Question about Ricoh Aficio AP3800C Laser Printer
Ricoh CL7000 While printing we encounter a pink line about a 1/2 inch thick on the bottom of page, can you help. We are thinking the Magenta Drum needs to be replaced. Do you agree?
  • Ricoh Master
  • 691 Answers
Do a stop test using a document with CMYK content across whole document. Remove and examine M dev and drum and also check the master belt etc. The first component with the pink line on is most likely the faulty one.
Posted on Sep 14, 2008
A 1/4 inch stripe of magenta ink runs down the side of all pages printed.
Hi ,
Dirty print out is mostly due to cartridge related issues. In this case it seems that magenta is the issue. Take out the cartridge and clean its drum/ (green roller) with a dry, soft, lint-free cloth. The drum is located under a cover. Checkout for any spilled toner inside the printer and clean it also. Print a few pages so that the parts get further cleaned. I think, this would solve the issue.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located just behind the green drum inside the cartridge. Try cleaning it or replacing the Magenta Cartridge. If required, get the PCR Roller changed by a professional.
Let me know if any further clarification is required.
Hope it helps! Good Luck!
CreativeTECH
Mar 03, 2011 | Brother MFC9450CDN Colour Laser MFC...
I have a Gestetner DSc38u and when I print colour I get a 'red'/'pink' line about an inch from the top of each page. Any suggestions?
If the line is only red or pink, it is most likely caused by the magenta PCU. Replace this PCU and your problem will go away.
Occasionally the magenta developer unit can cause a red or pink line, but the problem is more than likely from your magenta PCU. The PCU is easy to replace, and instructions will come in the box if you order an OEM replacement unit.
Jan 22, 2011 | Ricoh Aficio 3800CMF Laser Printer
Hi Everytning I print has a very narrow pink line straight down the centre of the page, also every so often the print has a black/yellow/blue/pink thick line running across the page. Thanks
The narrow pink line is coming from your magenta toner/drum cartridge. You may be able to open the from cover and look at the 4 toners. If you look at the magenta (like pink) cartridge, you might see the thin line on the drum surface.
The multicolored band that sometimes shows up on your prints is most likely the transfer belt unit. This is caused by an area of the belt that is not being cleaned very well. This probably tends to show up when you are running mutilple prints of a page.
So it looks like to may need to replace your magenta toner and look at getting a transfer belt unit.
May 13, 2010 | HP Color LaserJet 2600n Printer
Black streaky lines on printed and copied pages
HI,
I think you should change your printers tonner.
Thanks
Feb 24, 2009 | Ricoh Aficio CL7000 Laser Printer
Repeated cyan line across printouts.
Need to replace the cyan PCU. It is a user replaceable item. Here is a link to user manual:
http://www.ricoh-usa.com/downloads/manuals/printers/cl7000/manuals/CL7000%20Printer%20Maintenance%20Guide.pdf
Nov 12, 2008 | Ricoh Aficio CL7000 Laser Printer
Ricoh CL7000 protected menu
Go in through the web page (printer's ip address) Default username:Admin
Password: password
You can change it in there.
Oct 20, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh CL7000 - Black lines every 4,5 or 9 pages
Sounds like the registration clutch is faulty. The knocking maybe the fuser unit jumping gears check that unit also check that the green paper holders are all in the correct place.
Thanks Jason
Jun 30, 2008 | Ricoh Aficio CL7000 Laser Printer
Streaking
Hi there it will be either the drum unit for the color streaks you are getting or the fuser unit. Check the drum units for the streaks on them also check the fuser but the clue is when you have the streaks in different places. Most likely to be the drum units. You will need to replace.
Thanks J
Oct 30, 2007 | Ricoh Aficio CL7000 Laser Printer
Ricoh CL7000 Pink bands
Hi there you have the magenta drum cleaning fault. You will have to replace the Magenta PCU (Photo Conductor Unit) 99.5% sure
Thanks J
Nov 15, 2006 | Ricoh CL7000 DT2 Laser Printer
Ricoh Aficio AP3800C Laser Printer Logo
195 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
