Question about Avanti EWC28 Wine Cooler
Avanti WC330DZB Dual Zone Wine Chiller
Moisture builds in the upper and lower zones and eventually turns to ice. The gaskets look good and I used a hair drier on them just in case. What is causing this? How is the moisture getting into the sealed chambers?
  • 1314 Answers
SOURCE: Avanti EWC28 Wine Cooler TOO Cool
contact avanti cust svc they are easy to work with and want you happy tell them your promb but i suspect you need a new themostat
Posted on Jan 01, 2008
  • 1314 Answers
SOURCE: where do I locate the
look in the bottom in the back if you dont have a manuel go here
Posted on Mar 19, 2008
  • 358 Answers
SOURCE: Oil appears to be leaking from my Avanti Wine
Is it cooling ok?Where did you find the oil? If is not cooling and you see an oil spot inside or outside where the compresor is that means there's a refrigerant leak.
Posted on May 02, 2009
57 varieties
  • 1653 Answers
SOURCE: I have Vinotemp wine chiller model number
It will either be the thermal resistor or the controller of which the electronic thermostat is a part and yes it can be repaired. It is a reasonably common and cheap fault to repair. If you go to the following link you can get the service manual FOC
and you can contact a repair company via Vinotemp at the following link
Posted on Nov 07, 2009
I have the same E4 problem. You can order the PCB from Avanti at Miami Florida or your regional Avanti service rep.
Posted on Dec 16, 2009
Danby DWC2121BLS dual commpartment wine cooler is cooling normally but after 2 days aprox the temperature increase and beeping and flashing hi
If evaporator starts to freeze up the ice accumulated serves as an insulator and the temps go up. If you turn it off and let ice buildup melt the unit will work fine again until it refreezes.
Check if unit has a device to prevent ice build up. If so, it is not working. If warm moist air is entering the area of evaporator coil, that could also be causing the buildup.
Sep 26, 2016 | Danby Silhouette Dual Zone DWBC14BLS 13.90...
Will not cool to correct temperature as set
check the air exchange under and at back of unit if its to hot or dusty will effect how unit preforms if good and clear possible thermostat or motherboard circuit last would be low on freon
Aug 16, 2016 | Whirlpool 22" Dual Zone 38 Bottle Wine...
The left side exterior gets too hot to touch at times,is this normal?
Yes it can get quite hot, remember there is a compressor running in there.
Aug 15, 2016 | Whirlpool 22" Dual Zone 38 Bottle Wine...
Beeping at times?
Temp OK !?? door shut all the way !?? any obstruction preventing door from sealing ?? is unit Level ??
Mar 15, 2015 | Koolatron WC18 18 Bottle Dual Zone Wine...
Avanti dual zone 28 bottle wine refrigerator doesn't cool any more. How do I fix this?
HVAC ,repair man ,,can ck Refrigerant level ,,might need a shot of Freon
Mar 15, 2015 | Avanti Refrigerators
Bottom level of wine cooler frosted up. Trying to defrost. What is the problem?
It sounds like your thermostat is set to low, if there is a fan check it. That can also happen for a while before it quits working if there is a refrigrent leak.
Jan 11, 2015 | Whirlpool 22" Dual Zone 38 Bottle Wine...
Haier Dual Zone Wine Chiller - One Fan wont run
I have the same problem. When I first discovered this, both fans had stopped working and the temp for both zones was over 80. So much for the wine that had been stored there. After leaving the unit unplugged for a few days, the fan for the lower section started working again but the upper fan is still overheating. Haier customer service says too bad, so sad (I discovered this problem in the 13th month of ownership). I'm sure it is not worthwhile to fix this so it is going out with the trash and I'll look for a different brand for the next wine cellar that I purchase. Any ideas?
Mar 01, 2009 | Refrigerators
Avanti EWC28 Wine Cooler Logo
90 people viewed this question
Top Avanti Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Avanti Furniture Expert? Answer questions, earn points and help others
