I have a mac pro 8 core computer and a mac book pro laptop both with gigabit ethernet ports and both are connected to a netgear gs116 gigabit ethernet switch. My problem is I am not getting a gigabit connection to the switch?
It turns out I had bad CAT5e cables.  Upon switching them out all connections were working at full speed.
Posted on Aug 21, 2008
Transferring data/programs from Mac book to iMac using Ethernet cable. All was going well till last minute, and it has been stuck on that for 3+ hours. Don't know what to do. Help please Elise
Assuming the MacBook has FireWire, get a firewire800 cable. PLug it into both Macs FireWire ports. Shut down MacBook, restart and hold T key = target disk mode. MacBook will appear as any other mounted external drive on your desktop. *From there, you can either manually drag files over or open Migration Assistant on the iMac and migrate user/data/ apps.
Jun 04, 2016 | Apple MacBook Pro Laptop Computer with...
Need to connect both d-link dcm-202 and netgear n600 to mac
is the negear n600 model WNDR3400 or WNDR3700?
try setting the netgear in Accesspoint mode.
(guide available here netgear website)
http://gestyy.com/qXchmK
Jul 02, 2017 | NetGear N600 Wireless Dual Band Gigabit...
Using Netgear DG834 ADSL Modem, want to add a netgear WNDR3700 Wireless Router to act as an assess point
The simplest way to add more ethernet ports is to use a network hub and connect it to the Netgear DG834 instead of the Netgear WNDR3700. This does not require any configuration.
Mar 08, 2012 | Apple MacBook Pro Laptop Computer with...
GS605 v4 netgear
Move your primary Internet connection to port number 5. Although it is not mentioned in any of the documentation, Port 5 is the uplink port.
Feb 25, 2012 | NetGear GS605 5Port Gigabit Ethernet...
We have a Linksys SRW2048 48-Port Gigabit Ethernet Switch. The problem is, that we can't get a connection on the 8 ports on the very right side. What could be the problem, how can we solve it?
Disconnect all the Ethernet cables from all the ports.
Connect one of those eight "bad" ports to your laptop.
See if the port works when it is the ONLY active port.
If not, move the cable to the next of the eight "bad" ports, and test again. Repeat.
Move the cable to one of the 40 "good" ports, and test.
If it works, then you have a hardware problem with that "group" of 8 ports.
Your choice to use only the 40 "good" ports, or to replace the router, if you need those last 8 ports.
Jul 11, 2011 | Linksys SRW2048 48-Port Gigabit Ethernet...
I've got a BT HomeHub which works fine with a 4-port Ethernet switch to give me a small home network of 1 Mac Pro, 1 Laptop and 1 printer. I have an older Netgear RO318 Router - with 8-ports. But when...
When you use the older Netgear RO318 Router, make sure you don't use the WAN/Internet port, only use the numbered switch ports of the router.
Jul 31, 2017 | NetGear RO318 Router
Hi I would like o hook up a netgear prosafe 8port gigabit switch to my pc and run an ethernet cable which is allready hardwired to my sony bluray player so I can enjoy netflix
It would be much easier to use a simpler device, namely any Netgear 10/100 wireless router.
Cable-modem (or DSL-modem) --> Router's WAN port
Router's LAN port #1 --> your desktop computer
Router's LAN port #2 --> your Sony player
Router's wireless adapter --> your iPod Touch's WiFi adapter
Since the cable-modem (or DSL-modem) is only delivering 5 to 25 Mbits/second to your router,
unless you are paying a _lot_ of money per month to your ISP,
there's no need to buy/use expensive "gigabit" equipment.
Jun 06, 2011 | NetGear ProSafe GS108 8-Port Gigabit...
Switching from Linksys 5 port switch to Netgear 8 Port Gigabit
Kindly check the Gateway used in the computer where internet is working.....
to find gateway follow this
start menu >>> RUN>> CMD>>>> Ipconfig
then configure this gateway in all other systems and ask for DNS from you isp as well..to provide DNS manulay.
If still dont work ...
tell me the all information you get by useing ipconfig command in the PC where internet is working.
like IP address
Gateway
DNS
i will make you a map to follow.
best regards,
Dec 02, 2008 | NetGear ProSafe GS108 8-Port Gigabit...
Help me with this linksys product
You may not be able to do MAC Filter in SRW2008. but you can do Static MAC address on the device which allows the computers in Static MAC table can connect it in your switch.
Hope this may help you !
Oct 17, 2007 | Linksys SRW2008 8-Port Gigabit Ethernet...
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
