SOURCE: how do you bridge a amp to one subwoofer the amp
http://www.docs.sony.com/release/XM1502SX.PDF
THE ABOVE LINK WILL TAKE YOU TO THE SONYSTYLE WEBSITES COPY OF YOUR AMPLIFIER'S USER MANUAL WHICH INCLUDES PRODUCT HOOK-UP AND DIAGRAMS. YOU WILL BE USING THE LEFT CHANNELS POSITIVE AND THE RIGHT CHANNELS NEGATIVE FOR A BRIDGED CONNECTION. THE CORRECT SPEAKER LOAD IS 4 OHMS MINIMUM. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE....V
Testimonial: "thanks for the help professor sounds good "
SOURCE: can you bridge a sony xm-2200gtx amp
left positive and right negative-make sure the speaker that you intend to run in bridged mode is 4 ohms or you will kill your amp
SOURCE: can the xm-460 gtx be bridged so as to run just
No, because the would require bridgeing the front channels and this amp does not allow for that. Rear only so it can only operate in a 3 or 4 channel mode.
SOURCE: I have this amp...the sony xplod xm-sd51x class d
monoblock amps are NOT bridgiable. there is a good chance you will burn up the amp if you try it.
This will allow 2 channels to run 100 watts each @ 4ohms with an additional single channel with 250 watts @ 4 ohms.
The single sub channel is created by bridging channels 3 & 4
