Cannot select background option (option greyed out) all I can do is change the colour
  • 1 more comment
  • biba1 Aug 20, 2008
    Windows XP Control Panel/Display/desktop/background I can't select one of the preloaded background options all that is active is the colour option
  • biba1 Aug 23, 2008
    Where do I get windows repair ?
  • biba1 Aug 28, 2008
    thanks
  • 6,487 Answers
You can follow the solutions that other experts offered to you like using a Cd to recovery the corrupted windows file that's why you dont have that option and also do a system restore to the point where everything is working fine..By the I also encounter this and it was cause by a virus or a trojan that only 3 option are available and the option to change display settings is disable, so try running your updated anti virus or if you also have a spyware that will also help...IF all failed this will end to reinstalling your operating system...
Good luck..........
Posted on Aug 23, 2008
    Genius:
  • 1,268 Answers
The driver of your video card hasn't been installed. What you have is just a windows pre-loaded driver. Go to Device manager (right-click My Computer > Properties > Hardware > Device Manager). Look for Display Adapter, Click the + sign. Right-click on your display adapter and click on update driver. Let it search the net for updated drivers.
Also you can run the Setup CD for the motherboard of your computer if you still have it. Install the Video card driver.
    Genius:
  • 1,847 Answers
You need to run windows repair , windows is corrupted
Posted on Aug 20, 2008
    Sergeant:
    Champion:
  • 310 Answers
Can u explain ur problem clearly
    Genius:
  • 2,028 Answers
The background setting are embedded in the operating system, so you will need to perform a system repair with your recovery or operating system disc in order to get it back. You may be able to do a system restore to get it to work. Start with the restore, then do the repair.
  • 3 more comments
  • Ryan Rogers
    Ryan Rogers Aug 20, 2008
    The server glitch momentarily. Did you get my solution?
  • Ryan Rogers
    I believe that a system restore from the start menu, acessories/system tools, will fix the problem. You may have to go back a couple of restore points, but this should clear it up.
  • Ryan Rogers
    Try the restore, then get back to me.
  • Ryan Rogers
    Ryan Rogers Aug 23, 2008
    You will need your recovery or operating system disc. Upon start up, you will need to enter the boot menu or set the bios to boot from the CD drive before the hard drive. Boot from the disc, follow the directions, skip past the first repair section that asks if you want to repair using the recovery console, and go on to the section that finds existing operating systems, from here you will be able to press R, and perform the repair.
  • Ryan Rogers
Printer has light grey background after printing
Hi Mel:
Just a thought, is there a "greyscale" setting?
When I try to print I have the choice of Black & White, colour, and greyscale.
Hope this helps.
Cheers.
Jan 26, 2016 | Brother MFC-7440N Multifunction Laser...
How to change my pattern code if the option is of grey colour
it's better if you reset to factory default it will fix that problem but take a backup of your data
Jun 02, 2014 | Acer Iconia B1-710
Excel Spreadsheet Chapter 2
Firstly you would need to select all the cells in the worksheet. (Assuming you have the worksheet that needs the change in format already open.)
Click on the rectangle between the row numbers and the column names ( i.e. to the left of the A and above the 1) - Marked as Step 1
Then make sure you have selected the home option on the menu bar you need to click on the bucket like button on the ribbon - Marked as BG Button. This should open the colour drop down thinggy that i added to the right of the image. Select the colour you need in this case for the purple I have marked it as Step 2 the Yellow is step 4.
To select a certain block of cells you need to click on the cell address area ( Step 3) and type the range of cells you need to select i.e. B3:B5 .. in this case its just 3 cells and can be selected manually by just clicking on the first cell and dragging the mouse to the third.
Finally jst as you selected the purple you could select the yellow colour.1_26_2013_12_31_35_am.jpg
Jan 25, 2013 | YouTube Videos
How to make folder in dos command how to rename the folder in dos command how to change the font color of the dos command
To make a folder type: mkdir FOLDER_NAME Where FOLDER_NAME is the name that you want to give your folder.
To rename a folder type: rename FOLDER_OLDNAME FOLDER_NEWNAME Where FOLDER_OLDNAME is the old name of the folder and FOLDER_NEWNAME is the new name of the folder.
To change your font colour, use the color command by typing: color XY Where X is a hex value representing the colour of the background of your window and Y is the colour of your.
The values that you can use for X and Y are:
0-black
1-blue
2-green
3-aqua
4-red
5-purple
6-yellow
7-white
8-grey
9-light blue
a-light green
blight aqua
c-light red
d-light purple
e-light yellow
f-bright white
Mar 25, 2011 | Computers & Internet
Grey background on entire sheet
What to do
Change the default 'Grayscale' setting to 'Color' within the print dialog of MS™ PowerPoint.
To do this:
  1. Click File from the file menu option bar.
  2. Click Print from the drop-down dialog options.
  3. Locate the Color/grayscale setting in the lower-left.
  4. Click on the down arrow and select Color.
  5. Click Ok.
Dec 06, 2010 | Lexmark Optra M410 Laser Printer
Can't fix desktop background
this happens due to some virus, it disables these options, download a updated antivirus and scan your system through it
Oct 05, 2009 | HP Pavilion dv1000 Notebook
Printing grayscale
in MS office you change pictures 's colour and print them in garyscale go to picture tool bar and change its colour and in printing prefrence from printer properties change dpi setting to save ink
Aug 09, 2009 | Dell 810 All-In-One InkJet Printer
Kyocera FS-C5015N colour laser printer. -printing grey backgound
it seems very important to shake the toner before using your printer.
it is not too late
remove all toners and shake them well
you will find after a short time that the grey background goes away
Jul 09, 2009 | Kyocera Office Equipment & Supplies
Grayblue Background on scans
A color scan will give real output as it is. If the background is grey, the output will also be grey. If you select 256 Color output, there may be small change in color, as compared to the original. If you select grey output, all colors will be converted to Grey. If these files are converted to PDF, it will be same, except in ODF format.
If you select B&W you can save the file in TIFF format. Unlike grey or color, each pixel can be either black or white only. To scan in black and white you must select right brightness. By doing os you can eliminate background (technically noise) and capture foreground(data)
S. Mohan
Oct 19, 2007 | Canon DR-1210C Scanner
Computers & Internet Logo
37 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
