SOURCE: Setting the Clock
1.In the stop mode, press and hold down the MENU/STOP button for at least 2 seconds
The menu setting display appears.
2. Press the SKIP/SEARCH button repeatedly to select dAtE
3. Press the POWER/PLAY button.
The year display blinks
4. Press the SKIP/SEARCH button repeatedly to select the year. Then press the POWER/PLAY button. The month display blinks.
5. Repeat the same step 4 to set the month, day, hour display ("24 H or "12H") hour and minute. Note: "second" cannot be selected.
When the minute setting is completed, "dAtE" returns.
6. Press the MENU/STOP button.
SOURCE: ICR-B130 Handheld Digital Recorder
Ha this is a greatly contested two posiblities.
1/ Are you on a business network? The most common reason for this error is because the user has mapped network drives on low drive letters e.g. mapped drives on E F G H I etc. When you connect recorder windows trys to assign the physically available drive letter. However that drive is being used by a mapped network drive so windows simply doesnt recognise the newly attched device hence the sanyo software not recognising the device.
2/ Some Dell PC's struggle to supply enough power to all USB ports so try connecting to the back of the PC or removing some USB devices and reconnect the B130.
This error cannot be produced without a recorder being connect so it recognised to a point just. Just not correctly.
If this Answer goes some way towards helping
to resolve your Query, Problem or Fault, please take the time to Rate it. Doing
so helps Solution Providers, like me, better understand the needs and the point
of view of Askers, like you, and guides us in exploring the best ways to
provide the most comprehensive, useful and high quality Responses and Solutions
we can. If you need further help, please do not hesitate to post another
Question or add a Comment to this Question.
Thanks for using FixYa.
