Question about HP Officejet 5610 All-In-One InkJet Printer
Cancel printing doesn't work
Hi, the HP 5610 seems to have a problem when it comes to cancelling print jobs that stall halfway through printing.
I can't cancel them through the normal route (cancelling one or all in the print queue or pressing cancel on the printer keyboard).
It also doesn't work if I turn the printer off and on again. The job is still int he print queue even though it is no longer registered on the printer's information window.
I've looked for processes that should be ended (control+alt+del) but i'm not sure which one to end and don't want to cause any other problems.
This is very irritating! I don't want to reboot the computer as I don't want to lose something on a webpage that I want to print (confirmation of a flight booking)... But i can't print it because of this other job in the way.
Thanks!
Lesley
  • mangoginger Aug 21, 2008
    thanks, but I did cancel the job from the desk top (in addition to the printer buttons) but it just wouldn't disappear. I rebooted my computer in the end. I think it's a printer glitch because it doesn't happen with my nice cheap Canon i250.
    thanks for your help.
  • 234 Answers
If you have tried a reboot then why don't you try a Soppler Refresh.
Click on Start> Run (and type Services.msc) Hot ok.
It should open services window up.
Then look for Print spooler> Double click on it> Under General amke sure startup type is selected as Automatic> Then down you shoul see a tab which says stop> Click Stop (Now a small windows popps up and closes) You will see Start Highlighted> Click start and stop will be higlighted> if applicable click on apply or ok and close all the windows and restart the computer.
Then go to Start> Control panel> Printers and faxes> and check to see if the icon say 0Ready> if yes right click on the icon and left lick on Properties and then in the bottom you will see a tab which says print test page> click and see if it prints a test page.
Then try printing any document.
Good Luck
Posted on Sep 01, 2008
How to cancel a print job on the HP officejet 5610 all in one pri nter
The user manual for this printer is here: http://h10032.www1.hp.com/ctg/Manual/c00461378.pdf
On page 4, the cancel button is marked "11" on the diagram.
Jul 28, 2011 | HP Officejet 5610 All-In-One InkJet...
I would like to cancel a print job without losing all of my memory card picture selections. Seems rather silly to lose all your selections if something goes awry with your printer output.
If you are using Windows, you can cancel a print job by opening your Start menu (usually the bottom left corner of your screen) then open Devices and Printers or Printers and Faxes depending on your version of Windows.
Double left-click the name of your printer
Right-click the name of the print job you want to cancel and select cancel print job or right-click a blank part of the printer box and select cancel all print jobs.
Apr 12, 2011 | HP Photosmart 3310 Printer
How do you clear the print jobs so that you are not printing the same things over and over
How to Clear Out a Stalled Print Job In order to stop a stalled print job, perform the following steps in order:
  1. Stop the Print Spooling service.
    • Click Start.
    • Click Run.
    • Type cmd.
    • Hit Enter.
    • At the command prompt, type net stop spooler and hit the Enter key.
  2. Delete the stalled print job.
    • Open My Computer.
    • Go to C:\Windows\system32\spool
      • Delete any files you find in this folder (but do not delete any folders!).
    • Go to C:\Windows\system32\spool\printers
  3. Restart the Print Spooling service.
    • Return to the command prompt used in step 1.
    • Type net start spooler and hit the Enter key.
Once you have restarted the Print Spooler, the jammed print job will be cleared from memory. Now you can go back and re-print all the jobs that were held up.
Feb 15, 2011 | HP Office Equipment & Supplies
My hp officejet 5610 all-in-one is giving me a problem it wont print but it prints old stuf when i turn on my printer how do i fix it
Clear out your print cue. Double click on the printer icon and then right click on the print jobs and cancel all. Then retry your current job.
Aug 23, 2010 | HP Officejet 5610 All-In-One InkJet...
Cancelled a job and it stays in queue
Cancel all the documents in the print queue, (just do it whether they are actually deleted or not), press "cancel" on button the printer and restart your system and also the printer. If possible, please leave the printer switched off for few minutes and don't forget to use the "Power" button to turn if off or on. This will help your printer to restart new print job, all the jobs on the print queue will be deleted/cleared. Good luck, Thanks for using FixYa.
Jun 08, 2010 | HP DeskJet 5550 InkJet Printer
It takes unduly long time to cancel a print-command on any printer, when we work on Windows. What is the surest way to kill a printing command.
Open "Printers and Faxes" from the Start Menu. Open the print queue for your printer by double-clicking on your printer's icon. There will be a list of all the current print jobs. There you can right-click on a job and select Cancel, Restart, etc. Cancel will remove it from the list.
If you are not on the computer that is connected to the printer, you might not have permission to change the queue. Then you should go to the computer that is actually connected, and use this procedure there.
May 28, 2010 | HP Officejet 5610 All-In-One InkJet...
Unable to delete pending jobs
To cancel one or more print jobs, follow these steps.
1. Go to Control panel - Printers .
2. Right-click the icon for your printer, and then click
Open.
3. To cancel individual print jobs, right-click the print job
that you want to cancel, and then click Cancel.
4. To cancel all print jobs, click Cancel All Documents on
the Printer menu.
Alternatively if this doesnt work you have to restart the spooler service
1.Go to Control Panel - Click Administrative Tools.
2.Double-click Services.
3. Stop the service called Print Spooler.
4. Click Start to restart the Print Spooler. Then click OK.
Hope this helps.
Mar 12, 2010 | HP LaserJet P4015N Printer
Can't cancel a HP PSC 750 Printer print job.
Right click on MyComputer and click Manage. Then go to Services and Applications and then Services. Find the Print Spooler services in the list and right click to stop it. When it is stopped try to cancel the document again. Then start the print spooler service again.
Regards,
nicolasiac
Feb 12, 2010 | HP PSC 750 All-In-One InkJet Printer
Printing Problem
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer.
Jan 28, 2010 | Lexmark X73 All-In-One InkJet Printer
SerialNumberJob appears in the printing queque
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab20
Jul 11, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
133 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
