Mitsubishi WD-52525 52 in. Rear Projection... According to a diagnosis by TV Jack in Bonita,CA the FMT Module and digit Board are defective. The replacement parts cost and labor charge are $995.95. Is it possible to having the capacitors changed on the boards to resolve the issue?
  • mroyster Aug 20, 2008
    The original problem is no picture and the lamp light staying "Red". I ordered a new replacement lamp, which didn't fix the problem and that I can not return. At that point, I contracted a Mitusbishi authorized manufacturer for a paid diagnosis and pick-up.
  • 4,234 Answers
In order to make any determination, the original problem description is required. Please post the original problem.
Thanks,
Dan
Posted on Aug 20, 2008
Hi i have a mitsubishi WD-52525 and the timer light just keeps flashing and the tv wont power on....whats wrong with it?
Check for bad cap on DM & FMT modules 1000uf at 25volts caps to E2P module.
Credit: http://www.repairworld.com
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Green lines thru picture like some open the shades
If the menu is clear without the lines then chances are its failed caps on the FMT board. You can get the V26 FMT repair kit from the following link which also includes instructions for the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-fmt-pwb-repair-kit/cName/repair-kits
Jul 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Horizontal Lines in Picture, Picture Possibly Dimmer
The dimming is usually caused by the mirror needing polishing. The lines floating across the screen is usually caused by failed caps on the FMT board you can get the V26 FMT repair kit from
Jul 07, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Hi, I have a Mitsubishi WD-52525, and have the Green Light of Death. I plan on replacing the capacitors, and have the Power Chassis out of the TV. However, I am having issues extracting the DM module...
The DM is the second board in the chassis from the right side looking in the rear. The first board is the FMT. The second is the DM, third is the Signal and the one which is sideway across the front is the Power board. The Chassis metal shields have to be removed to access the boards.
Dec 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitubishi WD 62725 - Ballast Problem??
the capacitors on the power board are the most likely the cause of the problem.
Jun 21, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Vertical Green Lines across TV Screen with no picture
The capacitorson the FMT board have failed, which will cause that symptom. Is the menu screen clear when you hit menu?
Apr 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Need DM or FMT PC board
If the front light of the TV is blinking green suspect caps are bad and change them yourself, google for cap locations
Nov 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Sep 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Blinking green timer light
Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
May 07, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi wd-62327 red light
1. Self-diagnosis error 4-4, check for open F9A06 part # 283P128050 on the Power PCB. 2. Self-diagnosis error 4-4, check for proper seating of the DVI cable between the FMT PCB and the DMD (Light Engine). It may be necessary to disconnect and reconnect this cable to insure proper connection. 3. Self-diagnosis error 4-4, if F9A06 is good and the connection on the DVI cable between the FMT PCB and DMD are secure, suspect the Light Engine part # 939P977020 4. Self-diagnosis error 4-4, check F9A07 part # 283P128050 on the Power PCB, if open suspect the Light Engine part # 939P977020 5. Self-diagnosis error 4-1, suspect the Power PCB part # 930B929001
Sep 10, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
