Question about PC Chips M810DLU (M810DLUV75C) Motherboard
BOOT falilure after RAM installation
HISTORY: Every time when the computer was powered up, there was a message "CMOS battery low" and F1/F2 selection for proceeding. ACCIDENT: I replaced a memory chip (power cord out, static e checked) and started a computer. The computer didn't load (no bios messages, no "beep"0 - black monitor), but the fan was working, CD drive was working. ATTEMPTS: - put back an old memory chip - same story. - replaced existing CMOS battery (tablet 3V CR 2032 lithium battery) with a new one - same story - removed memory chips - same story - reset CMOS jumper - same story HARDWARE: Motherboard type - AMD M810D v 7.5 with nothing on it,except for the graphic card and RAM. Memory type - DDR
  • 1 more comment
  • nk08 Aug 21, 2008
    THis is M810D v.7.5 and it holds DDR type of ram.
    I tried it first on my other machine and the chip worked just fine (even it is not exclude what you just said).
    But then even with the old chip it didn't start.
  • chanito28 Oct 10, 2008
    I had the same problem. I received the low batery message.I didn´t change the memory. One friend asked me to just install a fresh copy and then give it back to him. When he tested it on his house it didn´t turn on. Now only the CD an fan are "working". There is no beep and no image on the screen. Could it be a problem with the CMOS? Have you solved this problem?
  • bolo961423 Jan 12, 2009
    I have the same problem, Only Tried to just flash the cmos and it clear it instead. I found a manual for the board and it said you need the motherboard installation disk. And I cannot find it anywhere
If your battery finally died then most likely your motherboard was cleared. you need to find the motherboard setup disk to set it up for use again. I have the same problem but the cmos clear jumper on the board was moved purposely in my case.I never thought i would erase the board just reset it. OOPS.
Posted on Jan 12, 2009
  • 236 Answers
Did you make sure that the new RAM was compatible with the motherboard? ...?
Some RAM manufacturers are not compatible with certain motherboard manufacturers....
Posted on Aug 21, 2008
  • Dave MacPhee
    Dave MacPhee Aug 21, 2008
    if you can tell me the motherboard model number, I should be able to find what RAM makers are compatible
Asus k50ij wont boot
The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Aug 08, 2012 | ASUS K50IJ-C1 Notebook
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
HP Compaq NC6000\r\nWhen I press the power button it seems to start but the only thing I see is numbers going by rapidly in the form of kbytes (524288 KB ok) then it reads 162-system Options not set. Then...
Hi promano67
When you "start" the computer, and the {"Screen"} displays a "Error Message."[CMOS] "error checksum!"
Settings: "Default" loaded.A "checksum error" shows that:
The ("Boot-up Settings "have been changed?"), ie. "Booting OS."
*Boot File 'missing'.
"This can 'occur' if the computer was "shut-down unexpectedly."
Force Shut-down : Power lost; due to 'low battery...'
A ("Power Surge") can cause this 'problem' also.
"What 'happens is that the [CMOS] settings are lost!".
"To fix the problem!"
Do the following:
  • "Restart / Boot the computer.
  • Next, verify if the 'error message' displays?
  • If you are still getting the message?
  • "You will have to "Remove the CMOS battery form the computer!"
  • Shut-down the computer.
  • "Unplug the computer from the {Wall Out-let}.
  • Remove the Lithium battery from the "Notebook."
  • There is a compartment (underneath) the "Notebook that 'store' the CMOS battery."
  • "You will need a {very small Phillips screwdriver}._953.jpg *Remove the CMOS battery for: [30 minutes].
  • !Important: If you have to do it again?
  • Remove the CMOS battery for a {'longer amount of time'}.
  • Replace the "CMOS battery."
  • Next, "Only plug the Power Adapter into the computer.
  • "Do not - replace the "Lithium battery!"
  • Once you have completed these 'task'.
  • "Restart the computer."
  • "Press the [F2] key, to 'enter' the CMOS / BIOS Setup!" _951.jpg
  • Next, 'reset' (all) "Values to the Default Settings."
  • "Press the [F10] key to 'Save' the changes!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Mar 13, 2011 | HP Compaq nc6000 Notebook
Laptop not used for some years. could enter bios OK to reset Replaced U/S CMOS battery with no problem. Restarted............ Message press F1 ibm bios setup press F11 to invoke IBM product recovery...
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Dec 31, 2010 | IBM ThinkPad R30 2656 Notebook
I am having problem with my CPU.When I switch on it state that low battery voltage.Please can you help me with some software or give information on how to solve this problem.Your time & effort in...
Had this problem once before on boot up, but can't find the fix for it.
On boot up, I get the message that says "battery voltage low" and I have
to hit F1 to continue or F2 for setup. My battery voltage is NOT low.
Does anyone have the solution to this as it's quite annoying to have the
boot stop and wait for the F1 command? I promise NOT to lose the solution
again. Thanks.
Just a guess, but is it referring to your CMOS battery and might therefore
be an early indication that it needs changing?
Nov 14, 2010 | Computers & Internet
I got a message 027 real time clock error press F1 to load default or F2 to setup. No booting. Model Satellite A215, AMD
Normally when this happens it is the CMOS battery in the computer that needs replacing. Not the laprtop battery but the internal battery.
hope this helps.
Aug 27, 2010 | Toshiba Satellite A215-S4747 Notebook
F1 F2 required at boot up in VPC, not simple battery issue.
Hi im Rain.
Have you tried changiong the CMOS battery? Im sorry but the big Y2K was just the panic of people not knowing what will happen. There were no computers Reported to have been affected by the Y2K scare. Try changing the CMOS Battery If that fails then we can look into other things that may be affecting the BIOS
Jan 13, 2010 | Computers & Internet
Cant get 4600i started. powers up but will not get past intro screen. screen shows F1 to continue and when i press F1 it tells me to press it again to retry reboot, F2 for setup options.
you need to go to cmos or bios setup, set all the date and time and proper boot setting there save and exit, it is a cmos or bios failure that causes these problems try replacing the cmos battery if the message still continues
Nov 22, 2009 | Dell Dimension 4600 PC Desktop
How to enter cmos setup?
Dear Don't worry, there are some options you will have to press or check one by one "F1or F2 or F8 or F10 or F12 or del. Now, You can enter in CMOS setup.
Aug 04, 2009 | Toshiba Satellite 5005-S504 Notebook
MY LAPTOP(hp compaq presario v2000)BEEPS TWICE AND DISPLAYS PRESS F1 TO RESUME OR F2 TO SETUP!pls help
Hi, and welcome to FixYa
The computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this issue can be caused by any of the below possibilities.
Solution:
If no new hardware has been added to the computer or the new hardware has been removed and you continue to receive the error, it is likely that there is an error or confliction with the CMOS. Press the key requested to enter setup and verify that all settings are correct. If everything appears to be correct try resetting the CMOS values to the defaults and/or Reset Configuration Data. Additional information about how to do this can be found on document CH000976.
If all settings appear to be correct, save changes and exit CMOS setup. If the error continues to appear, enter setup again and restore all CMOS values to default.
· See our CMOS page for additional help and information with the CMOS.
· Additional information about getting into the CMOS / BIOS setup can be found on document CH000192.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, it is also possible that the CMOS battery may be bad or failing. Generally; when this occurs, the computer is not holding the time or date correctly. If this is occurring it is recommended that the CMOS battery be replaced.
regards
/Teis the Wiz - -> Vote "FixYa" :-)
Dec 05, 2008 | Computers & Internet
PC Chips M810DLU (M810DLUV75C) Motherboard Logo
153 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
