Question about Elmo Projectors TRS-35XG 35mm 80 Slides Rotary Carousel Slide Projector
Elmo slide to video projector
I recently purchase a TRS-35XG slide to video projector. I have tried hooking up the projector to my TV using the RCA output and have tried using the S-Video output and both times all I get on the TV screen is a double/blurry picture that only displays in a the bottom righthand 1/3 of the TV screen. How can I get the picture to display full screen and get rid of the double or shadow effect? I have also hooked it up to a computer monitor with the RGB output and get a picture in the center 1/4 of the screen and the monitor flashes on and off. The previous owner claims to have had it hooked up to an LCD projector and it worked fine from all outputs. What could be wrong?
  • 2,237 Answers
Check the resolution. is your tv hd? the projector may not be.
Posted on Aug 19, 2009
Can i convert to a dvd i have a trv-35h elmo
You can very easily. You may use the S-VHS output on your Elmo ( a 4-pin DIN socket on the rear) going into the S-VHS input on your DVD player. You will need an S-VHS cord. Very cheap at Radio Shack or on Ebay. This gives the best quality. Our you can use the more familiar RCA composite video output (yellow socket) from the Elmo into the composite or auxiliary input on the DVD recorder.Be sure you have selected the proper input on your DVD recorder. Use a TV set as a monitor so you can see what you are recording.When I convert slides to DVD, I do a test run through the carousel to be sure the slides are all facing the right way, not upside down or backward.I set my Elmo timer on 5 seconds and let the carousel advance automatically. You may want to zoom in or color correct as you convert. In that case, pause your DVD recorder between slides, make your adjustments, then resume recording. This is called assembly editing. It works very smoothly and you get a better show,
Oct 28, 2011 | Elmo Projectors TRV-35H Slide Projector
I bouht an old Elmo but the lens seems to be missing. How does this projector project anyway What sort of lens system? Thanks to whoever answers
The TRV-35 series are not slide projectors in the normal sense. There isn't a projection lens to enable an image to be projected on a wall or cine screen. The unit is a digital convertor for producing an image via a TV or PC.
Aug 11, 2010 | Elmo Projectors TRV-35H Slide Projector
Need to upgrade video camera in an Elmo TRV-s8
Not sure if that can be done but give Elmo Service a call.
Feb 23, 2010 | Elmo Projectors TRV-35H Slide Projector
Shows a blue screen
Make sure power is plugged in and power switch set to on.
Make sure TV or projector is plugged into video out.
Make sure the input switch is set to Main and not video in.
Nov 20, 2009 | Elmo Projectors EV-200 Slide Projector
What size tray doe the Elmo TRV-35H use? What mfg is comparable?
It uses a standard 80 slide Kodak Carousel or comparable tray. Transvue works the best. Sometimes I can coax the Elmo to use a 140 slide tray, but the slides sometimes jam.
Sep 17, 2009 | Elmo Projectors TRV-35H Slide Projector
Forgot how to use it!
Try Elmo's website. Google Elmo TRV-35 H. A PDF of the user manual is available free for download.
Apr 07, 2009 | Elmo Projectors TRV-35H Slide Projector
ELMO document camera only shows documents in black and white, not color. Is there something wrong with the bulb? the camera?
My ELMO unexpectedly stops working during class. The blue power light is still lit but the ELMO is not recognized through my projector.
Any suggestions on what the problem may be?
Mar 25, 2009 | Elmo Projectors EV-200 Slide Projector
My ELMO video presenter is not working. When I connect it to the video projector via s-video cable, it no longer shows an image, but the projector recognizes there is a signal. It recently fell off of a...
you'll have to check the elmo usa website. you can either send it to elmo themselves, or to one of their authorized service centers (website). if the camera itself is damaged, it's pretty expensive. it may just be the s-video socket.
Dec 11, 2008 | Elmo Projectors HV-8000SX Slide Projector
Need software
Try Windows Vista it sounds very powerful.
Mar 08, 2008 | Elmo Projectors TRV-35H Slide Projector
Elmo Projectors TRS-35XG 35mm 80 Slides Rotary Carousel Slide Projector Logo
221 people viewed this question
Top Elmo Projectors Office Equipment & Supplies Experts
Are you an Elmo Projectors Office Equipment and Supply Expert? Answer questions, earn points and help others
