Question about Lexmark Wheelwriter 1000 Typewriter
Lift off tape doesn't work
Hi!
We replaced the liftoff tape and now it doesn't work any longer. We bought new tapes because we thought the back up we had was too old and dried out. Any suggestions?
Thanks
Gail
  • 462 Answers
Check that it did not twist when put on, the shiny side must face you.
Posted on Aug 21, 2008
How to correct mistake
Push the correction key, and it will automatically lift of the character, just make sure you are using a correctable ribbon with the liftoff tape.
Aug 15, 2014 | Lexmark Wheelwriter 1000 Typewriter
The lift-off tape is to low
1. Use the SPACEBAR or BACKSPACE to move the carrier to the center of the typewriter, then turn off the typewriter and unplug the unit from the AC outlet.
2. Open the Top Cover and remove the cassette ribbon, if installed.
3. Pull off both spools by holding the correction tape taut between the spools; bring the correction tape to a position parallel with the platen and lift up and out.
4. Pass the new tape through left guide, behind the ribbon guide and out through the right guide. The rough (sticky) side of the tape should face the platen.
5. Attach the feeder spool to the pin on the left.
6. Attach the take up spool to the pin on the right. Turn the take up spool counter-clockwise until a small amount of white tape has wound around it.
7. Replace the cassette ribbon and close the top cover, plug in the AC cord to the AC outlet, and turn on the typewriter.
May 20, 2013 | Brother GX-6750 Typewriter
Will no longer record answers because "out of
Hi, I would suggest that you get another tape. Because after so many recordings the tape will become unreadable by the machine. Replace the tape.
Aug 18, 2011 | Panasonic Lands Phones
Just bought a 2000 grand marquis. keyless keypad does not work. is there a way to reset it or know if the module has to be replaced
Your factory 5 digit code is taped to one of the lift arms in your trunk.Try that out & if that doesn't work then the whole system may need replacing
Jul 19, 2011 | 2000 Mercury Grand Marquis
How to change the correction tape?
Changing the Correction Tape
1) Move the print carrier to the center of the platen using the SPACE or BS key.
2) To replace the correction tape, lift out the typing ribbon cassette (see Changing The Ribbon Cassette) and remove the two spools of the lift off tape by pulling them outwards.
3) Place the empty spool of new tape on the left pin so that the tape winds clockwise. Place the tape around the left guide. Pull the tape around the right
guide and place the loaded spool on the right pin so that the tape unwinds counter-clockwise.
Note: Make sure the sticky side of the tape is facing the platen.
4) Manually turn the left-hand spool in the clockwise direction, tightening the tape until resistance is felt.
5) Replace the typing ribbon cassette.
6) Press the CODE + = (SETTING) key.
Changing the Ribbon Cassette
2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette.
3) To insert a new cassette, place the back end of the cassette on the cassette
holder on the carrier and gently press down on the front of the cassette unit it clicks into place.
4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon.
5) Presss the CODE + = (SETTING) key.
Good Luck!
Oct 13, 2010 | Smith Corona Wordsmith 100 Typewriter
Lift Off tape is not working we bought brand labeled for Brother typewriters. It fits but does not lift off.
Possibly the tape is not on correctly. the dull side of the tape must be toward the paper.
DickyO
Nov 10, 2009 | Brother SX-4000 Typewriter
Ground shielding wire for needle lift sensor?
Shielding wires are always only connected at one end. Connecting at both ends substantially reduces the protection offered.
Jun 10, 2009 | 2003 Volkswagen Jetta TDI
Tapes sounding funny
try using a smaller tapetime, the grinding noise your hearing is the gears of the tape take up within the casette not the camera, it seems the Sony tapes are 120mins long and the Sony tapes are heavier than TDK and your spool take up on the camera can't take it. the TDK tapes you were previously using may have been a shorter time than 120minute?...try any Hi 8 60min tapes instead. not the 120, they can be too heavy for the take up spool motor of the camera and all its doing is stretching and winding the cassette tape and unable to pull it with a 120 min cassette
Apr 24, 2017 | Sony Handycam® DCR-TRV250 Digital-8...
Liftoff tape doesn't work properly
It could be the ribbon is not seated properly try removing it and reinstalling, or did you remove the tab from the ribbon cartridge top either orange or red coler and did yo wind the lift off tape into the takeup spool show the leader is no longer exposed?
Aug 20, 2008 | Office Equipment & Supplies
Lexmark Wheelwriter 1000 Typewriter Logo
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
