Question about Cameras
Curtain on my Mamiya 645AFD is permantly closed
  • John O'Meara Aug 20, 2008
    the curtain on my Mamiya 645AFD is closed . I can open it with my finger but it closes again when i release. i cannot see anything through the viewfinder nor can i get the slide out of the camera
    Master:
  • 623 Answers
Manual for your cam
www.mamiya.nl/client/mamiya/uploads/downloads/645afinstr.pdf
Posted on Aug 20, 2008
    Master:
  • 521 Answers
  • Cameras Master
  • 19,396 Answers
Try helping the shutter with your fingr nail while you turn camera on.
  • Ginko
    Ginko Aug 20, 2008
    This often happens because of a problems with lens gear, like dirt or dust inside.
    Start trying to remove battery for one minute, to reset camera, as it can be a problem with electronics
    Then try helping the curtain to open using your finger nail while you turn camera on.
    If this still does not work, then the lens barrel must be taken apart and re assembled.
    In this case take camera to a camera repair shop near to you or call the repair service phone number printed on your user manual.
  • Ginko
    Ginko Aug 20, 2008
    Ensure first that camera is in shutting mode, otherwise curtain closing back is normal.
    Also perform the battery reset as suggested, keeping batteries out for a longer time (one hour should be enough).
    If it keep closing back when you force it, then there is a problem with the spring that keeps the curtain opened.
    Only way to fix this it is usually taking apart the lens barrel and fixing the mechanic fault by re mounting lens correctly or removing dirt inside. Unless you did same maintenance before, I strongly reccomend taking the camera for repair, you can damage camera further if you do not have enough know how.
Shutter Curtain Doesnt Reset Mirror
If your shutter curtain doesnt close, it may be out of Sync with the shutter button. My Minolta x700 had this problem. My camera guy fixed it for me with a couple of tinker moves. Contact your nearest camera repair shop (if available) and ask how much it would be to fix the Sync between depressing the shutter button and the curtain. it may just be some grime that has it stuck.
Mar 18, 2014 | Minolta X-700 35mm SLR Camera
Is it ok to use a curtain as a room divider?
You can use a curtain as a room divider but I don't recommend itbecause curtains collect dust. Also,room dividers are a great way to make a small room feel bigger where arecurtains just close the room off.
May 29, 2012 | Furniture
Light leakage detected from my second hand PRO TL especially at low shutter speed (<1/15 sec). Details are as follows: a) appeared at lower third of a frame; b) spread out evenly from 3 points lying...
It sounds like the aux. curtain that covers the film when you're focusing either is not properly lowering, or is damaged somehow. You can remove the back and look through to see if you notice any light coming through. If you do, consult a tech. You'd only notice it on frames because mid-frames wouldn't remain in the light path long enough to be affected under most circumstances. It'd likely be a tear/nick in the curtain. Or, it could just not be completely be closing.
It could also be an issue with bad seals in the film back, or between the back and body, or even a crack somewhere in the back or the body itself. If you can't find a leak in the curtain, try keeping the dark slide in right up til you take a shot in, taking it out as soon as you're ready to shoot, replacing it before you wind, etc. to minimize the amount of time light could come from the anywhere but the back - to try and narrow down the location of the leak.
Jul 26, 2011 | Mamiya 645 Pro TL Medium Format Camera
I installed a Mamiya lens on my RB 67 Pro S. I cocked the shutter and fired it. Now I can't recock shutter and I can't get the lens off. The lens blades are closed.
Hi RMT, I sueest you only one thing. Please visit the service center. Beoause you already cocked the shutter & make it fired. So please follow the link its really very helpful for you.
LINK
Thanks & waiting for your feedback.
Feb 17, 2010 | Mamiya RB67 Pro SD Medium Format Camera
I have a RB67 pro SD and just bought a #1 extension tube for it but the lens doesn't want to mount deep enough? What am I doing wrong? I can't close the lock ring.
You might have an earlier rb pro S ( not pro sd ) version.
The later pro sd lenses have a larger diameter rear element.
The rb67prosd extension yube is clearly marked pro sd the older version just has-
mamiya no.1 45mm.
Nov 25, 2009 | Mamiya RB67 Pro SD Medium Format Camera
AaaaaaaaaaaaAFTER TAKING PICTURES IN DOORS WHY DOES IT GET BLACK ON THE RIGHT SIDE SOME TIMES NOT ALL THE TIME?
typically this is a problem with flash photography.
are you using flash?
the speed of exposure, the time that the film is exposed is controlled by two curtains that cover the film and prevent light from striking it. One curtain is across the film at the start, and springs open, then the second which was open, springs shut.
for 'long' exposures the first one opens time passes and then the second closes, but to achieve very short times, the second curtain starts to close before the first one has fully cleared the opening. so the edge of the second curtain can be traveling fractions of a second behind the first.
the result is that NOT ALL OF YOUR FILM is exposed to light at the same instant. If you have a flash go off during a fast exposure, only that portion of film that is exposes when the flash fires will get the proper amount of light, the rest of the film being blocked by a curtain. Most cameras are wired to fire the flash as soon as the first curtain is fully open and before the second starts to close. If you have a faster speed set in your camera by mistake, the second curtain has already started to close when the flash goes off. The black area on the right side is that portion of film that was already covered by that second curtain when the flash fired.
if you have the camera set correctly (typically at 1/60th or 1/100th sec) then maybe you should take the camera to a local camera store, and have the curtains timed...
Feb 20, 2009 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Mamiya 645 Super Replacement Parts
You can probably order direct from Mamiya, here is the contact info: Mamiya America
Mar 26, 2008 | Cameras
Rear curtain won't close fully
It's a sign the mechanism needs a cleaning and lube. Temporarily you might try releasing the shutter ( without a lens mounted ) and locking the release button down. Then CAREFULLY from the back, put a little upward pressure on the metal curtain 1/4 inch or so, to twist the curtain slightly on it's shaft. Don't pull to far or you can do permanent damage. You should have a repair shop take care of it.
Nov 09, 2006 | Hasselblad 503CX Medium Format Camera
Cameras Logo
119 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
