Question about Mitsubishi Televison & Video
Need a part number
Tv mitsubhishi wt 22311 need a vertical ic number
  • 1,031 Answers
Check this link http://www.mitsubishi-tv.com/ service/parts for details on the part number for the ic
Posted on Aug 20, 2008
  • Mitsubishi Master
  • 19,396 Answers
  • Ginko
    Ginko Aug 20, 2008
    wt 22311does not return any mitsubishi TV model double check the model, or get IC details from the Mitsubishi support website above.
Wt is the problem tv is not oning
pl chk ur vertical section ic or tr short replace may b solved ur problem
Apr 30, 2014 | Tvone TV-207 Television
Loss of vertical sweep
Hello
Your TVs vertical output Ic may be damaged. You just open your TV and locate the vertical section inside, usually panasonic uses Ic numbered [LA7837] which will be marked as part number IC451 on the circuit board. It is a 13 pin Ic, sometimes the number may be different in your TV, as Panasonic uses four types of LA series Ics in their sets. I think that you have some knowledge in the service field, so the complaint states only "loss of vertical sweep", and so I'm not going too deep into description. OK.
Nov 06, 2010 | Panasonic TC-21PM10RQ 21" TV
Mitsubishi WS-55857 with a flickering blue edge.
The vertical IC needs to be replaced. You can get new Vertical output ICs at www.tvrepairworld.com and they will also help explain where its located.
Nov 27, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Need the vertical output ic part number for my toshiba 36" model CN36Z71 TV
This set uses the vertical IC part number TA8427K.
Check this website to find the part you need.
Sep 28, 2009 | Toshiba CN36Z71 36" TV
WT-42313 - Won't turn on. TV gives and error code of 24. I found that this is an issue with vertical deflection. I need to know how to repair this issue.
Ck pico fuse F9A05 5amps it will be green or yellow looks like resistor if bad, replace Both STK ICs STK394-250 and 2 resistors R8c13 &14 3.9ohms also resolder all 3 yoke plugins on board.
Sep 20, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi wt-46809
the vertical deflection IC if defective will cause the protection circut not to let the tv power up ,it has a thermal protection circut as well
here is the vertical deflection IC # la78045
and here is a link for the NTE equivalent part and specifications and pin layout
http://www.nteinc.com/specs/7200to7299/pdf/nte7209.pdf WARNING if you heat up any component to long or with to hot of an iron you can dammage the component and or the thermal protection circut
but I believe you will also have to replace the flyback (high voltage transformer ) with wire giving to much voltage
Oct 11, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Convergence
you need to replace both convergence ICs they are STK392-110 you can get replacements at the following link with free installation instructions so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Aug 23, 2008 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-46809 Vertical Deflection Failure
the vertical output IC may need re-soldering or it may be defective and need to be replaced. my guess would be bad solder on the vertical IC.
Apr 23, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WS55511
You will need to change your Convergence ICs and possibly the resistors right next to them. They are located in the very center board of the chassis on a heat sink !C8C01 & IC8C02 . The part numbers for these ICs are STK393-110. If you can solder you can buy these parts for about 10.00 each and takes maybe an hr to solder in. A TV shop will want at least 400. Thats sad but unfortunatly a reality. A service manual may come in handy as it list the locations and proceedures for realighning the colors with the remote, and will list the resistor ratings if they turn out to need replacing as well. You can get one for 10.99 for your set at the following link. They will email it to you if you ask them to. They also offer free unlimited support with the manual. Hope this helps let me know if I can assist you further or if you need to know where to purchase the parts.
Jan 25, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Vertical hold not working
on mitsubishi just replace the caps that are near the vertical ic this will fix the problem good luck
Nov 02, 2007 | Mitsubishi WT-46805 46" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
