Question about Philips 50P8341 50" Rear Projection Television
Philips 50P8341 Does Not
I am having a problem with my tv when i turn it on the tv buttons on the front turn red but the screen does not get power all it sounds like it juice ups i get is a green line going across the tv no sound black screen me and my dad opened the tv he has some experience with tvs as he studied for electrician but that was long time ago so he is not sure of the solution.
  • 4 more comments
  • dtmsinc Aug 20, 2008
    a few weeks ago we used to turn on the tv and it will show a white screen then went black
    after taking it to the tecnician he told me the job was going to cost me $600 so of course i did not agreed
    after that when we turned on the tv we can hear the sounf of the tv juiceing up but i get a black screen and a green horizontal bow down line
    Thanks for your time
    HOO AND PLEASE I DONT WANT THAT GUY FROM MAGNAVOXHELP.COM TRYING TO SELL ME HIS PRODUCT AS IF I DIDNOT KNOW THAT THE IC COST $5.99 AND HE IS TRYING TO SELL THEM FOR $32
    THANKS
    PS
    IF THE IC IS THE PROBLEM PLEASE LET ME KNOW (NOT U MAGNAVOXHELP)
    THANKS
  • dtmsinc Aug 21, 2008
    Hi
    could you please tell me where are the vertical output IC and if they the same as the coverange ic
    Thanks
    hi
    i was not able to find the diodes and the resistors by the numbers you guys gave me please let me know where they are my tv model is a 50P8341 and the chasis number is ptv915
    Thanks
    Hi
    i think i have a 31350133199.7 and the white sticker says 313501705281 Please look at the pictures any help or advice is apreciated as you can see i have also taken a picture of the crts the crts turn on but there is no strong light in them i can see the on because i can see they show a little light for each color from the bottom area
    Thanks
  • dtmsinc Aug 22, 2008
    Hi
    i did found the resistor 3661 and did found that the ssm its 31350133203.9 but i was not able to find 6003 6012 6025
    or 6809 6810 i did also found fuses 1800 and 1801 on the pip card but there was just a space there was not a fuse i also looked in the lsb and nothing
    any help is appreciated
    Thanks
    dtmsinc gmail.com
    Problem Solver:
  • 53 Answers
Hello dtmsinc:
Possible cause is a defective vertical output. Check fuses 1800 and 1801. Also check diodes 6809 and 6810. If there is High Voltage then replace Diode 6003 and Resistor 3669 when replacing the above parts also replace Diode 6012and Diode 6025 your dad should be able to help you.
Posted on Aug 20, 2008
  • 138 Answers
Have some one with experience on repairing tvs try this and it will determine wich board is bad and the you can go to www.tritronicsinc.com for the part.
Have them unplug the connector from the LSB to the SSM (the plug that feeds the voltage to the convergence IC’s, toward the front of the set) If the H/V comes up replace the SSM. If the H/V don’t come up unplug the CRT’s from the H/V generator. If it comes up see which CRT is bad if not replace the LSB first and the SSB if that doesn’t work.
  • 3 more comments
  • Lawrence Smith Aug 20, 2008
    I don't think it is the IC but I just remembered something else. If the set do have high voltage. Have them check diode 6003 with part number 934055352115and Resistor 3669 with part number 482211711503 when replacing the above parts also replace Diode 6012 and Diode 6025 with part number 934055352115.
  • Lawrence Smith Aug 21, 2008
    The vertical IC's are on the large signal board and they are not the same.
    They mad two version of this board. To find which version you have look at the top of the board for 31350133203.9. These parts will be found on board revision .9 only. This does not apply to any other versions. They are located at D-4 on the bottom of the board close to plug 1083. Diode 6003 is labeled however resistor 3669 is not, it is located next to pin 10 of plug 1083 and is the first part between pin 10 and the edge of the board.
    I looked in the schematics and the resistor is not 3669 but is 3661 and it is on the SSM that is the board with the av connectors on it. And it is 6025 is also on the SSM.
  • Lawrence Smith Aug 22, 2008
    I looked in the schematics and the diodes next connector 1083 on the SSM which is a 10 pin connector. And I looked in the schematics and found 6809 and 6810 on the LSB.
When you push the power button, the screen flashes a picture, and than goes dark. The power button stays solid red.
Two probably solutions:
1.-- SSB need be replace
2.-- Convergence IC's need be replace.
You need to have electronic skills. is hard to do this work.
Be careful, try to find a TV shop for help.
Thank you
Aug 15, 2011 | Philips 50P8341 50" Rear Projection...
The on and off switch will shut the TV off after
my philips rear projection tv shut down within 1 minute when on rolling the letter av from up to down and curved uo and down also have red lines in screen
Sep 01, 2009 | Philips 50P8341 50" Rear Projection...
How do I replace the Vertical Output IC
Replace the Small Signal Board Part #313912725871
This is a common problem withis TV.
Jul 30, 2009 | Philips 50P8341 50" Rear Projection...
Problem with tv 50p8341 might have found the solution
The green line across the TV if its in the middle is usually loss of vertical deflection so that can shut the tubes down for protective purposes. Check the vertical output IC thats what is most likely causing the problem. The flyback is working if theres a green line across the middle of the screen.
Aug 20, 2008 | Philips 50P8341 50" Rear Projection...
Phillips model 50p8341 titanium-finished 50-inch Red tint to picture
Your Red CRT may be on its way out. Try turning down the G2 screen control on the red CRT just a little. That should help for now. A new red tube wil be a reality in the future.
Jan 21, 2008 | Philips 50P8341 50" Rear Projection...
Blue screen with sound but nothing else!
I, too, acquired a Phillips without a manual and was experiencing a similar problem. My model is PTV 916, but if your TV has a "source select" button, say a prayer and press the button. From that point, I don't know what else I did, but I do get TV programs now.
Jan 04, 2008 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 50 in. Rear Projection Television most of the color is red
Usually if you remove the speaker grill in front there is a convergence panel that can be carefully removed. If you look inside you should see a small rectangular block with six controls. They are labelled focus and screen, and red, blue and green. Adjust only the screen controls very carefully and slowly. I would recommend reducing the red slightly brfore raising the green and then blue until the picture looks acceptable. Be sure to center the on screen controls before starting.
Nov 18, 2007 | Philips 50P8341 50" Rear Projection...
TV not working...no picuture, no sound
your tv needs to be taken to a tech the problem is on the IF module the tuner is also on that module.you can get parts at www.dalbani.com or www.repairworld.com and service manual try www.partstore.com.good luck
Apr 18, 2007 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
451 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
