Question about Lexmark E340 Laser Printer
Paper jams Keep getting several messages. Replace photo conductor, paper jam, low toner. Lexmark said reset to factory defaults. Tried this, but says paper jam when we try to print again. There is no paper jam, have replaced photo conductor, nothing is working. What else can we try?
  • 1 more comment
  • milliken_l Aug 25, 2008
    Had already tried a new toner first. This is the sequence of problems.
    1. Busy Toner Low
    2. Ready Toner Low
    I try to print test page
    3. 201 paper jam remove cartridge
    I remove paper.
    4. Close Door
    I close door.
    5. Busy Toner Low
    6.Ready Toner Low
    Then we start all over again.
    Any idea?
    Lexmark toner (do not purchase generic, learned the hard and expensive way!)
    When I open the door, the test page is half printed and it is just laying there. It is very easy to pick it up and remove. I do not have that printer here in my office, but I will try the things you have mentioned. Thank you.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Lexmark Master
  • 1,362 Answers
There are two parts to the copy of this machine, one is the photo conductor (drum, green cylinder ***'y) and the toner which fits in the drum ***'y.
you replaced the drum but you need to replace the toner as well (low toner)
then turn off and hold the start key an dturn on to get into service mode, scroll to reset photo count, select.
Posted on Aug 25, 2008
  • 1 more comment
  • CheckitRight
    CheckitRight Aug 25, 2008
    is this generic or oem toner?
  • CheckitRight
    are you using punch hole paper? with this model the holes have to be towards the back or it will jam and give a code.
    does it actually pick up the paper or make the noise?
    try flipping the paper over.
    did you clean the rubber tires that pick up the paper?
    clean with alcohol, it should pick up after cleaning, may need to replace.
  • CheckitRight
    it also sounds like it is not reaching the fuser (where it gets hot before the exit)
    we know the drum and toner are working and rotating (prints)
    you may also want to double check the paper size and make sure it's set for Letter.
    try the by-pass feed a single sheet in the front, does it go trough? yes then the problem is between the tray and the black spongy roller under the drum.
    does it pick up hte paper right away, or is there hesitation?
    when you open the door look in front there is a black guide that you can lift up there is a sensor there, it must be freeand have a spring action.
Paper jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 12, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
alternative :
Jun 09, 2009 | Lexmark T644 Laser Printer
I have a lexmark 5470 there is paper jammed and I cannot get to the jam It is a all in one printer
alternative :
Jun 08, 2009 | Lexmark X5470 All-In-One InkJet Printer
Paper jam message, but actually no paper jam
alternative :
Mar 25, 2009 | Lexmark X83 All-In-One InkJet Printer
Misfeeds paper pulls to the right--says paper jam-no jam
there could be a paper jam or some paper still inside.
alternative :
Mar 17, 2009 | Lexmark X3350 All-In-One InkJet Printer
Jam
alternative :
Oct 28, 2008 | HP 920 Plain Paper Fax
Paper jam. When I use my printer paper is jam and goes at a wrong angle. Please. Let me know how I can fix of it. Thanks. Valeriy
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
alternative :
Oct 26, 2008 | Lexmark X83 All-In-One InkJet Printer
Paper jam.
try this, its probably a small part of jammed paper inside or then theres a problem with the paper pickup, try cleaning it.
alternative :
PAPER JAM ERROR MESSAGE
your sensor flag in the back is broken or missing
Jun 05, 2008 | Lexmark E342n Laser Printer
Lexmark E340 Laser Printer Logo
436 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
