Toshiba A75-S231 on/off glow ring.
The glow ring around the on/off switch has dislodged from the computer case. I can still turn the computer on by pushing on the on/off button that normally sits under the glow ring. How do I get to the under side of the top of the computer to reattach the glow ring?
Thanks,
Fred F
  • frf1940 Aug 21, 2008
    The plastic strip you reffer to seems to be part of the whole plastic top cover. I lefted the plastic stip that hides the key pad screws. It appears that the key pad may have to be removed along with the screen attachment screw. There are also two screws marked F8 that appears to hold down the entire top plastic cover. Maybe the key board and screen mouting pionts do not have to be removed and will come up with the cover when I remove the two F8 screws. The P/N # of the lap top is
    PSA7OUOWLOOG. Your comments please.
    FredF
    Genius:
  • 2,028 Answers
The plastic strip with the power button/glow ring, comes off. I believe there is at least one, and maybe two screws on the bottom that hold it. Take out the screws that are directly bellow the strip, it doesn't matter if you remove all screws in that area just so long as you put them back. After removing the screws, pry up one end of the strip, and lift up the rest, the strip will snap up and off. I've found that it's easier if you get it started from the top of the keyboard, rather than trying to get under the very end next to the other plastic area for the initial pry or lift on the strip.
Posted on Aug 20, 2008
  • Ryan Rogers
    Ryan Rogers Aug 21, 2008
    I'm sorry, I was thinking of a different model. On this, you will have to remove the screen in order to get the top plastics off. Once you remove the key board and hinge covers, you will be able to see the screws holding the screen hinges. It's fairly simple to remove. Make sure you have all the screws out of the base before trying to remove the top plastic, there are some hidden under the battery, and I think the bottom covers. Keep in mind that the top plastic snaps into place and can be difficult to get it started. Let me know how it goes.
Toshiba Satellite A75-S231 overheating pls advise me
You need to open the Notebook and clean it with an Air-blower mainly near the CPU (Processor) area.
You need to check whether the CPU cooling fan is working properly or not, try cleaning it too, If the problem still persists replace the CPU cooling fan.
That's it.
Feb 03, 2010 | Toshiba Satellite A75-S231 Notebook
Toshiba Satellite A75-S231 overheating and unexpected shutdown. I tried dismantling the laptop to clean the fan and heatsink, but I was not able to open it completely. Pls could you guide me and assist me...
I have a Satellite A75-S2292. It did the same thing to me. I just blow the vents & fans out weekly with canned air. I also have an under the laptop cooling fan, to increase the air flow. I haven't had it shut done for months, since I started doing some preventive maintenance.
The changing the thermal paste is not a good repair. Thermal paste will last for at least 20 years, under worse conditions than most computers will ever experience. Removing the processor chip, wiping everything clean & replacing the paste & chip just make more chances for damage.
Oct 29, 2009 | Toshiba Satellite A75-S231 Notebook
I need to reinstall Windows on my Toshiba A75-S231
You can usally find this in your D: Drive. It should already be pre-loaded. Make sure you have made a back up disk as this procedure can wipe out all your programmes that did,nt come with the comp
Feb 12, 2009 | Toshiba Satellite A75-S231 Notebook
When i play sims 2 it always hang then my pc will shut down automatically. the spec of the games are compatible to my loptop what will i do?
There is a problem of overheating. Maybe the specs are almost exactly the same as the game requirements. So the PC still has to work hard. This causes overheating, which should not happen if it is even perfectly compatible.
So, this means that something is causing the computer to overheat. Firstly, shut down any open background programs. Also, see that the laptop vents are not blocked by any thing around. Remember to dust the heatsinks, fans and the casing. Also, the keyboard and main vents. If you can, vacuum it all and open up the casing to be sure that all the gunk is out.
Jan 30, 2009 | Toshiba Satellite A75-S231 Notebook
Remote Procedure Call (RPC) service terminated
do one thing ...
start the system and make sure you are fast
when the system starts up click on the start > run > type > services.msc
in the list find the remote procedure call ( RPC ) and double click on it > click on the tab that says recovery > and than make sure the failures say take no action and than apply and click ok
Dec 23, 2008 | Toshiba Satellite A75-S231 Notebook
Toshiba a75-s231
Your laptop's hard drive must be corrupted. Try a clean install of your operating system or try using the recovery cds included with your laptop.
Sep 21, 2008 | Toshiba A75-S125 Satellite Notebook
This is the problem inside part of your notebook called inverter.
This inverter supply electricity to a small tube light called backlight.So it can be eitheer case of this 3 problem
1.Spoil inverter....need to be replace or
2.Spoil backlight...need to be replace or
3. Spoil mother board that can send voltage to your inverter
So your last choice here is trying to refresh your notebook.I'm not sure toshiba has this soft reset or not...but try it
1.take of your battery
2.unplug the ac adapter off from noteboo
3.Push the poweron button and while holding it,plug the ac adapter back and hold it for 10 sec.
4.push your power button to turn it on and see.
Best of luck,takecare
Apr 20, 2008 | Toshiba Satellite A75-S231 Notebook
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
