Question about Canon CFX-L4000 Plain Paper Laser Fax
ALLOWING FOR A PICK UP ON THE LINE
MY FAX IS NOT ALLOWING ENOUGH RINGS TO GO BEFORE IT DISENGAGES AND GOES INTO REDIAL MODE. I HAVE SOME CLIENTS THAT HAVE THEIR FAXES SET ON 7 RINGS CAN I ADJUST MINE TO LET THE LINE RING A COUPLE MORE TIMES BEFORE DISENGAGING???
I was under the impression this help was free. Your site is very misleading. When I googled Free help you were the first one there and in your description it said free as well. No, I didn't get the problem resolved. But I know in the future not to ask your site.
Posted on Aug 21, 2008
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
I have the fax connected to the phone line with a splitter which is also connected to my portable phone and answering machine. when the phone rings it goes to answering machine if not answered and then to...
The fax machine should have two places on the back where you can plug in a phone cord. One of these is the input: where the cord from the wall goes, and should have either "in" or a picture of a wall phone outlet next to it. The other is used as a line through the fax machine and should have a picture of a phone or "out" next to it. Ideally, you would plug the fax machine directly into the wall and then your phone/answering machine into the "out" plug on your fax machine.
When in auto mode, the fax machine will listen in on the line when the phone rings and if it detects a fax signal (all the whirring and beeping) it will pick up the phone and receive. If there is no signal, it will simply allow the signal to pass through to the phone and answering machine.
Jun 02, 2011 | HP 1010 Plain Paper Inkjet Fax
How do I recieve a fax
This question is pretty vague but I will do my best to answer your question.
  • Make sure the fax is plugged into a working phone jack (cable goes to line port on fax if multiple jacks are on fax machine)
  • Set the mode on the fax to auto (if you want fax to automatically answer fax)
  • Set the mode on the fax to manual (if you want to manually tell the fax to pick up the line)
  • Set the mode on the fax to A.M. (if you are using an answer machine, you will need to reference your operators manual for this as each manufacturer uses different settings)
After doing this call you fax line with your cell phone and see if your fax rings then answers (for auto).
Oct 14, 2009 | Office Equipment & Supplies
My hp psc 2410 photosmart All-Inn-One is not allowing me to receive faxes. It goes through the process of connecting but then says fax failed. I am able to send faxes out and they are received. I am using...
try going into the advanced fax settings and turning off error correction mode. also if you have distinctive ring on the phone line make sure it is set to the right number of rings for the line. ex. fax line is second number set the answer ring type or distinctive rings to double
Aug 08, 2009 | HP PSC 2410 All-In-One InkJet Printer
Our fax will not pickup incoming faxes
The mode is correct. You can check the rings to answer setting. Default is 4 rings. If your phone line is just for the fax try setting rings to 1. Sometimes sending fax machines go into redial before the 4th ring.
Also, sometimes unplugging the power for 10 seconds will clear any memory that may have locked up the machine.
Hope this helps.
Apr 08, 2009 | Brother IntelliFAX 4100 Laser Fax
MFC 7840W, fax not sending or receiving
Is your phone line DIGITAL? Fax machines are ANALOG devices.
Jan 15, 2009 | Brother MFC 7840W Printer
Fax answer phone line
You set the machine up in the answer/fax mode, when a fax is coming in you have to press 9 on the phone to make it receive the fax if you pick up the receiver when it is a fax call.
You can also change the number of rings to answer a fax, I think the max is 7 rings.
Dec 20, 2008 | Xerox WorkCentre Pro 412 All-In-One Laser...
Redial
Go into the admin mode or user mode to reset the default settings. Procedure should be in the op manual.
Nov 15, 2007 | Minolta MF1600E Plain Paper Laser Fax
Machine dials during phone calls
please check if the machine is set to correct answering mode i.e. TAD/FAX ?correct it if otherwise. in case it is ok please check whether the DRPD mode may not be switched off ,pls correct it.. HAPPY FAXING HEMANT GROVER
Aug 29, 2007 | HP 1040 Plain Paper Inkjet Fax
Canon CFX-L4000 Plain Paper Laser Fax Logo
old marine
old marine
