Question about Brother IntelliFAX 4100 Laser Fax
Send Fax Issue
Recently we had to unplug our 4100 fax in order to cancel an incoming 974 pp document. After doing so we now are having problems sending faxes. Before the machine would press "Fax" and all the documents would scan into memory and then it would dial the number and fax the documents. We could scan several documents to be faxed at a time and not have to wait to scan them individually. How to I reset the fax so we can fax several documents at a time?
Thanks
I have a brother intellifax 770 and I bought it used so their for I do not have the owners manual and I am having trouble setting it up and getting it to work. I can fax out but I just can't recieve faxes I can fax my daughter but when she faxes me she gets an error of 388 but she is able to fax and recieve faxes so we know her end is not the problem.
Posted on Aug 25, 2008
We have a Brother 4100 Fax Machine. When we send a fax or make a copy, there is a black bar about 2" wide that shows up the length of the page. It does not appear on incoming faxes. I believe it is...
Make sure the **** glass is clean, use a micro fiber cloth to wipe the debris/old toner or white out off the glass. restart the fax machine. If it prints this black line from a copy and it is 2" wide after you have cleaned both the glass and the white reference bar, most likley the scanner itself has failed.
www.brother.ca for further assistance.
Jan 14, 2011 | Brother IntelliFAX 4100 Laser Fax
Black strip in documents when I send a fax
If you lift up the top, like you are clearing a jammed original, you should see a piece of glass across the machine. Look for something on the glass, usually white-out, and clean it. Test by making a copy. If copy is ok, then you fixed the problem.
Jul 12, 2010 | Brother IntelliFAX 4100 Laser Fax
Trying to cancel incoming fax on panafax uf-8000
there is a feature called junk fax that will stop all incoming faxes
Jan 08, 2009 | Panasonic PanaFax UF-8000 Laser Fax
FAX 4100. Can't send fax, not sure if I can receive
make sure the phone line is plug to the fax out on the machine do noy know about routers
Dec 20, 2008 | Brother IntelliFAX 4100 Laser Fax
Black line on all faxes I send to recipients
open the document feeder and look for wite-out on the small scanner glass.
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother 4750e
This problem could be Phone line problem, or hardware failure or receiver's (the machine of the person whom you are sending the fax) machine problem and so on. First, let's check the line, if you have another Phone line, please dial from the number to your number, also, connect the currently connected line to a receiver and call a Land-line number, if the outgoing or incoming is ok, the proceed forward, otherwise, you telephone operator should check the line.
Sometimes, sending fax to a particular number doesn't work, to make sure, try sending a fax to another number.
If the line which is connected to the machine is extended from another machine such as Receiver, Switch, etc... unplug them and connect the fax machine directly to the Line.
It's also important to adjust the compatibility mode, to do this, follow the steps below:
  • Press Menu.
  • Press the up or down arrow key to select Fax.
  • Press OK.
  • Press the up or down arrow key to select Miscellaneous.
  • Press OK.
  • Press the up or down arrow key to select Compatibility.
  • Press the left or right arrow key to select Basic (for VoIP).
  • Press OK.
  • Press Stop/Exit.
If you place the scanning document/file on the auto-sheet feeder, you can help it pulling inside the passage or you can use the glass (flatbed) instead. Sometimes, this small mistakes with the sheet-feeder creates this problem. You can also clean the rollers inside the ADF (auto document feeder) passage.
If all of the above measure don't help, I would suggest you to call brother and seek their help. The rest is with mechanical or we can say hardware or firmware related issue. (use this form to contact Brother)
I wish you good luck.
Thanks for using FixYa.
Jun 10, 2008 | Brother IntelliFAX 4100 Laser Fax
CANCELLING INCOMING FAXES
Unplug the phone line and unplug the fax machine. Then clear the memory if it starts printing out again.
Mar 07, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
219 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
