Question about HP Office Equipment & Supplies
Cannot scan anything - HP Office Equipment & Supplies
My HP deskjet F380 doesnt scan. How should I fix it?
thanks....
Posted on Sep 14, 2008
Why does my Canon Mf 8380 scan anything handwritten very faint and non legible
Is the handwriting black ink? Colours come out poorly on most scanners.
You need to increase the contrast when scanning handwriting.
Jul 07, 2014 | Canon imageCLASS Office Equipment &...
I cant seem to scan anything using my MP190 printer do i need a program or anything like that?
you need a program that can scan and the scanner driver...do you have any software from the device...should have a scanner program...if you have the driver installed, usually a twain driver then any photo editing program can usually scan...
Feb 08, 2011 | Office Equipment & Supplies
It just scans and scans it never picks anything up. No clue how to work this scanner or where to get codes for it. When you turn it on, it just scans thru all the channels but doesn't seem to pick anything...
Sounds like either your squelch is set too high or you don't have the proper frequencies for your area programmed into the scanner. When it starts scanning turn the squelch down gradually until the scanning stops and you hear noise, then turn up slowly until it starts to scan again. If you still don't pick up anything, you probably need to reprogram the frequencies. For a list of active frequencies and systems in your area visit
www.RadioReference.com
or
www.CityFreq.com
In case you need it, here's a link to the manual for your scanner.
If you have any other questions, please contact us again.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 26, 2009 | Radio Shack Pro-2051 Base Scanner
Code error ffff:0024
While I am trying to scan the images, I am getting the error Code[ffff:0024] & I am unable to scan anything from Epson 1500 model. While I switch on the scanner, it sounds lot from the scanner for continuous 2 minutes. I couldn't get scanned anything ... please
give me the solution.
Mar 30, 2009 | Acer Scan to Web 3300U Flatbed Scanner
Black line down the middle of scanned documents.
Try leaving the cover open and run a test scan, once with a fresh sheet as the item to be scanned and then a second time without anything on the table.  You may see what is blocking the light source or possibly a defect in it.
Scanning is done left-right, left-right across the width of the page and the vertical stripe indicates that the blockage is present during each scanned line.
In servicing copiers and multifunction machines, I have found a number of curious contaminents, one of the most annoying was a moth, still alive, that would randomly sit on the lamp, causing some pages to come out OK, others not.
If your copies and printouts are coming out fine, then only the scanner can be at fault.
Jan 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
I want to scan
I got it to scan. I found this by the grace of God. I have the same problem with the print cartridges. But I was attemting to get into my camera. I went to the 'My computer' Icon on Windows XP. Under that part of the file system, I have the "HP PSC 1600 series" icon under the scanners and printers. I double clicked this, and it allowed me to scan an image.
May 09, 2008 | HP PSC 1610v All-in-One Printer
"Scanning in progress" reported even when I'm not scanning anything
You need to install the print driver and Sharpdesk before you connect the USB cable.
Dec 10, 2007 | Sharp AL-1642CS Copier
185 people viewed this question
Seeker5211
Seeker5211
