Question about LG 42PC3D 42 in. Plasma Television
Hdmi port i have no sound when using the hdmi port, but picture is fine? i have tried other tvs using the hdmi cable , so cable is functional. any body else have this same problem? when i use the av1 port sound and picture are fine.........
  • Anonymous Sep 19, 2008
    Picture but no sound on HDMI.
I have a 50 inch and recently had to have the main board replaced d/t the IR receiver was failing intermittently. Since they replaced the main board, one of the two HDMI is doing the same thing (picture, no sound). When I spoke to service they felt the issue was related to the replacement board and will be replacing. The weird thing is the picture is not quite right + no sound. Usually with HDMI it's either all OK or not OK at all. In any event, my problem seems to be the main board.
Posted on Oct 09, 2008
Hitachi L42S02A no sound through HDMI
I've had a few HD TVs that you could disable/enable individual ports on the TV in the Settings menu. Good luck.
Jan 28, 2018 | Hitachi L42S02A 42" Multi-System LCD TV
Lg 42" plasma
It may be that your cable box is outputting at a resolution your TV doesn't recognise or doesn't support. Do you have any other connection you can use from your cable box to your TV to check the settings?
Nov 18, 2017 | Televison & Video
No picture
Its certainly possible there may be something wrong with the port itself but first, I would try swapping out the hdmi cable itself to rule that out. It may also be the video board in the receiver. Can you get video out by using RCA cables instead of HDMI? Maybe try that first.
Jul 27, 2012 | Insignia - 450W 5.1-Ch. A/V Home Theater...
It seems has if the HDMI port on my Scenium is going bad. For quite a while, it would occasionally turn people's skin blue. Pulling out the HDMI cable and reinserting it would usually correct the...
hi,
Your TV didn't have any HDMI port. Do you mean the DVI port. do you use DVI cable or DVI to HDMI cable.
The only way to check whether the DVI port is working or not is by replacing the cable. purchase a new cable and try again.
ok
Jan 31, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
How do i change from 480i to 1080 on my Toshiba 52HM95 DLP im trying to hook up my playstation 3 with an HDMI cable but it wont switch over to 1080i
Most TVs choose the resolution based on the signal coming in. Be careful if you try and use 1080P. Not all TVs support it. 1080P is only on HDMI. set the playstation to 1080i before connection.
Some TVs and Playstation HDMI do not mix well due to software in the HDMI ports. Try RGB cables.
Apr 02, 2010 | Toshiba 52HM95 52" HDTV Projection...
Hitachi l42vpo1u no sound through hdmi
HDMI port damaged, mainboard need to be replaced.
But be absolute sure your HDMI port is not working properly, I recommed you try it again with another HDMI cable, you can also try same cable in another TV.
Bye
May 18, 2009 | Televison & Video
Xbox 360 sound problem
HDMI carrys no sound you still need to have the audio cables from the component plugged into the tv. If this doesnt do the trick you should call MS or check your TV's settings maybe there is a special function when using that resolution. Hope this helps.
Jan 02, 2008 | Microsoft Xbox 360 Console
LG 42PC3D 42 in. Plasma Television Logo
285 people viewed this question
Computer Repairing
Computer Repairing
