Question about Altec Lansing ADA995 Speaker
Altec Lansing ADA995 does not work
Came with Dell desktop. Stopped working. Got nothing when checked using the rear panel diagnostic jack. Fuse is good. I need a schematic of the subwoofer assembly. Any ideas? Thank you.
  • Anonymous Oct 04, 2008
    Might as well kiss these speakers goodbye. I inherited a set and think they are the best sounding speakers around, but, they are poorly made. I mean REALLY BAD. My first set blew with two loud pops. I tried to take the sub-woofer cabinet apart to get to the electronics and it was sealed--forever. These were not intended to be services, but thrown out. I had to take a Roto-Zip to cut the side out of the cabinet and when I got to the electronics I could not tell which caps had blown. Long story short, I threw them out.
    I then found a set on e-bay and thought I had died and gone to heaven. I paid the guy $125, he shipped them, and I was happy for a couple of months, then this new set blew up. Screw it, I'm giving up on these pieces of junk, which, by the way, neither Altec Lansing nor Dell supports (I called both) and, this comes as no surprise, they're made in Japan. Thanks, Altec Lansing, for using your good name to produce junk.
    Ah, I feel better.
    New Friend:
This is my Dell Altec Lansing 5.1 (ADA995) surround sound amplifier for my computer. There is a design flaw where the board gets corroded due to the fact they caulked or glued it togther and left some of the circuit board hanging out. Just thought I would point out my findings in case some of you had the same system. It's a relatively easy fix. I got all the parts from Newark for about $30.00, and it took roughly 2 hours. Original Amplifier Chips below:
Positive Voltage Regulator is blown out:
Notice the traces where corrosion caused a short:
Another Altec Lansing ADA995 does not work - 8_18_2012_3_30_13_am.jpg:
This resistor was blown out.
I pAltec Lansing ADA995 does not work - 8_18_2012_3_31_59_am.jpgok the picture I went ahead and replaced all of the 4.7 ohm 1/4 watt resistors:8_18_2012_3_31_59_am.jpg
BlownAltec Lansing ADA995 does not work - 8_18_2012_3_33_48_am.jpgistor:8_18_2012_3_32_37_am.jpgNew goods!8Altec Lansing ADA995 does not work - 8_18_2012_3_35_55_am.jpg class=
Just before surgery on the amp chips:
Re-jumpered the traces:
Re-jumpered the traces:8_18_2012_3_36_44_am.jpg Boy that "Heat Sink Transfer Paste" is really messy!!!:8_18_2012_3_37_26_amAltec Lansing ADA995 does not work - 8_18_2012_3_39_35_am.jpg><br><span>A
peek at the underside:</span><img src=
8_18_2012_3_38_35_amAltec Lansing ADA995 does not work - 8_18_2012_3_41_02_am.jpg>
<p>New L7815CV Positive Voltage Regulator (Shown here):<br><span>New L7915CV Negative Voltage Regulator is on the
back side:</span><img src=
New amp chips are all nestled down in their new home!:
Boy that's a big heat-sink:
Time to try it out. And it works. Boy, going a week with out 5.1 audio on your computer is terrible! Nobody should have to live that way or be subjected to that kind of torture. I guess this would be considered a "first world problem"!
-Jason-
Posted on Aug 18, 2012
  • johnguitar3
    johnguitar3 Sep 10, 2012
    What screws did you have to remove to be able to take out the circuit boards? Did you have to remove the 2 large port tubes? My center channel output and subwoofer aren't working (tested with diagnostic jack on sub), and I'm trying to get to the circuit board to look for any fried components.
    Problem Solver:
  • 7 Answers
I've managed to fix the amp in the ADA995 when I blew the rear channel amp. There is a design fault with the voltage regulator that causes it to run very hot, which frys the plastic housing glued near it, which corrodes the circuit board trace.
Getting the sub/amp apart is a *****. But doable. You need to not only remove the screws in the back under the flat grills, but ALSO 3 screws behind the top speaker that also hold the amp in place. And getting the power supply out is another rather difficult procedure, which is needed if you want to run the amp on the bench to troubleshoot.
Posted on Apr 22, 2012
  • Travis Chastain Jun 27, 2012
    Alan, do you have any advice on opening the sub? I removed every screw I could see and nothing budged (except something inside when I removed the bottom screws). I'm assuming I need to make an... incision somewhere? I just don't want to ruin it in the quest to replace bad components.
  • Richard Cypher May 20, 2015
    Where can I find those 3 screws behind the top speaker
    Problem Solver:
  • 14 Answers
Does the unit have a fuse??
If so I would start there, making sure that I replace it with a like fuse.
I don't believe you are going to find a schematic outside of a repair center. Leaving you with a repair center or replacing the speaker system.
Looking quickly on the web, I see a great many refurbs not sure why, but a question.
john
john
Posted on Aug 20, 2008
6ya staff
SOURCE:
I connected some Altec Lansing speakers to my all in one (dell) desktop and now the built-in speakers don't want to work when i disconnect the Altec Lansing speakers !!
Your audio drivers may not be detecting the removal of the audio jack. First make sure the jack is completely removed from the computer.
Next, try a reboot.
Then go to the system tray, near the clock, and right click the speaker icon (you may need to expand the tray by clicking the icon.) Select "Control Panel" (the name may change depending on your audio card manufacturer) and then look for the "Jack Detection" option, it is usually a checkbox. Make sure it's checked, or if it is, uncheck it and then re-check it.
Please remember to vote for me if you like my solution.
Apr 07, 2011 | Computers & Internet
Sound is very low
What are you using for the sound source? That could be where the volume is being lost.
Here is a troubeshooting guide.
http://support.dell.com/support/edocs/acc/ada995/trouble.htm
Mar 13, 2010 | Altec Lansing ADA995 Speaker
I have an ada995 and want to run it on a dell inspiron 15
go to http://support.dell.com/support/edocs/acc/ada995/usage.htm
u will find everything u need to know about using ada on ur dell
Mar 12, 2010 | Altec Lansing ADA995 Speaker
Altec Lansing ADA995 Speaker system partial speaker play
Drivers and support softwares for Dell Dimension 9100 are still very much available to Dell's website (here). Download the audio driver for your StaCruz Audio card.
Hope this helps. Please don't forget to rate.
Nov 07, 2009 | Altec Lansing ADA995 Speaker
How can I hook these speakers to a laptop pc? I have a dell inspiron laptop with an output for the earplugs. I was wondering if the ADA995 could be attached to a mocked-up plug for this output. Seems these...
External speakers can be connected to the earphone jack,BUT remember the computer output is only designed to power earphones not big speakers. The speakers have to have an amp built in, like some desktop speakers. Also if you use an adapter to connect the speakers, you MUST make sure the grounds and output wires are matched correctly or you will fry the computers audio board or worse.
Sep 01, 2009 | Altec Lansing ADA995 Speaker
Hooking 5.1 computer speakers to a Samsung Plasma
Computer speakers are powered, they have their own amps inside the speaker cabinet.
To get these to work on a TV you need to plug them into a headphone out jack.
The external speaker terminals produce too hot a signal for powered computer speakers. The amp in the speakers may have already been damaged.
May 04, 2009 | Altec Lansing ADA995 Speaker
Output board for Altec Lansing ADA995
I had the same problem. One day I heard two pops and the speaker, including the power light, were dead. Neither Dell nor Altec Lansing support them. They're throw-aways, unless you know a genius electronics technician.
Dec 24, 2007 | Audio Players & Recorders
Altec Lansing ADA995 Speaker Logo
2,434 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Don Hart
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
