Question about Linksys Wireless-G WRT54G Router
Had a power bump and the next I lost the connection to the secure link Barneyi
    Problem Solver:
  • 35 Answers
SOURCE:
Here's my problem, I have a belkin n300 extender, ok it worked for about a week or so and one day I lost connection, when I looked it is solid blue, even after I press reset or wps, it stays blue, I don't...
Blue?
the n300 colors.....
4 LED Descriptions
Router Link LED
This LED indicates the connection between the extender and the router or access point.
Solid green
. Best connection.
Solid ambe
r. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Device Link LED
This LED indicates the connection between the extender and a computer or mobile device.
Solid green
. Best connection.
Solid amber
. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Power LED
Solid amber
. The extender is booting.
Solid green
. The extender is powered on.
Off
. The extender is powered off.
WPS LED
Solid green
. WiFi security is enabled (WPA or WPA2).
Blinking green
. A WPS connection is being established.
Off
. WiFi security is not enabled.
Note:
If the Router Link LED or Device Link LED is amber or red, Find the Best Location
Mar 07, 2018 | Belkin Computers & Internet
2000 Isuzu rodeo dies when you hit bump starts back immediately
Is it setting any fault code in the Powertrain computer?
Oct 07, 2016 | 2000 Isuzu Rodeo
How do I repair all wheel drive in 2004 chevrolet astro van. hit a big bump and lost all power. later retrieved power, but lost all wheel drive. thanks for any help.
its electronic solenoid inside the transmission you have to pull the transmission apart to get to it. starting with the transmission pan.you might want to use a transmission shop for this one.
Oct 14, 2014 | 2004 Chevrolet Astro
No electrical power at all, possible fuse somewhere?
If you check the battery posts with a meter and you have voltage, you would next check the main fuses and for power at the starter, plus the ground connections.
Jan 12, 2013 | 2006 Nissan Xterra
Everytime I turn a corner or go over a bump the entire system shuts off and reboots. It will do this mutliple times, to the point where its no longer playing music anymore. What's wrong with it?
I would check fusable link on power supply 12 volt DC from battery voltage. if compression springs loose inside link, possible that bumps are causing loss of contact causing power down, then when the reconnect, you get reboot, check entire power supply line from point of power connection to unit.
DW Mylin
Nov 28, 2012 | Kenwood Kdc-138 Car Cd Receiver Aux Ipod...
I have a 95 yj, 6 cyl. 4.0 . When driving and I hit a hard bump in the road or multiple bumps it kills the truck completely. Ill get out and play with the nuetral safety switch and it fires right over. Ive...
The plug that connects to the main ecu computer might be loose and the hard bumps might be causing an intermittent connection. Check the ecu plug and if it's loose, you can use plastic wire straps to secure it firmly to the ecu.
Sep 06, 2011 | 1995 Jeep Wrangler
I have a home networkwith a d link adsl2+ router... it was wired into my desktop which has just crashed... it is now pluggedinto my laptop which had also crashed but has just been fixed by relacing the...
In case of lost password, all you can do is to Reset the router to factory default setting and re-configure the modem/router. Press and hold the reset button for few seconds (It is at the back of the router near the DC Power Jack). The LEDs will then blink and the routers factory settings would be restored. Please note that, after resetting the router you should be able to see the router and connect to it via LAN Cable or Wirelessly as the router automatic assigns the IP Address and gateway etc. Before proceeding to the next step please make sure that you are getting the signals as well as internet. However, the internet connection would not be secure, which can be done later.
After hard reset all the settings are lost and you would have to enter the ISP/DSL settings which are usually provided by the ISP/Internet provider.
Now, all you have to do is connect to the router and secure the connection follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (Default router settings are written under the router)
(unless you've configured otherwise, the default username is admin and the password "leave it blank") and lookup for the options to do the following: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password
(The above step would prevent unauthorized access to your router)
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Setup" 2.Under "Wireless Security Mode", select your desired encryption method (preferably WEP or WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Save Settings.
In the screen shot below from D-Link DIR-300 Router, I have highlighted the above mentioned options.
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 29, 2011 | D-Link Computers & Internet
Total power loss
Check the battery connections. Also check the connection of the cable at the underhood fuse box where there is a "stud" with a cable that looks like a small version of a battery cable secured by a nut. Hope this is helpful.
May 23, 2009 | 2007 Chevrolet Cobalt Coupe
Bumped front of my modem by accident and i lost connection....
I think that when u bumped, something went loose. Open up your computer and just make sure everything is seated properly. You RAM and your graphics card being the main things to check. Re-seat them if possible. That should take care of the problem.
May 14, 2009 | Dell Computers & Internet
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
