Question about Hotpoint WMM65 Front Load Washer
Hotpoit wma64 fins inside drum keep snapping off is this a design fault
  • 139 Answers
This is a common faulton this model of machine, and is easily replaced by yourself. theres two types of these blue fins used in the machine so be sure you know which one it is,, there is a version 1 and a version 2.. if your in the uk you can purchase these from a company called connect distributions type it into google to get further details....
Posted on Aug 20, 2008
SOURCE:
My hotpoint washing machine wma64 will not spin
Dear Blaze,
Here is a link for a service manual Hotpoint WMA64 Installation And User Instructions Manual
The drum motor, its brushes, the belt, or idler arm roller, and the drum roller bearings can all be suspect. Here is a link that supports the statement Hotpoint Ultima Extra Wma64 Drum Not Turning E32 Fault Code Hotpoint...
Here is some conversation not relevant to your statement but maybe associated later on Faulty Hotpoint WMA64 DIYnot com DIY and Home Improvement .
I suggest when it is repaired to do a service wash to clear the drum of buildup.
Fare. Well.
Dec 28, 2014 | Hotpoint Washing Machines
My hotpoint WNA64 has been making loads of noise during the spin cycle now the belt has snapped are the two conected?U
I say so think its drum bearing failure common on this machine is the drum noisy on its own try a hand turn and see could also be a sock stuck in it if not free....Please leave feeddback
Apr 08, 2010 | Hotpoint WMA64 Front Load Washer
Do you have to take the motor out to fit new brushes on a hotpoint wma64
Remove lower rear panel of washer.
Remove drum drive belt.
Unplug lead to motor, remove earth wire.to motor.
Locate and undo 2 screws securing motor to drum chassis.
Lever motor backwards to remove from mountings, keeping hold of the motor so it does not drop.
Remove old carbons at opp end to motor pulley.
Mar 13, 2010 | Hotpoint WMA64 Front Load Washer
Hotpiont wma62 not washing
check the motor brushes and connections to the motor the fault is logged as motor action fault.
Jul 12, 2009 | Hotpoint WMA64 Front Load Washer
WHERE IS THE FILTER
this sounds more like grease marks rather than sludgy marks,i bet you the bearrings have worn out,check this out by opening the door and the silver drum inside will have a knocking noise as you lift it up and down,when bearrings have worn out this causes a sludgy diposite,rgds,paul
Jul 07, 2009 | Hotpoint WMA64 Front Load Washer
FIn inside neptune md55 dryer came loose need to remove side pane
I had the same problem but it's the FRONT Panel you need to remove. Before you start, unplug the thing first. BTW I did the whole proceedure in 10 minutes using an electric screwdiver / philips bit and a socket set with an 8mm socket with my leg in a cast. You can do better, I'm confident!
Two 8mm hex head bolts hold each fin on the drum. They can be tightened. You need to open the dryer front since they bolt from the outside of the drum. To open the dryer front you first take the door off by removing the two philips head screws, then slightly lift the door and pull toward you (the door hinges have little hooks on the end that inserts into the slots (this little design keeps the door from falling off during removal and install-nice). Then remove the two philips screws on the other side of the door opening (opposite the door hinges). These screws hold two plastic brackets (be sure to see how they are aligned before you remove them so you know how they go back on.
Now the front frame panel looks like an "H" . Grab the top two arms of the 'H" and give a quick ****. The top arms of the 'H" will come loose. The bottom part is held by a couple of clips, just pull up and the front panel comes off.
You will be able to spin the drum until the hex bolts for the fin(s) in question are visable / reachable from the right side (just above the heater unit-hope you unplugged the dryer earlier). I tightened it using an 8 mm socket.
Now reverse your steps: put the front panel back on the bottom clips and snap the top "H" arms back in place. Reinstall the plastic clips / screws and then put the door back on.
Feb 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Replace belt wma64
Remove top cover, tilt m/c towards you, this gives you more space to work in, and slip belt over motor pulley first, then gradually ease belt over drum pulley turning the drum with the belt,until it is on.
Keep your fingers from getting trapped as the belt is very tight
Sep 15, 2008 | Hotpoint WMA64 Front Load Washer
Hotpoint WMM65 Front Load Washer Logo
62 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
