear projection tv has a problem with the picture blacking out randomly and the display just shows "Video 2" on the screen. If we jump on the floor or smack the side of the tv it will pop back on. Any ideas on what could cause this would be appreciated.
  • 125 Answers
There are for sure cold solders on the module you will need a solder iron and some expertise resoldering
Posted on Aug 20, 2008
Is it worth repairing?
that consideration can be made after you have the problem properly diagnosed by a service technician and get the quote
Nov 19, 2015 | Samsung HL72A650 Rear Projection TV, 72 -...
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV display is black; audio works fine. If I turn TV off and then back on the picture does display for a few seconds but then...
The backlight inverter which is also part of the power supply needs to be replaced. If you feel comfortable you can replace the blown capacitors on it.
Feb 10, 2018 | Televison & Video
TV MADE A LOUD "POP" NOSIE AND THEN SCREEN WENT
Hell k_sopata
If the display isn't working and according to the conditions you described yes it is the picture tube. You could contact Samsung and get a replacement for it.
Jan 10, 2011 | Samsung PCJ522R 52" Rear Projection...
Mitsubishi rearTV has intermittent wavy lines running throughout
Do you have anything to test it in 1080i? Does it do it on all connections or just one? I had a similar problem with my TV that turned out to be a bad input board. Mine would only display 1080i through the Component connections. All others would show pink and green wavy lines. It cost me around 500 to fix it. Unplug the TV. Remove the back cover for the TV. Using a NON-metal object, or gloves, wiggle the input board (that has all the video connections on it) slowly back and forth and see if the problem comes and goes. You will have to have someone watching for you. If something is loose on that board, the problem should show itself. Narrowing down the problem will probably save you money on repair bills.
May 13, 2010 | Mitsubishi WS-65809 65" Rear Projection...
My samsung dlp 6163 display suddenly changed to B&W
Bad Color Wheel!!!!! Call Encompass for Part 1-800-638-3328 if out of stock call Mats 1-800-628-1118 Just looked it up encompass is out of them right now part # BP96-00674A Listed for 129.69 Go to E-Bay Lots of good deals for TV parts. E-Bay has 4 prices range from 122.00- $149.00
Sep 29, 2009 | Samsung HLP6163W 61" Rear Projection...
I have mitsibishi projection tv. the screen black shows 1/2 black and sometimes all sreen black . can u help?
Could be something as simple as a defective lamp to a more complex problem related to video display or mirror/color wheel problems. Check other inputs (DVD, etc) first to be sure the problem is consistent across all input types. Have you tried "resetting' the tv or plugging it out. then wait. then plug back in and go thru setup again.
Jul 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Samsung HL-R4667W black screen, display says "Lamp"
it means you need to replace a lamp when it says that
Jan 30, 2009 | Samsung HLN5065W 50" Rear Projection...
Not Supported Mode
Sound as if the digital board has failed, Samsung p/n# Bp94-00385a
Bill
Apr 02, 2008 | Samsung HLN5065W 50" Rear Projection...
Only picture in picture works
Your pip module has went south.The capicitators on the board have leaked and ruined the board.Agood tv repair man can bypass the module to get you a full screen picture again.The only problem is you will no longer have pip ability.
Mar 07, 2008 | Sony KP-48S75 48" Rear Projection...
HCM4215W 42 in. Rear Projection Television
When the screen goes blank, hit any remote function that will show up on the screen-like volume bar. If the display is missing as well, then you have a tv problem. If the volume display is there when the tv picture is not, you may require a software upgrade.
Mar 06, 2008 | Samsung HCM4215W 42" Rear Projection...
Samsung HCJ652W 65" Rear Projection Television Logo
43 people viewed this question
Henry  Thomas
Henry Thomas
