Question about Dacor ECS227 Epicure Electric Double Oven
Dacor ECS227 It appears tha that the electronics cooling fan turns off too soon. While cooking, the control panel facia is cool to the touch, but after turning the oven off, the facia panel gets very hot, almost too hot to touch (60 deg c?). Where is the sensor located? can it be adjusted? What is the part number? Jim
  • jrt12 Aug 21, 2008
    Thanks for comments posted by Ginko, but I had already been on the RepairCLinic.com site. I went back and couldn't find the exploded view he was talking about.
    Also secoiond site suggested; Parts Select site, does not have Dacor listed as parts available.
    I'd really like to know where the sensor is that lets the cooling fan turn off/on after the oven is turned off. ALso for My Model number DAcor ECS227SCH, what is the proper part number for the sensor. And how to tell if the sensor is bad.
    Jim
  • jrt12 Aug 22, 2008
    AS I said before, PartsSelect does not appear to offer anything associated with Dacor ovens, neither parts not exploded diagrams. If any one out there can post th specific link, it would be very helpful.
    Jim
    Master:
  • 623 Answers
How bout this one...
www.dacor.com
Posted on Aug 22, 2008
    Master:
  • 521 Answers
This link has full diagram of each and every part you require and also the reparing tiips you require.
check out this link
http://www.microwavedisplay.com/
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
please rate the solution if helped.thanks.
Posted on Aug 21, 2008
  • 2,071 Answers
Just click below ,you can ask there exploded diagram...
  1. Appliance Parts From PartSelect | Repair Parts For Major Appliances
Hope this may help; Regards,
VOTIT
  • LORETO LACARON
    LORETO LACARON Aug 30, 2008
    Latest updates of the problem!!!
  • Dacor Master
  • 19,396 Answers
On this website you can download the exploded view and find the part list.
Posted on Aug 20, 2008
I try to set the clock on the oven but pressing the CLOCK touch pad or the TIME-TEMP pad has no affect. It is completely nonresponsive.
It sound like the board is faulty, its quite common after power surges can cause damage to small circuit boards like clocks, I would recommend changing it as the clock will also provide timing for switch on at a set time cook for time as well.
http://dacor.com/Search.aspx?query=ECS227 Epicure Electric
Hope this is helpful
Regards
John
Oct 31, 2014 | Dacor ECS227 Epicure Electric Double Oven
F24 code
In some cases I have had to replace both the touch pad and power relay board. Expensive! HOWEVER, I have, on occasion, found the wide ribbon from the touch pad to the relay board to be at fault. I have not found replacements for these as of yet. I have been able to "open" the ribbon to clean the contacts within and reassemble it to find everything working. Needless to say, my clients have been extremely happy with my ability to do so, saving them thousands if having to replace the entire unit.
I found the bad connection when the lighting was dim and I saw a "flash" at the point ribbon it inserted in the end piece. Hope this helps.
Jan 23, 2014 | Thermador Ovens
Im getting this message u60 cooling fan can some one tell me the meaning? Thanks
There is a small fan you should be able to hear blowing when the oven has been hot for a while. The fan keep the electronic controls cooler so they won't be damaged by the heat.
Aug 21, 2009 | Dacor MCS130 Millennia Electric Single...
DACOR IS A PEICE ****
The hi limit thermostat probably tripped during self clean. It can be manually reset. Turn off the power and remove the grill under the control panel. There is a two wire switch behind the door latch press in the red button on the switch. Reassemble and turn on the power. If it works you can reset the cooling fan to run longer which could cure your problem. Press and release upper broil button, press and release the up arrow, then hold down the broil button until it reads COOL 000. Press the up arrow until it reads COOL 200. Press cancel. Done.
Jul 01, 2009 | Dacor ECD230 Epicure Electric Double Oven
COOLING FAN DOES NOT STOP AFTER HOURS
Hi I am Vortash the cooling fan must be controlled by a thermostat , it appears that it has a problem on it and is not shutting off .
They are usually normally open contact switches that are on the top or the side of the oven ,they heat up close the connection and turn the fan on . yours sounds as if it is sticking . Other ovens are controlled by a rheostat a long tubed thermostat that goes to a main control consul on the oven , it controls the fan and responds to what the stat tells it .
It may be this controller is not turning the fan off afterwards , my suggestion is that unless you are electrically trained you get the help of a service engineer to check your oven out .... regards Vortash
Jun 15, 2009 | GE Profile JT912 Electric Single Oven
Our Dacor Millennia wall oven will not heat
There is a manual reset button behind the vent under the touch pad. Turn off the power. Open the door. Remove the vent. Behind the latch is a two wire switch. press the red button on it until it clicks. reassemble and turn on power. It over heated when the power went off by stopping the cooling fan.
Mar 04, 2009 | Dacor MCS130SS Millennia Electric Single...
Display reads U60 Cooling Fan - oven won't heat
I got Dacor to give me the number sequence -- - push "cancel" and "#" at same time - when screen asks for "service ID" enter "S1234" (get "S" by pushing "7" 5 times) - screen will list "U60 Cooling Fan" as number 1, so select "1" - select "clear all", this should clear the error - hit "cancel" to get out of that screen
Hope this works for you! Best suggestion I have is DON'T BUY DACOR!! We also own their 30" dishwasher, which has been a nightmare experience as well.
Apr 09, 2008 | Dacor ECS230 Epicure Electric Double Oven
Control panel fan won't turn off
Is the oven still hot?? this is a Electronics cooling fan it will run even after the oven is turned off give it some time it should shut off let me know if not
Jan 26, 2008 | Dacor Epicure 30" Double Wall Oven,...
Exterior surface of oven gets hot when turned off
What do you mean by very hot? Is it too hot to touch? Hot enough to sizzle when a drop of water is put on it?
Oct 06, 2007 | Dacor MCS130 Millennia Electric Single...
Dacor ECS227 Epicure Electric Double Oven Logo
211 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Paul Bade
rjbeg123
Are you a Dacor Oven Expert? Answer questions, earn points and help others
