Question about Toshiba MCDU Processor Card for Display Telephones - Refurbished (TSMCDU)
Toshiba Auto Attendant
I am trying to change the main greeting on our telephone system for when the phone is set to auto attendant. How do I go about doing this?
4 Suggested Answers
  • 45 Answers
SOURCE: panasonic 816 reduce from 4 to 1 ring before auto attendant ans.
You can voice mail to answer after one ring.
You will need a programmer to program ringing.
info@ameritelnj.com
Tony
Posted on Apr 03, 2009
  • 66 Answers
SOURCE: Does Toshiba Stratta DK 14 current setup offer voicemail?
A DK 14 is only capable us using the Stratagy Flash voice mail and is an external unit Grey in color. I have phones and systems that are compatible but it's not something you just "Turn On". idacomusa.com
Posted on Feb 11, 2010
  • 45 Answers
SOURCE: Our company has produced Auto Attendant messages
You would have to dial your voicemail extension. Usually this extension is 850 or 555. Once greeting starts you need to press *. It will then ask you for the user ID and password. User ID should be 990 and password should be 990997. Once in the mailbox you will have to follow the instructions on entering in your message. Below is a site with Toshiba manuals that may help.
http://www.wedophones.com/ToshibaManualsLead.htm
Posted on Feb 26, 2010
Set up auto attendant toshiba
This is a system wide setting please go to http://www.telecom.toshiba.com/ and obtain a users guide for VM specifically the administrators guide. If this does not work. Stay on this same site and find a dealer to log into the system to change the settings for you
Feb 26, 2013 | Toshiba DKT-2020-SD telephone
I have a Panasonic KX-T7433 and want to change the Auto Attendant message. How do I do this?
An auto attendant in a Panasonic brand voice mail system (TVS/TVA/TVM etc.) is controlled from the message manager's phone. It is accessed by calling 165 and dialing #6 *998
Unfortunately, your question has no hard answer. Each voice mail and auto attendant is different. For example, in TVS boxes, we use custom greetings and store day messages in 30 and night in 60. There are 100 "custom" greeting slots and 32 "company" slots in a TVS box. In the newer TVA systems, the interface is visual and custom messages get assigned sequentially. In those systems, we start with 1 day and 2 night.
So, the best answer is to find the installation instructions. If you can't, then you can step through each custom greeting for the existing one, or log into the VM system and read the database.
Carl
Feb 16, 2011 | Panasonic KX-T7453 Corded Phone
How do you erase and change after hours greeting?dhalman
Call voicemail by pressing the Intercom button then dialing 777, when it answers login by dialing 99# followed by the password(default is 1234#) then press 9 for system features menu. Press 3 to choose Automated Attendant, the system prompts for the Auto Attendant number(1-4), start with Auto Attendant 1,if you do not know which one is being used by pressing 1. Press 2 to choose Night Menu, press 6 to change the Night Menu prompt. Lift the handset, press 1 to record your new Night Menu prompt using the handset, press 1 at the end of your recording. To listen to the new recording press 23, to immediately re-record press 21, to save the recording press *#. Press # to save all programming changes and activate new recording. Press *7 to return to system features menu or hang up to end programming session.
Changing the Auto Attendant prompt should be done when you are able to do a test call on each line to verify that you have changed the correct prompt(in your case after hours or by putting the system in After Hours mode manually to ensure the After Hours prompt is active) for each line being answered by the Auto Attendant. By default all lines are assigned to Auto Attendant 1, if your system has been modified to use a different Auto Attendant for some or all lines, you will need to repeat the above procedure for the Auto Attendant being used. If at any time you get lost or confused while in the voicemail programming, hang up and start over. Once you get comfortable with navigating the voicemail programming, it gets easier. If you have trouble send a comment, I will try to help.
Feb 10, 2011 | Lucent PARTNER18 Corded Phone
We have a Landmark/Southwestern Bell Telecom DKS 308/616 system and need to know how to access and change the auto attendant greeting.
Call your own number or press and hold #1 button and when the message starts playing press either # or * and follow the directions. It's usually #
Apr 16, 2010 | Cell Phones
Nortel 7316e: Need to change the auto attendant
To enter viocemail administration, press Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Oct 27, 2009 | Nortel T7316E 2-Line Corded Phone
I can not change the Auto Attendant Message on the phone . It wont let me change the auto-attandant message i put in the password as 1020000 and it says invalid! how can i get around it...no one knows the...
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Sep 15, 2009 | NorStar M7310 Corded Phone
Change new greeting removed old greeting
Sounds like you might be changing the wrong greeting. If your using a night button to toggle the auto attendant on and off the auto attendant is using the night greeting.
Aug 28, 2009 | Lucent PARTNER18 Corded Phone
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Feb 11, 2009 | NorStar M7324 Telephone
Cant get auto attendant to turn off.
What are you trying to do. It isnt that easy to turn the Auto Attendant partially off....
Jan 17, 2008 | Avaya Magic Voice Mail Automated Attendant...
Starplus sts phone change the greeting on auto attendant
Do you have the manual for the phone system or the voice mail? If you are looking at a phone system manual, most do not contain any details on voice mail settings because you can have different voice mail systems attached to your system. Just like your computer manual would not contain much information about the printer you purchased separately.
Nov 29, 2007 | Lands Phones
Lands Phones Logo
75 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
