Question about Igia X-Press Turbo 6754 Iron
Iron housing is melting
The iron spits and leaks when it has water in it. the plastic housing around the top of iron has turned brown and is melting.
Only paid $19.95 for it, Not going to spend more than $3.00-4.00 to fix it so it has gone the way of the circular file.
Posted on Aug 21, 2008
Tip
My Steam Iron is Leaking Water
If you are having trouble with your steam iron leaking or dripping water, then this tip is for you.
The first thing to remember is that the wrong water can cause you many problems with your iron. If you are experiencing problems, one of the first things to try is to use different water in your iron. Steam irons need a certain amount of mineral in the water for them to operate properly, but too much mineral, iron, or organic matter can be disaster.
Too much will cause all sorts of problems. Brown water, white scale and other problems will come from the wrong water. The wrong water will also cause the iron to corrode and leak. Of course not taking care to store the iron properly will also cause corrosion and leaks. See my other steam iron tips on the brown water and white scale issues.
So, if you are having problems, you must first figure out if it is bad water causing the steam iron to spit the water out of if in fact you have a leak internally. Internal leaks are not repairable. They are often caused by a combination of poor water quality and not drying the iron properly before storage. Either of these can cause internal corrosion and lead to leakage. Make sure to use good bottled spring water and empty the iron before storage. Lay the iron horizontal for a few seconds while hot to dry the remaining water from the tank before storing on its heel.
Poor water quality can also cause the iron to spit the water back out the wrong places and give you the impression that you are leaking, when in fact you are not. Water that makes steam too rapidly, will spit out all over the place and will not want to stay in the tank and make steam. Before assuming that you have a bad leaking iron, try using different water first. You may also need to follow my tip for cleaning the water tank of your iron, so that the different water can be effective.
In short, the wrong water can cause many problems when it comes to steam irons. Do some experimenting before you buy another one only to soon have the same problems all over again.
on Jul 14, 2010 | Irons
Tip
Cleaning a Steam Iron White Scale and Brown Water
If you are having problems with your steam iron spitting out brown water or white scale all over your clothing, then you need to read this tip.
Both of these problems are caused by poor quality water being used in your steam iron.
The problems are different in that they are caused by two different types of poor water quality. The brown coloring of the water is usually caused by organic matter or iron mineral in your tap water.
If you are getting white scale on your clothing from your iron then it is usually because of calcium or other minerals in your tap water.
Either of these problems can also contribute to spitting or leaking of the iron when in use.
To clean the inside of the iron you must first empty all the water from the iron. Then fill the iron half full with bottled spring water and then fill to full with vinegar. Run the iron at its hottest setting for 15 minutes and then drain the solution. Fill again with just the bottled spring water. Reheat and then empty. After removing all of the water, turn on the iron and let it sit in the horizontal position for a few seconds to evaporate the last of the water. This will not hurt your iron, but will remove all the moisture before storage.
To keep your iron working well, use bottled spring water, and remember to remove all water before storing your iron. Always allow the iron to cool and store it on its heel.
Using the right water will prolong the life of your iron. Commercial de-scaling cleaners are hard on the inside of the iron and can cause leaks. Do not use distilled water, as it is too pure and will not produce much if any steam.
Iron spits and leaks a lot of water when turned on. water will leak even around the handle
You need to clean it out, try a solution of white vinegar and water, if you can plug it in outside, do it. It usually is caused by tap water being stored in the iron and not emptied each time you use it. Once you run the vinegar solution through, rinse it out with distilled water, now only use distilled water in it plus empty it completely after each use. My iron is 40 yrs old and do this and never have a problem. I had wrecked other irons leaving tap water in it, so I know the problems it causes. I am hoping this will work for you, good luck, because it is cheap and worth a try.
Apr 15, 2011 | Rowenta Perfect Iron
My Rowenta Expert steam generation iron (seperate tank for the water type) is starting to spit ever so often brown water out. I only use filtered water. How can I clean the actual Iron, the water tank is...
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Mar 16, 2011 | Rowenta DG-980 Iron
Brown water spitting out of bosch steam iron
Brown water and white scale are often the result of the water you use in the iron...
heatman101
Feb 03, 2011 | Bosch TDA8340 Iron
Dirty water in my iron
The dirty water coming out of your iron steam holes is caused by the accumulation of 'dirty' tap water: if you look inside an eletric kettle, you will see the same 'dirty' muddy brown mineral residue on the inside. In addition, if your iron is old, it can also be rust. It is a pretty common problem that can be minimized by using distilled water. You can get commercial steam iron cleaning fluid to clean the inside of your steam iron or you an simply use vinegar: 1) with a cold iron, fill the reservoir with straight vinegar 2) Place your iron on top of a metal kitchen rack above your kitchen sink, turn iron on and let it steam out all the vinegar: it should spit out the whitish mineral and muddy brown deposity. 3) Refill iron reservoir with clean water and repeat as of step 2. 4) Refill iron reservoir with clean water, wipe any dirty from the sole plate and this time on full steam, iron on clean layers of Kitchen paper to ensure that all dirt has been removed from the inside of the iron reservoir, if not, repeat from step 1 again.
In the future, try to use distilled or at least filtered water.
Hope it helps: let me know how you go!
Feb 24, 2010 | Bosch TDA8340 Iron
Melting plastic from the housing is leaking from the base.
Irons heat up to 410° on the cotton setting.  If yours is leaking, it could be the sealant from inside.  If it was ever repaired, the wrong type of sealer was used.  If it wasn't repaired, it is overheating and needs repaired or replaced.
Are you sure a crayon wasn't put into the opening?
Jul 09, 2009 | Sunbeam Heritage 4264 Iron with Auto...
Iron spitting out brown water
I'm afraid the brown water is rust if it is I would chuck the iron and buy a new one.
If it's just scale then mix "Lime Away" 50/50 with water pour it in the opening where you put the water in for steam, turn it on low and let it sit for a few hours, rinse it three or four times and then try the steam again.
Feb 26, 2009 | Irons
Igia X-Press Turbo 6754 Iron Logo
66 people viewed this question
Top Igia Irons Experts
Are you an Igia Iron Expert? Answer questions, earn points and help others
