Question about SanDisk Sansa e260 MP3 Player
Sansa Ok it recognizes it now, but it just says A new USB device has been found. Wizard comes up tells me it will look on my computer for the installation CD. then says if my sansa came with a cd i should put it in. I did. i installed everything the sansa media converter. Then it searches for a usb device, says it dosent find anything. Then i have to finish.
  • marshy7 Aug 21, 2008
    nvm dosent recognize just comes up, saying unknown device. I cant find the mode thing though where u told me to go? Where is the menu
  • 758 Answers
To obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerrep
Posted on Sep 07, 2008
My computer does not recognize Sansa Fuze
On your computer, Go to Windows Task Manager or Control Panel. Find the Device Manager. There should be a list called Plug-N-Play Devices.
Find the one that should have the driver details of your SanDisk Sansa Fuze Digital Media Player.
Right click on it and select Uninstall.
Now plug in your MP3 Player again to the computer. This time your computer should detect that your MP3 player is connected and will install the drivers for the MP3 player again.
Hope I was of assistance to you,
Cheers :)
Apr 22, 2010 | SanDisk Sansa Fuze MP3 Player
I got a used sansa e260 mp3 and my computer won't accept it?
Try connecting it to another computer and see if it will recognize it as sansa or removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansa and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier
Mar 18, 2009 | SanDisk Sansa e260 MP3 Player
Sansa c200 will not connect to computer via USB
Try add new hardware wizard.
Once it does not find it.
Tell the new hardware wizard to search for MTP device.
Jan 16, 2009 | SanDisk Sansa c200 MP3 Player
Sansa e260 will not connect to computer
Unplug the Sansa from the computer. Turn it off. Hold in the REC button. Reconnect the Sansa to the computer while holding in the REC button. After 10-15 seconds of continuing to hold in the REC button, a window should pop up saying "Found New Hardware Wizard." Complete the Wizard.
-Tha Mp3 Doctor
Dec 27, 2008 | SanDisk Sansa e260 MP3 Player
Sansa scan disk mp3 player
guest - you must have Windows Vista - it's not compatible
tooth -
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Jul 01, 2008 | SanDisk Sansa m250 MP3 Player
Tried the solution you offered for c240....
Go to Start --> Control Panel --> Printers and Other Hardware --> System --> hardware --> device manager --> right click on the usb port that is malfunctioning (should have a red or yellow exclamation by it), right-click it and click on Update Driver
If that fails, try another USB port on the computer to see if you have more success
Jun 23, 2008 | SanDisk Sansa c240 MP3 Player
My sandisk c240 charges when plugged in but fails to be recognized on the computer
There is quite possibly a problem with the USB cable or the USB port on the computer, but try this shortcut force to force the computer to recognize the Mp3 player: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
How do I get my Sansa e260 to appear in Windows Media Player (v. 11; Vista)?
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 12, 2008 | SanDisk Sansa e260 MP3 Player
Windows xp professional does not recognize device
XP Professional tends to have problems with all devices when you are connected to a network. Disconnect your Sansa player from computer, turn it off, hold in the volume + button and reconnect to the computer. Continue holding the volume + button until the "Found New Hardware" Wizard pops up - XP will load the needed drivers.
Apr 12, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip mp3 player
To help you with that, I need to know what operating system your using (XP, Vista, ect...) and what other devices you have plugged into the computer. There are a few things you can try. When you plug it in, does it say it's connected? Does the "Found new hardware" wizard come up? Let me know, I'll see what I can do to help
Dec 31, 2007 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa e260 MP3 Player Logo
20 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
