Question about Sharper Image Ionic Breeze 3.0 Air Purifier
My ionic breeze has quit working. The red light that says needs cleaning is always on...........
  • 6 more comments
  • vietgirl Aug 27, 2008
    i have the same problem, the red light keeps flickering, and i clean the sysem very well.
  • TERROTH Aug 30, 2008
    SAME FOR ME, MY UNIT ISN'T CLEANING, THE RED LIGHT JUST FLICKERS ALL THE TIME EVEN THOUGH IT'S TOTALY CLEAN.
  • sar315 Aug 31, 2008
    The red light on my unit stays on despite the unit being cleaned. The unit is not filtering the air.
  • dntb Aug 31, 2008
    clean overdue light stays on
  • Anonymous Sep 05, 2008
    I too have an Ionic Breeze which has the "Unit Needs cleaning" light on even after I have cleaned the inside the outside fins and turned it upside down like you should. I take the inside fins out and they are completely clean.
  • ohgram Sep 14, 2008
    I have totally torn apart the unit and cleaned it to no avail. Flashing red light. Maybe it's just not fixable. Hope not...but company is bankrupt so why expect a solution to this.
  • SERG4517 Feb 19, 2009
    I just cleaned it AND IT WON'T TURN ON
  • ejabney May 11, 2010
    What is your solution?
I have the same problem as well as my on button keeps going off and on...
Posted on Aug 26, 2008
    Scholar:
  • 45 Answers
Have you tried unplugging it, cleaning it (filters/fins or whatever it has), and maybe checked online to see if there is a way or whatnot to do a type of "reset" on it? I had one about 6 months ago that it happened to and I ended up sending it in for warranty-type service. Needless to say I have a different one now that has not given me the first issue.
Good luck with it. I say contact the company and express your concerns, as they might try to make it right for you.
Posted on Aug 20, 2008
SHARPER IMAGE IONIC BREEZE QUADRA RED LIGHT ON
I had one that had the "needs cleaning" light was on. After cleaning, the light stayed on. I checked around at the time and learned it couldn't be fixed, and it was out of warrantee. I believe that's why they stopped making them. Mine was just thrown away.
Apr 02, 2012 | Sharper Image Air Purifiers
WHAT ARE THE GREEN AND BLUE LIGHTS FOR
To let you know when the ionic breeze is working properly (Green Light) and when it needs to be cleaned (Blue light). Hope this helps.
Apr 19, 2010 | Sharper Image Professional Plus Ionic...
MIDI Ionic Breeze quit working
Unit seems to need reset...To do this simply, with unit still plugged in, set to off by selecting on button until there are no high, med, or low lights on. unplug unit from wall for about 15 seconds then plug back into wall socket and select your favorite setting high, med. or low. The order in which you perform this task must be as stated above and the unit must be clean and the door and cleaning rod must be in home position. Hope this helps, mines working fine now but took a couple tries to find right order to reset.
Sep 16, 2009 | Sharper Image Professional Plus Ionic...
There is a red blinking light and it is not cleaning.
My Ionic Breeze would work for a short time after cleaning and the blue light would start flashing and the unit would stop working. I checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So I went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. However the Ionic Breeze produces harmful Ozone gas, so I don't use it anymore.
Aug 09, 2009 | Sharper Image Professional Plus Ionic...
Ionic breeze quadra s1857 Red light continues to blink needs cleaning even after cleaning. not filtering. help
Mine is a Pro-series Quadra. It needed better cleaning.
The front and rear plastic grill scome off (release catch at the bottom of each), allowing access to the central core. I cleaned it with a damp rag (let it dry before you turn it back on). Be very careful of the two wires running the length of the unit -- if you break these it will not work. I did, however, gently clean them.
When I restarted it there was an unusual smell for a few minutes, but all is working well again.
Apr 13, 2009 | Sharper Image Ionic Breeze® Quadra® Air...
Is my Ionic Breeze Quadra hopelessly broken and beyond repair?
This unit can be replaced on ebay for around $45.00 which is under any labor cost to repair the unit you currently have. You can always post your unit for sale on ebay for parts.
Feb 19, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Ionic breeze midi
Sharper Image Ionizers are no longer supported because they have recalled since they were proven to be innefective for cleaning the air and can harm people with breathing problems.
Here is a link on the Chapter 11 report
Here is an EPA report on ionizers
Jun 18, 2008 | Sharper Image Professional Plus Ionic...
Ionic breeze quadra s 1837
I had a problem with my Ionic Breeze Quadra. Green light would only blink for a second then the red light stayed on. I cleaned unit very good but problem came right back. I blew out the breeze with an air compressor. Not much came out, but now I am green and back in action. I used about 75 psi to clean out.
Mar 23, 2008 | Sharper Image Ionic Breeze® Quadra® Air...
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
299 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
