Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Sony KDF-42WE655 watching tv last night and I heard a pop and tv went blank.The power button just kept blinking green.I unpluged the tv from the wall and let it set for a minute.When I plugged it back in the light turned red and flashed 5 times and paused then flashed five times again.I replaced the opticle engine about a year and a half ago.Could this be related?
  • 320 Answers
Bad lamp and/or lamp driver. Try replacing the lamp first.
Posted on Oct 18, 2008
SOURCE:
I have a Sony KDF-42WE655 was watching it then heard a pop then no picture or sound the led on the front blinks red and green?
Check the lamp of your television. It is possible that the lamp came to its end, to confirm if the lamp is busted, pull the lamp out and for you to see the if lamp filament is broken. if it does, you need to replace the lamp.
Feb 16, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a 60" Sony
It seems lamp/ bulb popped again, check lamp inside tv.
If tv does not show red blinking light then it would be lamp that knocked off, replace lamp in tv to fix its problem, please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Jan 15, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
No Video/Sound,POwr Gren LiTE Blinks 4Ever, SONY WEGA KDF-55WF655
Please check lamp in tv as pop sound seems broken lamp.
Did you replaced lamp in last 2-3 years in tv? If not, then its lamp that got broken and tv needs new lamp.
Lamp replacement procedure is written in user manual and its easy, please buy Sony original lamp for good picture in tv.
Thanks.
Apr 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Black spots on the screen
CHANGE OPTICAL UNIT BLOCK COMPLETLY
Jan 30, 2010 | Sony KDF-42WE655 Television
I have Sony TV model KDF-42WE655 which stopped working. No display and when powered on, the green light comes on and blinks approx 50 times and turn red (blinking red). How and what do I need to buy to fix...
Its not the green light that you should be count but the red. How many times is it blinking? Here is a quick update of the errors that are most common.
3x - Lamp switch not engaged
4x - Fans issue
5x - Lamp
6x - Thermal fuse
Dec 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have a KDF 42WE655..while watching tv, I heard a popping sound.
If the lamp is blowing that soon, the cooling fan is not working, or is plugged with dust. I have heard some people have a filter that needs changing or cleaning. Check your manual. The cooling fan is on the optical block and not easy to get to.
Probably a job for a tech.
Aug 18, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Turned tv on, heard a pop, no picture, standby light blinks conti
POP goes a fuse in your power supply or maybe even a capacitor you need to have this repaired unplug this immediately. Take it to a local repair shop to have it fixed.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 03, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
419 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
