Question about Sony Playstation 3 (PS3) Console
Scart to HDMI
I recently took my ps3 to a friends and reset it to output via scart.
On returning home and plugging in the hdmi lead; I now can not the screen through hdmi.
Whilst the scart is still plugged in I've tried to reset to HDMI, but this has been unsucessful; although the ps3 detects the hdmi is plugged in.
HELP???
Goodnr10
Press and hold your power button for a few secs until it beeps, do it again.This resets all of your settings.You just need to set everythin right again
Posted on Aug 21, 2008
Hi, I have a Funai vhs dvd combo recorder model drv-b2737 and would like to know how I can set this up with my flat screen tv and what cables would I need to accomplish this. Thank you
This has no HDMI socket so you have a choice of either SCART or SVHS depending on what your TV has. If the TV users HDMI you might want to consider a SCART to HDMI adapter lead.
http://www.ebuyer.com/133106-startech-com-6-ft-hdmi-to-dvi-d-cable-m-m-hdmidvimm6?mkwid=sWA3N2WiH_dc&pcrid=51630194939&pkw=&pmt=&gclid=Cj0KEQiAyuPCBRCimuayhb3qqvwBEiQAgz62kTtKa_YG_1esIQiPgik-Xm5AFxuGZI25r11jA5KJOFwaAjJj8P8HAQ
Plug the SCART to TV in the bottom SCART not the top one!
If you just want a SCART to SCART make certain you get the highest quality ones you can find.
There is an OPTICAL output for the high quality sound. You can connect this via an OPTICAL lead to either a Surround Sound unit if you have one or direct to the TV. Again if it has an OPITICAL lead.
If using make certain the output it is switched on at both ends. You will see a red light if the TV is outputting it, with it unconnected to the VCR.
Dec 20, 2016 | Funai Televison & Video
Rdr dc90
Your recorder is mostly analogue with just a hdmi output, you need to link up using a scart lead or similar adapter lead for recording, looks to me like scart 1 (decoder) or the front sockets for input use while. the other scart looks to be just for TV to use.
If your TV has another hdmi then I would have thought your sky sat would connect that way leaving the scart for your video.
Though if it has only one, then you are looking at a multi input box for hdmi (some are automatic others have remote control) or demote your video's hdmi lead and connect it to the Sky sat, use the scart lead to link it with the video's scart 1 and the other scart socket to TV by the look of things.
Its a problem with older and younger equipment because they are built at different times with their connections decided by that time of manufacture.
Hope this helps..........
Sep 26, 2017 | Televison & Video
Just bought a ps3 secondhand but no scart lead do i need one?
You don't need a scart lead for your ps3 if you have a HD television. All ypu need is the HDMI cable (which is not included with a new PS3 but you can get very cheap from Ebay- don't bother with 'gold plated' or other 'high quality' cables as they are all the same output quality). The HDMI carries audio and video to your HD television, but you can use a scart lead for audio if and the HDMI for video if you want to use external speakers. The ps2 scart cable also works for the ps3 if you don't have a HD television. (note: a HD television is highly recommended because the quality is a hundred times better). Mine is a Samsung HD monitor which you can buy fairly cheaply.
Jul 28, 2011 | Video Game Consoles & Games
I have a JVC RM-C60 TV. I'm trying to tune it in to my Virgin Media HD box using a standard SCART lead but having no joy. It's completely failing to find the cable channel (or any other for that matter)....
Tuning of the TV not required when using scart lead, just select external input that the scartis connected to, ie AV1,AV2 (EXT1,EXT2) etc. The problem is possibly to do with the Virgin box, it may be set to HDMI out in which case it will not output anything via the scart lead, you would need to connect via an HDMI lead (small socket on the rear of the unit looks a little like a USB socket). Problem is if your TV is a CRT television its unlikely to have this socket. Your Virgin box can be reset to output via the scart but you would need to contact Virgin for this process.
Feb 17, 2011 | JVC Televison & Video
When the display is via HDMI Games won't load, the screen will alter as if loading the game then it will flicker and go black.... But it plays Blu Ray Movies fine...? I then have to restart the system and...
It's a bit of a pain as you'll have to re-establish your initial internet setup ( this is where keeping old passwords, etc, comes in handy ! ), but the only solution that will work is by resetting your PS3 to ' first time use ' ( not back to factory condition though ).
This may be an unwanted slog but if you've accidently changed the settings and can't remember how or why at least you'll know the initial sttings should work.
If you don't want to do this, try going to the screen settings and adjust one at a time ( loading a game in between ), also if you have a scart lead fitted ( as well as the HDMI lead ) make sure it's in the audio out and not in ' video ' ( the audio out will be a circuit between an audio scart socket on your tv and the red and white leads going back to your audio output device : active subwoofer, etc , the yellow lead plugs into the scart lead from the console via a plug point adaptor which goes straight into the scart on the tv set ).
AV Multi Out should not have to be performed as the leads out devices are the only ones which should be pressed to set.
Hope this helps.
Jul 24, 2009 | Sony Playstation 3 (PS3) Console
No input signal HDMI
turn on and hold down the on/off button for thirty seconds when it resets it will load up via hdmi lead this works both ways going from sd to hd, failing that have both connections plugged in both scart and hdmi lead then change the settings to hdmi when viewing through scart connector then flick to hdmi input and hey presto its worked.........
Nov 09, 2008 | Sony Playstation 3 (PS3) Console
No sound or display
go back to your friend or another with a hdmi tv then connect the ps3... when connected go into the menu for display and switch output from hdmi to scart it should then work on your tv
Oct 24, 2008 | Sony Playstation 3 (PS3) Console
I have had my ps3 connected to my hdmi lcd but now when i connect via the scart plug on an older tv no picture appears how do i sort this
This is because your PS3's Display Output it set to HDMI, therefore the SCART isn't active. I believe the PS3 has a video reset. This should be how it's done:
1. Shutdown your PS3 if you haven't done this yet.
2. Press and hold the powerbutton. It should beep once for power on and shortly afterwards beep again.
You'll have picture on the other cables and the resolution is reset to 480p. You can change the settings now.
You'll probably have to do this again when you plug it in to your LCD with HDMI again.
I hope this helps, please don't forget to rate.
Greetings,
DarkNeogen.
May 22, 2008 | Video Game Consoles & Games
Hi I recently played my ps3 on my friends tv using an hdmi lead and all was fine. Now i have returned home and tried to play my ps3 without the hdmi lead and it wont work can you help please.
go back to your friends with your ps3 and change the tv settings on the ps3 back to scart output but also take your scart lead and have it plugged in at the same time. once you have selected scart output unplug the hdmi cable to make sure the settings are right. hope this helps you.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
78 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
