Question about Sony KV-27S26 27" TV
Sony KV-27S26 27 with sound but no picture
I have a Sony KV-27S26 27 the image start compressing horizontal and eventually move up and disappear. Sometimes, the image is recovered by a small kick with the hand to disapear few second later. So, I guess that it is something loosen but I do not really what it is. Can someone help on this?
Thank you.
Andres
  • rjyukich Apr 14, 2009
    My KV 27S26 turns on with sound and either on picture or a sliglighty compressed picture with alot of horizontal lines in it is this something that can be fixed simply or does it need a repair shop?
  • 10,594 Answers
Yes, its dry solder joint problem in Vertical Deflection Area. If you know how to repair TV, then open it and resold vertical output IC pins and surrounding parts with solder iron and solder wire.
Posted on Aug 20, 2008
No picture, has sound
This problem usually lies on the horizontal output transistor, try to check also for shorted diode. you can buy ftom any electronic parts dealer or radio shacks stores
Jul 27, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron, no picture, sound works fine.
There are potentially dangerous high voltages present inside the set even when unplugged, so caution is required. That being said, if you can solder, you may be able to resolve this. If the picture returns with movement, it is possible that the problem is poor solder connections. Try removing the back and sliding out the main board. Resolder any connections that appear grasiny or have rings. That may resolve the problem.
Keep us posted.
Dan
Feb 03, 2009 | Sony KV-32FS13 TV
Picture stays on for 3 mins, then slowly disappears
sounds like the filament of the picture tube is losing voltage. normally this would be caused by a bad/broken/cracked solder connection. If this is the problem, it may not be too dificult to fix if you have the soldering skills and know what to look for.
Dec 15, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Trinitron KV-24FS100 red light flashes 4 times
your tv had a problem.if you have a knowledge in electronics, check or replace the horizontal transistor beside the plyback. it is a black square parts with 3 pins.
Jul 03, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Sony Trinitron: No Picture
It is likely the HOT (horizontal output transistor) and a couple of associated capacitors.
common failure.
the HOT is around 8.00 and some for the caps.
but almost no tv person works for less than 100. and provides a warranty. so you can expect 150. at least for a bill.
Jan 27, 2008 | Sony KV-27V22 TV
Flashing/sparking of image
no doubt. replace LOT and horizontal output transformer with new one
Jan 26, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
Tv tube wont stay on
in 97 Sony had problems with Flyback on these sets, so the thing I would do different is change it, along with the other components
Aug 22, 2007 | Sony KV-32V42 32" TV
Sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
Aug 29, 2006 | Sony KV-32S35 32" TV
Televison & Video Logo
249 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
